2002-1405
2002-1405
    WAGO(万可电子)
    端子块连接器 4 位置 馈通式 黑色 12-18 AWG
2002-1405 数据手册
Data sheet  |  Item number: 2002-1405 4-conductor through terminal block; 2.5 mm²; suitable for Ex e II applications; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Pushin CAGE CLAMP®; 2,50 mm²; black www.wago.com/2002-1405 Color: Data Electrical data Ratings per IEC/EN 60664-1 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 800 V Rated impulse voltage (III / 3) 8 kV Rated current 24 A Rated current (2) 32 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 20 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 20 A Approvals per CSA Rated voltage CSA (Use Group B) 600 V Rated current CSA (Use Group B) 20 A Rated voltage CSA (Use Group C) 600 V Rated current CSA (Use Group C) 20 A Approvals Ex Rated voltage EN (Ex e II) 550 V Rated current (Ex e II) 22 A Rated current (Ex e II) with jumper 20 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Open Tool Slot Connectable conductor materials Copper Nominal cross section 2.5 mm² Solid conductor 0.25 … 4 mm² / 22 … 12 AWG Solid conductor, push-in termination 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded conductor 0.25 … 4 mm² / 22 … 12 AWG Fine-stranded conductor with ferrule with plastic collar 1 … 2.5 mm² / 18 … 12 AWG Fine-stranded conductor with ferrule, push-in termination, from 1 … 2.5 mm² / 18 … 12 AWG Strip length 10 … 12 mm / 0.39 … 0.47 inch Total number of connection points Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 4 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Total number of connection points 4 Total number of potentials 1 Number of levels 1 Type of wiring Front-entry wiring Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross section can also be inserted via push-in termination. Number of jumper slots 2 Geometrical Data Width 5.2 mm / 0.205 inch Height from upper-edge of DIN-35 rail 32.9 mm / 1.295 inch Depth 69.9 mm / 2.752 inch Mechanical data Design horizontal Type of mounting DIN-35 rail Marking level Center/side marking Material Data Color black Insulating material Polyamide 66 (PA 66) Fire load 0.122 MJ Weight 6.4 g Commercial data Product Group 22 (TOPJOB S) Packaging type BOX Country of origin DE GTIN 4044918081566 Customs Tariff No. 85369010000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text AEx Underwriters Laboratories Inc. UL 60079 Certificate name 20190704E185892 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 ATEx Physikalisch Technische Bundesanstalt (PTB) EN 60079 PTB 03 ATEX 1162 U (II 2 G/D Ex e II bzw. I M 2 Ex e I) IECEx Physikalisch Technische Bundesanstalt IEC 60079 IECEx PTB 03.0004U (Ex eb IIC Gb or Ex eb I Mb) Country specific Approvals Logo Approval Additional Approval Text Certificate name CSA DEKRA Certification B.V. C22.2 No. 158 1536069 KEMA/KEUR DEKRA Certification B.V. EN 60947 71107687 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 14HG1293677PDA BV Bureau Veritas S.A. EN 60947 38586/A0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register EN 60947 91/20112 (E9) Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 UL-Approvals Logo Approval Additional Approval Text UR DEKRA Certification B.V. EN 60947 Certificate name NTR NL 7730 Compatible products tools Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft www.wago.com/210-720 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-243 Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 ferrule Item no.: 216-246 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-246 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-246 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-263 Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 2002-400 Adjacent jumper for continuous commoning; insulated; 2-way; Nominal current 25 A; light gray www.wago.com/2002-400 Item no.: 2002-402 Push-in type jumper bar; insulated; 2-way; Nominal current 25 A; light gray www.wago.com/2002-402 Item no.: 2002-402/000-005 Push-in type jumper bar; insulated; 2-way; Nominal current 25 A; red www.wago.com/2002-402 /000-005 Item no.: 2002-402/000-006 Push-in type jumper bar; insulated; 2-way; Nominal current 25 A; blue www.wago.com/2002-402 /000-006 Item no.: 2002-403 Push-in type jumper bar; insulated; 3-way; Nominal current 25 A; light gray www.wago.com/2002-403 Item no.: 2002-403/000-005 Push-in type jumper bar; insulated; 3-way; Nominal current 25 A; red www.wago.com/2002-403 /000-005 