2060-471/998-404/VE01-3500
    WAGO(万可电子)
    2060 Series 1 Position 24-18 AWG Manual /Automated Wiring Systems Terminal Block
2060-471/998-404/VE01-3500 数据手册
SMD Terminal Blocks Small is Big SMD Terminal Blocks A compact and flat printed circuit board connection is required to achieve the most uniform light distribution, while minimizing shadowing. WAGO’s SMD terminal blocks, with their combination of flat design and wide range of potential uses, completely cover these functionality demands. Furthermore, assembling 1-, 2- and 3-pole terminal blocks without losing any poles provides complete flexibility with a reduced number of variants. All SMD terminal blocks come in tape-and-reel packaging to ensure full integration into an automated assembly process. Applications: The SMD family offers many advantages allowing for a wide range of applications. From compact, conventionally wired LED spotlights up to industrially wired, recessed ceiling luminaires, WAGO’s three SMD terminal block series are the perfect connection between driver and module. The terminal blocks accommodate a broad range of conductors making them highly versatile for worldwide applications. 5.6 mm 4.5 mm 2.7 mm Benefits: Info • Low profile minimizes on-board shadowing • Direct push-in of solid conductors • Terminal strips of different lengths can be mounted without losing any poles allowing for a reduced number of variants and lower production costs • Available in 1–3 pole configurations • Delivery in tape-and-reel packaging for full integration into SMT soldering process • Potential for significant savings via automated pick-and-place assembly Surface Mount Technology Surface Mount Technology (SMT) means soldering electronic components directly onto PCB surface pads without drilling holes. The basic SMT process consists of applying solder paste to the PCB via solder dispensing equipment, screen or stencil printing. Automated assembly Printing (solder) Reflow Soldering Process: SMT components THR-Component SMD SMT assembly is performed using fully automated placement machines. Surface mount components are soldered to the board in infrared, convection or vapor phase ovens. 2059 Series For the Smallest Installation Spaces • Low profile of just 2.7 mm • Pin spacing: 3 mm • Terminates solid conductors from 26 to 22 AWG (0.14 – 0.34 mm2) • Direct push-in of solid conductors • Easy conductor removal via operating tool • Rated data: 160 V, 2.5 kV/2 (III), 3 A • Available in 1-, 2- and 3-pole configurations • Group arrangement is possible without losing any poles • Available in tape-and-reel packaging Inserting solid conductors via push-in termination. Easy conductor removal, e.g., via 206-859 operating tool. Connection technology PUSH WIRE® Overvoltage category III III II Conductor size: solid 0.14 – 0.34 mm2 Pollution degree 3 2 2 AWG 26 – 22 “sol.” Rated voltage 63 V 160 V 320 V Strip length 4 – 5.5 mm / 0.16 – 0.22 in Rated surge voltage 2.5 kV 2.5 kV 2.5 kV Rated current 3A 3A 3A 0,8 __> ( 0,5 ___> < Pole No. Item No. Pack. Unit SMD terminal blocks in tape-and-reel packaging, white 1 2059-301/998-403 31800 (12 x 2650) 2 3 2059-302/998-403 2059-303/998-403 21000 (12 x 1750) 21000 (12 x 1750) Reel diameter: 330 mm > L < > 2,5 < 1 ) 1,6 < > 2,6 < 3 mm / 0.118 in Ratings per )1,4 ( Pin Spacing > 2,7 < 2059 Series, 3 mm Pin Spacing 0,4 ___> < x Rastermaß) - 0,1 mm- 0.1 mm LL == (Polzahl (pole no. x pin spacing) 2060 Series For Manual and Automated Wiring Systems • 4.5 mm high • Pin spacing: 4 mm • Terminates conductors from 24 to 18 AWG (0.2 – 0.75 mm2) • Direct push-in of solid conductors • Push-buttons for easy connection and removal of all types of conductors • Rated data: 160 V, 2.5 kV/2 (III), 9 A • Available in 1-, 2- and 3-pole configurations • Group arrangement is possible without losing any poles • Available in tape-and-reel packaging Inserting solid conductors via push-in termination. Inserting/removing fine-stranded conductors by lightly pressing on push-button (e.g., using a 206-860 operating tool). 