2006-1611/1000-541
2006-1611/1000-541
    WAGO(万可电子)
    端子块连接器 2 位置 断连 灰色 8-14 AWG
2006-1611/1000-541 数据手册
Printview: 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; 12 … 30 V; with blown fuse indication by led - Item No.: 2006-1611/1000-541 . 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; 12 … 30 V; with blown fuse indication by led Item No.: 2006-1611/1000-541 . 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; 12 … 30 V; with blown fuse indication by led . Marking . Business data Supplier WAGO Item no. 2006-1611/1000-541 GTIN / EAN 4045454823962 Content 1 Order amount 25 Customer item number . Notes Safety information 1: Electrical ratings are given by the fuse and blown fuse indication. Technical data Miscellaneous Total number of connection points 2 Total number of potentials 1 Color gray Ratings according to 1 IEC/EN 60947-7-3 Pollution degree (1) 3 Rated voltage EN (1) [V] 800 [V] Rated surge voltage (1) [kV] 8 [kV] Nominal current [A] 10 [A] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; 12 … 30 V; with blown fuse indication by led - Item No.: 2006-1611/1000-541 Technical data Connection technology (1) Push-in CAGE CLAMP® Nominal cross section 1 6 mm² Solid sizes 1 0.5 … 10 mm² / 20 … 8 AWG solid, directly pluggable 1 1 … 10 mm² / 14 … 8 AWG Fine-stranded wires 1 0.5 … 10 mm² / 20 … 8 AWG min. fine-stranded with insulated ferrule, push-in terminati 1.5 mm² / 16 AWG Strip length 1 13 … 15 mm / 0.51 … 0.59 in Type of wiring Front-entry wiring Design horizontal Marking level Center/Side marking Insulating material Polyamide 66 (PA 66) Weight [g] 25 [g] Width 7.5 mm / 0.295 in Height from upper-edge of DIN-rail [mm] 59 [mm] Height from upper-edge of DIN-rail 59 mm / 2.323 in Length 96.3 mm / 3.791 in Type of mounting DIN 35 rail Safety information 2 Leakage current in case of blown fuse: LED 2mA WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; 12 … 30 V; with blown fuse indication by led - Item No.: 2006-1611/1000-541 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; 12 … 30 V; with blown fuse indication by led - Item No.: 2006-1611/1000-541 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
2006-1611/1000-541 价格&库存
很抱歉,暂时无法提供与“2006-1611/1000-541”相匹配的价格&库存,您可以联系我们找货
2006-1611/1000-541
  • 1+1277.22588
库存:30
2006-1611/1000-541
  • 1+318.63458
  • 10+230.12168
  • 25+203.95935
  • 100+182.98203
  • 250+172.26794
  • 500+166.20492
库存:5
2006-1611/1000-541
    • 9+101.58860
    库存:4
    2006-1611/1000-541
    • 1+4152.27801
    库存:30