Item no.: 2002-403/000-006 Push-in type jumper bar; insulated; 3-way; Nominal current 25 A; blue www.wago.com/2002-403 /000-006 Item no.: 2002-404 Push-in type jumper bar; insulated; 4-way; Nominal current 25 A; light gray www.wago.com/2002-404 Item no.: 2002-404/000-005 Push-in type jumper bar; insulated; 4-way; Nominal current 25 A; red www.wago.com/2002-404 /000-005 Item no.: 2002-404/000-006 Push-in type jumper bar; insulated; 4-way; Nominal current 25 A; blue www.wago.com/2002-404 /000-006 Jumper Item no.: 2002-405 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Item no.: 2002-405 Push-in type jumper bar; insulated; 5-way; Nominal current 25 A; light gray www.wago.com/2002-405 Item no.: 2002-405/000-005 Push-in type jumper bar; insulated; 5-way; Nominal current 25 A; red www.wago.com/2002-405 /000-005 Item no.: 2002-405/000-006 Push-in type jumper bar; insulated; 5-way; Nominal current 25 A; blue www.wago.com/2002-405 /000-006 Item no.: 2002-405/011-000 Star point jumper; insulated; 3-way (1-3-5); IN = IN terminal block; light gray www.wago.com/2002-405 /011-000 Item no.: 2002-406 Push-in type jumper bar; insulated; 6-way; Nominal current 25 A; light gray www.wago.com/2002-406 Item no.: 2002-406/000-005 Push-in type jumper bar; insulated; 6-way; Nominal current 25 A; red www.wago.com/2002-406 /000-005 Item no.: 2002-406/000-006 Push-in type jumper bar; insulated; 6-way; Nominal current 25 A; blue www.wago.com/2002-406 /000-006 Item no.: 2002-406/020-000 Delta jumper; insulated; 1-2 3-4 5-6; IN = IN terminal block; light gray www.wago.com/2002-406 /020-000 Item no.: 2002-407 Push-in type jumper bar; insulated; 7-way; Nominal current 25 A; light gray www.wago.com/2002-407 Item no.: 2002-407/000-005 Push-in type jumper bar; insulated; 7-way; Nominal current 25 A; red www.wago.com/2002-407 /000-005 Item no.: 2002-407/000-006 Push-in type jumper bar; insulated; 7-way; Nominal current 25 A; blue www.wago.com/2002-407 /000-006 Item no.: 2002-408 Push-in type jumper bar; insulated; 8-way; Nominal current 25 A; light gray www.wago.com/2002-408 Item no.: 2002-408/000-005 Push-in type jumper bar; insulated; 8-way; Nominal current 25 A; red www.wago.com/2002-408 /000-005 Item no.: 2002-408/000-006 Push-in type jumper bar; insulated; 8-way; Nominal current 25 A; blue www.wago.com/2002-408 /000-006 Item no.: 2002-409 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2002-409 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Item no.: 2002-409 Push-in type jumper bar; insulated; 9-way; Nominal current 25 A; light gray www.wago.com/2002-409 Item no.: 2002-409/000-005 Push-in type jumper bar; insulated; 9-way; Nominal current 25 A; red www.wago.com/2002-409 /000-005 Item no.: 2002-409/000-006 Push-in type jumper bar; insulated; 9-way; Nominal current 25 A; blue www.wago.com/2002-409 /000-006 Item no.: 2002-410 Push-in type jumper bar; insulated; 10-way; Nominal current 25 A; light gray www.wago.com/2002-410 Item no.: 2002-410/000-005 Push-in type jumper bar; insulated; 10-way; Nominal current 25 A; red www.wago.com/2002-410 /000-005 Item no.: 2002-410/000-006 Push-in type jumper bar; insulated; 10-way; Nominal current 25 A; blue www.wago.com/2002-410 /000-006 Item no.: 2002-423 Adjacent jumper for continuous commoning; insulated; from 1 to 3; Nominal current 25 A; light gray www.wago.com/2002-423 Item no.: 2002-423/000-005 Adjacent jumper for continuous commoning; insulated; from 1 to 3; Nominal current 25 A; red www.wago.com/2002-423 /000-005 Item no.: 2002-423/000-006 Adjacent jumper for continuous commoning; insulated; from 1 to 3; Nominal current 25 A; blue www.wago.com/2002-423 /000-006 Item no.: 2002-433 Push-in type jumper bar; insulated; from 1 to 3; Nominal current 25 A; light gray www.wago.com/2002-433 Item no.: 2002-434 Push-in type jumper bar; insulated; from 1 to 4; Nominal current 25 A; light gray www.wago.com/2002-434 Item no.: 2002-435 Push-in type jumper bar; insulated; from 1 to 5; Nominal current 25 A; light gray www.wago.com/2002-435 Item no.: 2002-436 Push-in type jumper bar; insulated; from 1 to 6; Nominal current 25 A; light gray www.wago.com/2002-436 Item no.: 2002-437 Push-in type jumper bar; insulated; from 1 to 7; Nominal current 25 A; light gray www.wago.com/2002-437 Item no.: 2002-438 Push-in type jumper bar; insulated; from 1 to 8; Nominal current 25 A; light gray www.wago.com/2002-438 Item no.: 2002-439 Push-in type jumper bar; insulated; from 