2060 Series, 4 mm Pin Spacing Conductor size: solid 0.2 – 0.75 mm2 Pollution degree 3 2 2 Conductor size: fine-stranded 0.2 – 0.75 mm Rated voltage 63 V 160 V 320 V Rated surge voltage 2.5 kV 2.5 kV 2.5 kV Approvals per 9A 9A 9A UL 1977 (with insulated ferrule) Conductor size: fine-stranded 0.25 – 0.34 mm 2 (with uninsulated ferrule) 600 V AWG 24 – 18 Rated voltage, 2 or more poles 250 V Strip length 7 – 9 mm / 0.28 – 0.35 in Pole No. 9A Item No. Pack. Unit SMD terminal blocks with push-buttons in tape-and-reel packaging, white 1 2060-451/998-404 13500 (9 x 1500) 2 3 2060-452/998-404 2060-453/998-404 9000 (9 x 1000) 6750 (9 x 750) Reel diameter: 330 mm > Conductor size: fine-stranded 0.25 – 0.34 mm2 Rated voltage, 1-pole Rated current (UL) 4 2 > < 2,1 0,4 ___> < 2,2 III > 3,5 < (4) 0,4 > 2 < Connection technology Overvoltage category Rated current Conductor Data IEC/EN 60664-1 1,2 0,95 > 4,5 < 2060 Series, Board-to-Board Connection Link Pin Spacing > min. 4,4 ‒ max. 5,4 min. 4,4 ‒ max. 5,4 < > < 2,1 > 3,5 < 0,95 > 2 < III CAGE CLAMP® S III 1,2 > Pin Spacing 0,4 ___> < 2061 Series For Direct Power System Feed-In • 5.6 mm high • Pin spacing: 6 mm • Terminates conductors from 20 to 16 AWG (0.5 – 1.5 mm2) • Direct push-in of solid conductors • Push-buttons for easy connection and removal of all types of conductors • Well-suited for automated wiring systems • Rated data 320 V, 4 kV/2 (III), 17,5 A • 300 V UL 1059 • Available in 1-, 2- and 3-pole configurations • Group arrangement is possible without losing any poles • Available in tape-and-reel packaging Application example: LED driver Inserting/removing fine-stranded conductors by lightly pressing on push-button (e.g., using a 206-861 operating tool). 2061-602/998-404 2061-603/998-404 6300 (9 x 700) 4050 (9 x 450) ) < 0,4 > 2,4 < 1,6 > 4,6 Reel diameter: 330 mm > < 5,6 > 0,55 ____> < 1,8 Pack. Unit SMD terminal blocks with push-buttons in tape-and-reel packaging, white 1 2061-601/998-404 8100 (9 x 900) 2 3 20 – 16 7 – 10 mm / 0.28 – 0.39 in > 4,5 < < AWG Strip length > 2,2 < > 2,1 < – 0.75 mm2 Conductor size: fine-stranded 0.5 (with uninsulated ferrule) < – 0.75 mm2 Conductor size: fine-stranded 0.5 (with insulated ferrule) > Conductor Data Connection technology CAGE CLAMP® S Conductor size: solid 0.5 – 1.5 mm2 Conductor size: fine-stranded 0.5 – 1.5 mm2 5,2 < 6 mm / 0.24 in IEC/EN 60664-1 III III II 3 2 2 250 V 320 V 630 V 4 kV 4 kV 4 kV 17,5 A 17,5 A 17,5 A UL B C D 600 V – 600 V 300 V – 300 V 10 A – 10 A Item No. > Pin Spacing Ratings per Overvoltage category Pollution degree Rated voltage Rated surge voltage Rated current Approvals per Use group UL 1059 Rated voltage, 1-pole Rated voltage, 2 or more poles Nominal current UL Pole No. 3,2 2,7 < 51300133 - 0888-0170/0200-6901 - SMD FLYER 2.0 US - 06/2014 - Printed in Germany - Subject to design changes www.wago.com/SMD WAGO Kontakttechnik GmbH & Co. KG Postfach 28 80 · D - 32385 Minden Hansastraße 27 · D - 32423 Minden Germany Phone: +49 571 887- 0 Fax: +49 571 887-169 E-mail: info@wago.com Online: www.wago.com
2060-471/998-404/VE01-3500 价格&库存
很抱歉,暂时无法提供与“2060-471/998-404/VE01-3500”相匹配的价格&库存,您可以联系我们找货
