2002-992
    WAGO(万可电子)
    连接器 端板 用于 TOPJOB®S 系列
2002-992 数据手册
Printview: End plate for fuse terminal blocks; 2 mm thick - Item No.: 2002-992 . End plate for fuse terminal blocks; 2 mm thick Item No.: 2002-992 . End plate for fuse terminal blocks; 2 mm thick . Marking . Business data Supplier WAGO Item no. 2002-992 GTIN / EAN 4045454779245 Content 1 Order amount 25 Customer item number . Notes Technical data Miscellaneous Color orange Fire load [MJ] 0.107 [MJ] Weight [g] 3.82 [g] Width 2 mm / 0.079 in Height from upper-edge of DIN-rail [mm] 57.2 [mm] Height from upper-edge of DIN-rail 57.2 mm / 2.252 in Length 67 mm / 2.638 in WAGO Kontakttechnik GmbH & Co. KG 1 Printview: End plate for fuse terminal blocks; 2 mm thick - Item No.: 2002-992 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 2 Printview: End plate for fuse terminal blocks; 2 mm thick - Item No.: 2002-992 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 3
2002-992 价格&库存
很抱歉,暂时无法提供与“2002-992”相匹配的价格&库存,您可以联系我们找货
  • 1+17.002081+2.11573
  • 10+14.4134210+1.79360
  • 25+13.5109025+1.68129
  • 50+12.8666150+1.60112
  • 100+12.25194100+1.52463
  • 250+11.48403250+1.42907
  • 500+10.93554500+1.36082
  • 1000+10.413731000+1.29588
  • 2500+9.761992500+1.21478
库存:57
2002-992
    • 1+277.68497
    库存:100
