Data sheet | Item number: 2050-1207
2-conductor miniature ground terminal block; with operating slots; 1 mm²;
with test port; side and center marking; for DIN-15 rail; Push-in CAGE
CLAMP®; 1,00 mm²; green-yellow
www.wago.com/2050-1207
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at 01788 568 008.
12.07.2021 Page 1/12
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60947-7-2
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-in
Operating tool
Connectable conductor materials
Copper
Copper
Nominal cross-section
1 mm²
Solid conductor
0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor; push-in termination
0.5 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.14 … 0.75 mm² / 24 … 18 AWG
Fine-stranded conductor; with ferrule; push-in termination
0.5 … 0.75 mm² / 20 … 18 AWG
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross-section can also be inserted via push-in termination.
Strip length
9 … 11 mm / 0.35 … 0.43 inch
Total number of connection points
2
Total number of potentials
1
Number of levels
1
Wiring direction
Front-entry wiring
Number of jumper slots
1
Physical data
Width
3.5 mm / 0.138 inch
Height
34 mm / 1.339 inch
Depth from upper edge of DIN-rail
28 mm / 1.102 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-15 rail
Marking level
Center/side marking
Material
Subject to data
Hansastr. 27
32423 Minden
12.07.2021 Page 2/12
Material data
Color
green-yellow
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Weight
3 g
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4055143981545
Customs tariff number
85369010000
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
AEx
Underwriters Laboratories Inc.
UL 60079
E185892
ATEX
Physikalisch Technische Bundesanstalt
EN IEC 60079-0
PTB 19 ATEX 1019
U (II 2G Ex eb IIC Gb
or I M 2 EX eb I Mb)
CCCEx
CQST/CNEx
CNCA-C23-01
2020312313000289
IECEx
IEC 60079
IECEx PTB 19.0050
U (Ex eb IIC Gb or
EX eb I Mb)
Country specific Approvals
Logo
Certificate
name
Approval
CCA
DEKRA Certification B.V.
EN 60947
NTR NL
7839
CCA
EN 60998
NTR NL
7840
Hansastr. 27
32423 Minden
12.07.2021 Page 3/12
7840
CSA
CSA
C22.2 No. 158
80034182
KEMA/KEUR
EN 60947
71113930
KEMA/KEUR
EN 60998
71113957
Approval
cURus
UL 1059
UL-Approvals
Logo
Certificate
name
E4517220200212
Required accessories
End plate
Item no.: 2050-1291
End and intermediate plate; 1.1 mm thick; gray
www.wago.com/2050-1291
Optional accessories
Jumpers
Item no.: 2000-402
Jumper; 2-way; insulated; light gray
www.wago.com/2000-402
Item no.: 2000-402/000-005
Jumper; 2-way; insulated; red
/000-005
Item no.: 2000-402/000-006
Jumper; 2-way; insulated; blue
/000-006
Item no.: 2000-402/000-018
Hansastr. 27
32423 Minden
12.07.2021 Page 4/12
Jumper; 2-way; insulated; yellow-green
/000-018
Item no.: 2000-403
Jumper; 3-way; insulated; light gray
www.wago.com/2000-403
Item no.: 2000-403/000-005
Jumper; 3-way; insulated; red
/000-005
Item no.: 2000-403/000-006
Jumper; 3-way; insulated; blue
/000-006
Item no.: 2000-404
Jumper; 4-way; insulated; light gray
www.wago.com/2000-404
Item no.: 2000-404/000-005
Jumper; 4-way; insulated; red
/000-005
Item no.: 2000-404/000-006
Jumper; 4-way; insulated; blue
/000-006
Item no.: 2000-405
Jumper; 5-way; insulated; light gray
www.wago.com/2000-405
Item no.: 2000-405/000-005
Jumper; 5-way; insulated; red
/000-005
Item no.: 2000-405/000-006
Jumper; 5-way; insulated; blue
/000-006
Item no.: 2000-405/011-000
Star point jumper; 3-way; insulated; light gray
/011-000
Item no.: 2000-406
Jumper; 6-way; insulated; light gray
www.wago.com/2000-406
Item no.: 2000-406/000-005
Jumper; 6-way; insulated; red
/000-005
Item no.: 2000-406/000-006
Jumper; 6-way; insulated; blue
/000-006
Item no.: 2000-406/020-000
Delta jumper; insulated; light gray
/020-000
Hansastr. 27
32423 Minden
12.07.2021 Page 5/12
/020-000
Item no.: 2000-407
Jumper; 7-way; insulated; light gray
www.wago.com/2000-407
Item no.: 2000-407/000-005
Jumper; 7-way; insulated; red
/000-005
Item no.: 2000-407/000-006
Jumper; 7-way; insulated; blue
/000-006
Item no.: 2000-408
Jumper; 8-way; insulated; light gray
www.wago.com/2000-408
Item no.: 2000-408/000-005
Jumper; 8-way; insulated; red
/000-005
Item no.: 2000-408/000-006
Jumper; 8-way; insulated; blue
/000-006
Item no.: 2000-409
Jumper; 9-way; insulated; light gray
www.wago.com/2000-409
Item no.: 2000-409/000-005
Jumper; 9-way; insulated; red
/000-005
Item no.: 2000-409/000-006
Jumper; 9-way; insulated; blue
/000-006
Item no.: 2000-410
Jumper; 10-way; insulated; light gray
www.wago.com/2000-410
Item no.: 2000-410/000-005
Jumper; 10-way; insulated; red
/000-005
Item no.: 2000-410/000-006
Jumper; 10-way; insulated; blue
/000-006
Item no.: 2000-433
Jumper; from 1 to 3; insulated; light gray
www.wago.com/2000-433
Item no.: 2000-433/000-005
Jumper; from 1 to 3; insulated; red
/000-005
Item no.: 2000-433/000-006
Hansastr. 27
32423 Minden
12.07.2021 Page 6/12
Jumper; from 1 to 3; insulated; blue
/000-006
Item no.: 2000-434
Jumper; from 1 to 4; insulated; light gray
www.wago.com/2000-434
Item no.: 2000-435
Jumper; from 1 to 5; insulated; light gray
www.wago.com/2000-435
Item no.: 2000-436
Jumper; from 1 to 6; insulated; light gray