1 to 9; Nominal current 25 A; light gray www.wago.com/2002-439 Item no.: 2002-440 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 8/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Item no.: 2002-440 Push-in type jumper bar; insulated; from 1 to 10; Nominal current 25 A; light gray www.wago.com/2002-440 Item no.: 2002-472 Staggered jumper; insulated; 2-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-472 Item no.: 2002-473 Staggered jumper; insulated; 3-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-473 Item no.: 2002-473/011-000 Ready-made staggered jumper; insulated; 2-way (1-3); Nominal current 25 A; with contact lugs broken off at the factory and circuit marking; light gray www.wago.com/2002-473 /011-000 Item no.: 2002-474 Staggered jumper; insulated; 4-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-474 Item no.: 2002-475 Staggered jumper; insulated; 5-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-475 Item no.: 2002-475/011-000 Ready-made staggered jumper; insulated; 3-way (1-3-5); Nominal current 25 A; with contact lugs broken off at the factory and circuit marking; light gray www.wago.com/2002-475 /011-000 Item no.: 2002-476 Staggered jumper; insulated; 6-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-476 Item no.: 2002-477 Staggered jumper; insulated; 7-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-477 Item no.: 2002-477/011-000 Ready-made staggered jumper; insulated; 1-3-5-7; Nominal current 25 A; with contact lugs broken off at the factory and circuit marking; light gray www.wago.com/2002-477 /011-000 Item no.: 2002-478 Staggered jumper; insulated; 8-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-478 Item no.: 2002-479 Staggered jumper; insulated; 9-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-479 Item no.: 2002-479/011-000 www.wago.com/2002-479 Ready-made staggered jumper; insulated; 1-3-5-7-9; Nominal current 25 A; with contact lugs broken /011-000 off at the factory and circuit marking; light gray Item no.: 2002-480 Staggered jumper; insulated; 10-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-480 Item no.: 2002-481 Staggered jumper; insulated; 11-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-481 Item no.: 2002-481/011-000 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2002-481 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 9/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Item no.: 2002-481/011-000 Ready-made staggered jumper; insulated; 1-3-5-7-9-11; Nominal current 25 A; with contact lugs broken off at the factory and circuit marking; light gray www.wago.com/2002-481 /011-000 Item no.: 2002-482 Staggered jumper; insulated; 12-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-482 Item no.: 2006-499 Step-down jumper; insulated; from 6/4 mm² to 4/2.5/1.5 mm²; Nominal current 32 A; light gray www.wago.com/2006-499 Item no.: 2009-412 Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-412 Item no.: 2009-414 Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-414 Item no.: 2009-416 Push-in type wire jumper; insulated; wire length 250 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-416 Item no.: 2016-499 Step-down jumper; insulated; from 16/10 mm² to 10/6/4/2.5 mm²; Nominal current 57 A; light gray www.wago.com/2016-499 Item no.: 210-103 Wire commoning chain; insulated; 50 connections; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; 50 connections www.wago.com/210-123 Marking accessories Item no.: 2002-161 Adaptor www.wago.com/2002-161 Item no.: 2009-110 Marking strips; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-005 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-115 /000-005 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 10/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-145 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-145 Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-006 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-145 /000-006 Item no.: 2009-145/000-007 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-145 /000-007 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 2009-191 Group marker carrier www.wago.com/2009-191 Item no.: 2009-192 Group marker carrier www.wago.com/2009-192 Item no.: 2009-193 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 11/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Item no.: 2009-193 Group marker carrier www.wago.com/2009-193 Item