2002-480
2002-480
    WAGO(万可电子)
2002-480 数据手册
1 104 TOPJOB® S Staggered Jumpers 2002 Series     Staggered jumper 400 V/6 kV/3 IN 25 A Staggered jumper with 7 contacts Breaking off contact lugs – Individual jumper contacts can be broken off by bending them. The remaining piece of insulation will meet requirements for clearances and creepage distances. Item No. Insert staggered jumper Push staggered jumper down until fully inserted. Pack. Unit Staggered jumper, insulated, suitable for 2002, 2003 and 2022 Series rail-mounted terminal blocks, light gray 100 (4x25) 2-way 2002-472 100 (4x25) 3-way 2002-473 100 (4x25) 4-way 2002-474 50 (2x25) 5-way 2002-475 50 (2x25) 6-way 2002-476 50 (2x25) 7-way 2002-477 50 (2x25) 8-way 2002-478 50 (2x25) Staggered jumper 1 – 3 – 5 – 7 9-way 2002-479 50 (2x25) Marking with a felt-tip pen. 10-way 2002-480 50 (2x25) 11-way 2002-481 50 (2x25) 12-way 2002-482 Locate red stripes of the staggered jumpers on the inside Commoning using staggered jumpers Individual jumper contacts can be broken off by bending them. The remaining piece of insulation will meet the requirements for clearances and creepage distances. This makes it possible to create custom staggered jumpers, e.g. for bridging over a terminal block with a different potential. When creating the jumpers, ensure only one contact lug is in contact with the terminal block. The contact lugs of the customized staggered jumpers contact the terminal blocks via the gaps created in the second jumper. Insert and press jumper into the jumper slot until it hits the backstop. Jumpers staggered in a jumper slot Custom staggered jumpers can be created, e.g., for bridging over a terminal block with a different potential. Make sure only one contact lug is in contact with the terminal block. That way, staggered jumpers are created with contact lugs that will make contact to the terminal block in the gaps of the second jumper. Insert the ready-made jumper assembly into the jumper slot until it hits the stop. Staggered jumpers for sophisticated circuit requirements. Staggered jumper removal Insert the operating tool between the jumpers and lift up the jumper.
2002-480 价格&库存
很抱歉,暂时无法提供与“2002-480”相匹配的价格&库存,您可以联系我们找货
    • 25+20.30803
    库存:100
    2002-480
    • 1+93.929691+12.14034
    • 10+66.6574810+8.61543
    • 25+58.9191525+7.61526
    • 50+54.2243750+7.00846
    • 100+50.41870100+6.51658
    • 250+46.53918250+6.01516
    • 500+44.31591500+5.72780
    • 1000+42.579831000+5.50341
    库存:97