www.wago.com/2000-436
Item no.: 2000-437
Jumper; from 1 to 7; insulated; light gray
www.wago.com/2000-437
Item no.: 2000-438
Jumper; from 1 to 8; insulated; light gray
www.wago.com/2000-438
Item no.: 2000-439
Jumper; from 1 to 9; insulated; light gray
www.wago.com/2000-439
Item no.: 2000-440
Jumper; from 1 to 10; insulated; light gray
www.wago.com/2000-440
Item no.: 210-103
Wire commoning chain; insulated; black
www.wago.com/210-103
Item no.: 210-123
Wire commoning chain; insulated; blue
www.wago.com/210-123
Item no.: 210-111
Steel carrier rail; 15 x 5.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; silver-colored
www.wago.com/210-111
Item no.: 210-295
Steel carrier rail; 15 x 5.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-295
Item no.: 210-296
Aluminum carrier rail; 15 x 5.5 mm; 1 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-296
Item no.: 210-647
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-647
Item no.: 210-648
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short
www.wago.com/210-648
Item no.: 210-719
www.wago.com/210-719
Carrier rail
Tool
Marking accessories
Item no.: 2009-110
www.wago.com/2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
Hansastr. 27
32423 Minden
12.07.2021 Page 7/12
Item no.: 2009-113
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; white
www.wago.com/2009-113
Item no.: 2009-113/000-002
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; yellow
/000-002
Item no.: 2009-113/000-005
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; red
/000-005
Item no.: 2009-113/000-006
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; blue
/000-006
Item no.: 2009-113/000-007
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; gray
/000-007
Item no.: 2009-113/000-012
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; orange
/000-012
Item no.: 2009-113/000-017
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; light green
/000-017
Item no.: 2009-113/000-023
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; green
/000-023
Item no.: 2009-113/000-024
WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; violet
/000-024
Item no.: 2009-191
Group marker carrier
www.wago.com/2009-191
Item no.: 793-3501
WMB marking card; as card; plain; snap-on type; white
www.wago.com/793-3501
Push-in type wire jumper
Item no.: 2009-402
Push-in type wire jumper; 0.75 mm²; insulated; 60 mm long; gray
www.wago.com/2009-402
Item no.: 2009-404
Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; gray
www.wago.com/2009-404
Item no.: 2009-406
Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; gray
www.wago.com/2009-406
Protective warning marker
Item no.: 2000-115
Hansastr. 27
32423 Minden
12.07.2021 Page 8/12
Item no.: 2000-115
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/2000-115
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Ferrule
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Mounting
Item no.: 249-101
Screwless end stop; 6 mm wide; for WMB markers; gray
www.wago.com/249-101
Testing and measuring
Item no.: 2009-174
Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray
www.wago.com/2009-174
Item no.: 2009-182
Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray
www.wago.com/2009-182
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Item no.: 210-137
Test plug; 2.3 mm Ø; with 500 mm cable; yellow
www.wago.com/210-137
Downloads
Documentation
Additional Information
Technical explanations
3 Apr 2019
pdf
2.2 MB
Download
URL
Download
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAE data
EPLAN Data Portal 2050-1207
ZUKEN Portal 2050-1207
CAD data
Hansastr. 27
32423 Minden
12.07.2021 Page 9/12
2D/3D Models 2050-1207
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2050-1207
2-conductor miniature ground terminal block; with operating slots; 1 mm²; with test
port; side and center marking; for DIN-15 rail; Push-in CAGE CLAMP®; 1,00 mm²;
green-yellow
Installation Notes
Conductor termination
Insert solid conductors via push-in
termination.
Insert ferruled conductors via push-in
termination.
Insert fine-stranded conductors via
operating tool.
Hansastr. 27
32423 Minden
12.07.2021 Page 10/12
Remove all conductors via operating tool.
Commoning
Insert a jumper (delta jumper) and push down
until it hits the backstop (picture shows
terminal blocks with push-buttons).
Marking strip (2009‑110) inserted in the
marking slot with jumper symbols of the
inserted jumper (picture shows terminal
Insert a jumper (star point jumper) and push
down until it hits the backstop (picture
shows terminal blocks with push-buttons).
inserted jumper (2000‑405/011‑000 Delta
Jumper) (picture shows terminal blocks with
push-buttons)
Testing
Hansastr. 27
32423 Minden
12.07.2021 Page 11/12
Testing with a 2 mm Ø 210‑136 Test Plug
(max. 42 V).
Marking
Snapping a WMB marking strip into a marker
slot.
Snapping a marking strip (2009‑110) into a
marker slot.
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
Hansastr. 27
32423 Minden
12.07.2021 Page 12/12
很抱歉,暂时无法提供与“2050-1207”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+28.06529
- 10+24.64956
- 25+22.15024
- 100+21.49416
- 500+20.84851