no.: 2009-198 Adaptor www.wago.com/2009-198 Item no.: 248-501 Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card www.wago.com/248-501 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 12/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- www.wago.com/793-5501 on type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-002 on type; yellow Item no.: 793-5501/000-005 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/793-5501 /000-005 Item no.: 793-5501/000-006 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/793-5501 /000-006 Item no.: 793-5501/000-007 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/793-5501 /000-007 Item no.: 793-5501/000-012 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/793-5501 /000-012 Item no.: 793-5501/000-014 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; brown www.wago.com/793-5501 /000-014 Item no.: 793-5501/000-017 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 13/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Item no.: 793-5501/000-017 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/793-5501 /000-017 Item no.: 793-5501/000-023 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/793-5501 /000-023 Item no.: 793-5501/000-024 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/793-5501 /000-024 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored www.wago.com/210-196 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715 www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715 www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715 www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715 www.wago.com/210-508 Carrier rail General accessories Item no.: 2002-880/1000-411 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 14/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Item no.: 2002-880/1000-411 Component plug; 2-pole; with diode 1N4007; 10.4 mm wide; Operating temperature 85°C max.; gray www.wago.com/2002-880 /1000-411 Item no.: 2002-880/1000-541 Component plug; 2-pole; LED (red); 10.4 mm wide; Operating temperature 85°C max.; gray www.wago.com/2002-880 /1000-541 Item no.: 2002-880/1000-542 LED module; with red LED; 10.4 mm wide; 30 - 65 V; Operating temperature 85°C max. www.wago.com/2002-880 /1000-542 Item no.: 2002-880/1000-836 Component plug; 2-pole; LED (red); 10.4 mm wide; Operating temperature 85°C max.; gray www.wago.com/2002-880 /1000-836 Item no.: 2002-171 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/2002-171 Item no.: 2002-172 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray www.wago.com/2002-172 Item no.: 2002-880 Empty component plug housing; 10.4 mm wide; 2-pole; Type 4; gray www.wago.com/2002-880 Insulation stop plug Protective Warning Marker Item no.: 2002-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2002-115 Item no.: 2002-1491 End and intermediate plate; 0.8 mm thick; gray www.wago.com/2002-1491 Item no.: 2002-1492 End and intermediate plate; 0.8 mm thick; orange www.wago.com/2002-1492 Item no.: 2002-1493 Separator plate; 2 mm thick; oversized; gray www.wago.com/2002-1493 Item no.: 2002-1494 Separator plate; 2 mm thick; oversized; orange www.wago.com/2002-1494 Item no.: 209-191 Separator for Ex e/Ex i applications; 3 mm thick; 120 mm wide; orange www.wago.com/209-191 Item no.: 2002-511 Modular TOPJOB®S connector; modular; for jumper contact slot; 1-pole; 2,50 mm²; gray www.wago.com/2002-511 End plate check Item no.: 2002-549 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2002-549 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 15/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Item no.: 2002-549 Spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/2002-549 Item no.: 2002-552 Modular TOPJOB®S connector; modular; for jumper contact slot; 2-pole; 2,50 mm²; gray www.wago.com/2002-552 Item no.: 2002-553 Modular TOPJOB®S connector; modular; for jumper contact slot; 3-pole; 2,50 mm²; gray www.wago.com/2002-553 Item no.: 2002-554 Modular TOPJOB®S connector; modular; for jumper contact slot; 4-pole; 2,50 mm²; gray www.wago.com/2002-554 Item no.: 2002-555 Modular TOPJOB®S connector; modular; for jumper contact slot; 5-pole; 2,50 mm²; gray www.wago.com/2002-555 Item no.: 2002-556 Modular TOPJOB®S connector; modular; for jumper contact slot; 6-pole; 2,50 mm²; gray www.wago.com/2002-556 Item no.: 2002-557 Modular TOPJOB®S connector; modular; for jumper contact slot; 7-pole; 2,50 mm²; gray www.wago.com/2002-557 