2002-3237
2002-3237
    WAGO(万可电子)
2002-3237 数据手册
TOPJOB® S Triple-Deck Terminal Blocks 2.5 (4) mm² 2002 Series 0.25 … 2.5 (4) mm²1 AWG 22 … 12 500 V/6 kV/3 2 600 V, 20 AU 600 V, 20 A2 IN 24 A (28 A) 0.25 … 2.5 (4) mm²1 AWG 22 … 12 500 V/6 kV/3 2 600 V, 20 AU 600 V, 20 A2 IN 24 A (28 A) Terminal block width 5.2 mm / 0.205 in. L 10 … 12 mm / 0.43 in.3 Terminal block width 5.2 mm / 0.205 in. L 10 … 12 mm / 0.43 in.3 Terminal block width 5.2 mm / 0.205 in. L 10 … 12 mm / 0.43 in.3 93,3 mm/3.67 in Item No. Through/through/through terminal block, with marker carrier, gray housing 2002-3231 5 L/L/L 4 2002-3233 5 L/L/N 4 Through/through/through terminal block, without marker carrier, gray housing 2002-3201 5 L/L/L 4 2002-3203 5 L/L/N 4 69,5 mm/2.74 in 81,3 mm/3.20 in 0.25 … 2.5 (4) mm²1 AWG 22 … 12 500 V/6 kV/3 2 600 V, 20 AU 600 V, 20 A2 IN 24 A (28 A) 69,5 mm/2.74 in 81,3 mm/3.20 in 38 69,5 mm/2.74 in 81,3 mm/3.20 in 1 93,3 mm/3.67 in Pack. Unit Item No. 50 50 50 50 93,3 mm/3.67 in Pack. Unit Item No. Pack. Unit Through/through/through terminal block, with marker carrier, blue housing 50 2002-3234 4 5 N/N/N 4 Ground conductor/through/through terminal block, with marker carrier, gray housing 50 2002-3247 5 PE/N/L 4 50 2002-3257 5 PE/L/L 4 Through/through/through terminal block, without marker carrier, blue housing 50 2002-3204 4 5 N/N/N 4 Ground conductor/through/through terminal block, without marker carrier, gray housing 50 2002-3217 5 PE/N/L 4 50 2002-3227 5 PE/L/L 4 93,3 mm/3.67 in   Item No. 3 93,3 mm/3.67 in Pack. Unit   Item No. 93,3 mm/3.67 in Pack. Unit   Item No. 6-conductor through terminal block, with marker carrier, internal commoning, conductor entry position colored in violet, gray housing 50 2002-3238 5 L4 6-conductor through terminal block, with marker carrier, internal commoning, conductor entry position colored in violet, blue housing 50 2002-3239 4 5 N4 6-conductor ground terminal block, with marker carrier, internal commoning, green-yellow housing 6-conductor through terminal block, without marker carrier, internal commoning, conductor entry position colored in violet, gray housing 50 2002-3208 5 L4 6-conductor through terminal block, without marker carrier, internal commoning, conductor entry position colored in violet, blue housing 50 2002-3209 4 5 N4 6-conductor ground terminal block, without marker carrier, internal commoning, green-yellow housing Certification organizations can be found in the overview on page 622. 69,5 mm/2.74 in 81,3 mm/3.20 in 2 69,5 mm/2.74 in 81,3 mm/3.20 in 1 69,5 mm/2.74 in 81,3 mm/3.20 in Other terminal blocks with the same profile: 2002-3211/1000-410 Page 88 Diode 2002-3221/1000-434 Page 88 LED PE 4 PE 4 2002-3237 5 2002-3207 5 Pack. Unit 50 50
2002-3237 价格&库存
很抱歉,暂时无法提供与“2002-3237”相匹配的价格&库存,您可以联系我们找货
  • 1+241.195541+31.17021