Item no.: 2002-558 Modular TOPJOB®S connector; modular; for jumper contact slot; 8-pole; 2,50 mm²; gray www.wago.com/2002-558 Item no.: 2002-559 Modular TOPJOB®S connector; modular; for jumper contact slot; 9-pole; 2,50 mm²; gray www.wago.com/2002-559 Item no.: 2002-560 Modular TOPJOB®S connector; modular; for jumper contact slot; 10-pole; 2,50 mm²; gray www.wago.com/2002-560 Item no.: 2002-611 TOPJOB®S L-type test plug module; modular; 1-pole; 2,50 mm²; gray www.wago.com/2002-611 Item no.: 2002-649 TOPJOB®S L-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/2002-649 Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Downloads Documentation Bid Text 2002-1405 Apr 23, 2019 docx 15.3 kB Download Apr 29, 2019 xml 4.2 kB Download docx - Datei 2002-1405 X81 - Datei Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 16/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 4.2 kB X81 - Datei Additional Information Technical explanations Apr 3, 2019 pdf 2.1 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2002-1405 CAE data EPLAN Data Portal 2002-1405 Download WSCAD Universe 2002-1405 Download Installation Notes Inserting a conductor All conductor types at a glance Terminating solid and ferruled conductors via push-in connection. Inserting conductors via push-in termination. Solid conductors with cross-sections from either one size above, or up to two sizes below, the rated cross-section can be simply pushed in – no tools needed. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 17/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Inserting a conductor via operating tool. Conductor termination – Insulation stop. Connecting fine-stranded conductors without ferrules, or small cross-sectional conductors that cannot be pushed in, is performed similarly to the original CAGE CLAMP® – just use an operating tool. The smart feature: To open the clamp, the operating tool is inserted vertically. The conductor entry is less than 15 degrees for easier wiring. Jumpered Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 18/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 The push-in type jumper bar system is based on the common plug and socket principle. Each terminal block is spring-loaded with a double socket and a resilient CrNi steel spring. The jumper contact material is pure electrolytic copper, which allows for an extremely small design capable of carrying the full-rated current of the terminal block. Ground terminal blocks can also be commoned using the same jumper system. Custom jumpers are created by breaking and removing jumper contacts (2000, 2001, 2002, 2004 Series). Removing a push-in type jumper bar. Insert the operating tool between the jumper and and partition wall of the dual jumper slots, then lift up the jumper. Place the operating tool in the center of jumpers up to five contacts (see above), or alternately on both sides for jumpers with more than five contacts. Jumpered Locate red stripes of the staggered jumpers on the inside. Insert staggered jumper and push down until it hits backstop. Removing a staggered jumper: Insert the operating tool between the staggered jumpers, then lift up the jumper. Jumpered Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 19/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Continuous jumpers (2002 Series) readily connect an endless number of terminal blocks to each other via a single jumper slot. Use the second jumper slot for additional commoning or testing. The 1-to-3 adjacent jumper for continuous commoning enables every other terminal block to be commoned. For example, positive and negative potentials can be accommodated alongside each other. This delta jumper has been specially developed to create a delta configuration and is used on motor terminal boards equipped with TOPJOB® S rail-mount terminal blocks. Push down the wire jumper until fully inserted. Lift the jumper with an operating tool for rewiring. This star point jumper has been specially developed to create a “star point” and is used on motor terminal boards equipped with TOPJOB® S rail-mount terminal blocks. Jumpered Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 20/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Step-down jumpers may common terminal blocks of different sizes, without losing a conductor clamping point. This can be beneficial on long conductor runs where voltage drops may be problematic. A large conductor can be easily connected to smaller conductors at the distribution point. Using step-down jumpers, an end plate must be inserted between the terminal blocks to be commoned. Step-down jumper (2006‑499) commons 6 /4 mm² (10/12 AWG) terminal blocks (2006 /2004 Series) with 4/2.5/1.5 mm² (12/14/16 AWG) terminal blocks (2004/2002/2001 Series). Commoning may be made in either direction using the special thin end plate to cover the open side. Additional through terminal blocks having a smaller cross-section may be commoned using push-in type jumper bars. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 21/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Step-down jumper (2016‑499) commons 16 /10 mm² (16/8 AWG) terminal blocks (2016 /2010 Series) with 10/6/4/2.5 mm² (8/10/12 /14 AWG) terminal blocks (2010/2006/2004 /2002 Series). Stepping down via push-in type jumper bar. Stepping down via push-in type jumper bar. Commoning via open terminal side with end plate allows jumpering over two crosssection sizes for 16 mm² (6 AWG) and 10 mm² (8 AWG) and one cross-section size for 6/4/2.5 mm² (10/12/14 AWG). An example: from 16 mm² (6 AWG) to 6 mm² (10 AWG) (see illustration above) or from 10 mm² (8 AWG) to 4 mm² (12 AWG). Commoning via closed terminal side with end plate allows jumpering over two crosssection sizes, e.g., from 16 mm² (6 AWG) to 6 mm² (10 AWG) or from 6 mm² (10 AWG) to 2.5 mm² (14 AWG) (see illustration above). Note: The total current of the outgoing circuits shall not exceed the nominal current of the step-down jumper/push-in type jumper bar. Testing Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 22/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 The modular TOPJOB® S connectors also connect conductors of the same size as the terminal blocks being used. TOPJOB® S Connectors with a 2 mm Ø test socket for testing voltage via 2-pole voltage tester Rail-mount terminal block assembly for electric motor wiring Test plug adapter (2009‑174, CAT I) for 4 mm Ø plugs – compatible with 2000 to 2016 Series Testing tap (2009‑182) for tool-free connection of test cables up to 2.5 mm² (12 AWG) – compatible with 2000 to 2016 Series L-type test plug module – cross-sectional view of contacts Marking Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 23/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Snapping WMB Inline markers into marker slots. TOPJOB® S 2009‑193 Group Marker Carrier (equipped with a marking strip) for all 2001 to 2016 Series TOPJOB® S Rail-Mount Terminal Blocks Do not use on an end plate! Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 24/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Using marker carriers for marking strips (2002‑161) in jumper slots. Through terminal blocks with a blue insulated housing are suitable for Ex i applications. All through and ground conductor terminal blocks are suitable for Ex e II applications. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 25/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 Separator for Ex e/Ex applications Ex e II/Ex i terminal strip An end plate must be applied to the terminal block located directly behind an Ex e/Ex i separator plate. Notice: Separator located between Ex e II and Ex i terminal strip The movable feet of terminal blocks and separator plates must face the same direction. End plate Ex e II terminal blocks Separator for Ex e/Ex i applications End plate Ex i terminal blocks According to EN 50020, a minimum distance of 50 mm must be kept between live parts of Ex e and Ex i circuits. The use of Ex e/Ex i separators is a space-saving solution when Ex e and Ex i terminal blocks are mounted on a common carrier rail. Product family TOPJOB® S Subject to changes. TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of rail- WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 26/27 Data sheet  |  Item number: 2002-1405 www.wago.com/2002-1405 TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 27/27
2002-1405
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种高速光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,其中1脚为发光二极管的阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为GND,6脚为Vcc。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms,响应时间为100ns。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于高速数据通信和工业控制领域。
6. 应用信息:广泛应用于数据通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
2002-1405 价格&库存
很抱歉,暂时无法提供与“2002-1405”相匹配的价格&库存,您可以联系我们找货
