SMD Terminal Blocks
with Push-Buttons
SMD Terminal Blocks
Small is Big
WAGO‘s new SMD Terminal Blocks provide push-button
termination for conductors 0.2–0.75 mm2/AWG 24–18
(2060 Series) and 0.5–1.5 mm2/AWG 20–16 (2061 Series),
making them ideal for PCB-based LED lighting and industrial
electronics. Both 2060 and 2061 Series are available as
1-, 2- and 3-pole variants, in light gray or black, and with
4/6 mm pin spacing. Proven CAGE CLAMP® S Spring
Pressure Connection Technology provides push-in termination
of solid and ferruled conductors. Integrated push-buttons
simplify termination of fine-stranded conductors and removal
of all conductor types. WAGO‘s 2060 Series Board-to-Board
Link easily in-lines several LED modules into a single string.
Featuring 8 mm pin spacing, 2060 Series is ideal for higher
rated voltages up to 630 V.
2060 Series
2061 Series
Benefits:
Info
• A height of just 4.5 or 5.6 mm prevents on-board
LED shadowing
• Delivery in tape-and-reel packaging for full
integration into SMT soldering process
• Push-in termination of solid and ferruled conductors
via CAGE CLAMP® S connection
• Potential for significant savings via automated
pick-and-place assembly
• Easy handling via side-entry wiring and top-of-unit
actuation
• Available in 1–3 pole configurations
• Terminal strips of different lengths can be assembled
side-by-side without pole loss, allowing for a reduced
number of variants and lower production costs
• Rated voltage: up to 630 V IEC
• Nominal current: up to 9 A or 12 A
Applications:
The 2060 and 2061 Series‘ many advantages allow them to
support a wide range of applications. From compact, conventionally wired LED spotlights up to industrially wired, recessed
ceiling luminaires, WAGO‘s new SMD Terminal Blocks are the
perfect connection between driver and module. The terminal
blocks accommodate a broad range of conductors making
them highly versatile for wolrdwide applications.
The 2061 Series also provides direct LED module supply
via extended conductor sizes up to 1.5 mm2 (AWG 16).
Furthermore, 2061 Series sets new standards for compact
wiring applications in measuring and control technology.
Conclusion: WAGO‘s 2060 and 2061 Series are the
industry‘s most compact and easy-to-use SMD terminal
blocks for wiring industrial electronics and LED modules.
Handling
2060 Series
Inserting solid conductors via push-in termination.
Inserting/removing fine-stranded conductors by lightly pressing on push-button
(e.g., using a 233-335 operating tool or a ball point pen).
Board-to-Board Link
Inserting board-to-board link into terminal block.
Assembly: Place PCBs on a flat surface and connect terminal blocks on adjoining PCBs via board-to-board link.
The PCBs must be secured (see figure above).
Disassembly: Pull PCBs apart
(max. 10 connections/disconnections).
2061 Series*
*2061 Series will be available in Summer 2013.
Technical Data
2060 Series, 4 mm Pin Spacing
CAGE CLAMP ® S
III
III
II
Conductor size: solid
0.2 – 0.75 mm2
Pollution degree
3
2
2
Conductor size: fine-stranded 0.2 – 0.75 mm2
Rated voltage
63 V
160 V
320 V
Rated surge voltage
2.5 kV
2.5 kV 2.5 kV
UL 1977
Approvals per
Rated voltage, 1-pole
600 V
Rated voltage, 2 or more poles
250 V
Nominal current UL
Pole No.
9 A
AWG
< 2.1
24 – 18
1.4
___>
9A
Item No.
Pack. Unit/Pieces per Reel
SMD terminal blocks with push-buttons in tape-and-reel packaging, light gray*
1
2060-401/998-404
1500
2
3
2060-402/998-404
2060-403/998-404
0.25 – 0.34 mm2
Conductor size: fine-stranded (with
uninsulated ferrule)
> 3.5 <
> 2 <
9A
0.25 – 0.34 mm
insulated ferrule)
2
1.2
0.95
> 4.5 <
2060 Series, Board-to-Board Link
min. 4.4 ‒ max. 5.4
min. 4.4 ‒ max. 5.4
< 2.1
0.25 – 0.34 mm2
AWG
Item No.
24 – 18
9A
2
2060-802/998-404
750
______>
> 3.5 <
0.95
III
Reel diameter: 330 mm
III
III
II
0.5 – 1.5 mm2
Pollution degree
3
2
2
Conductor size: fine-stranded 0.5 – 1.5 mm2
4 kV
4 kV
4 kV
Nominal current
12 A
12 A
12 A
2
3
0.55
____> <
1.6
Item No.
1
2061-601/998-404
> 4.5 <
Pole No.
> 2.2 <
2061-602/998-404
2061-603/998-404
*Depending on reflow soldering temperatures and times, color deviations may occur for light gray connectors.
These deviations will have no impact on functionality.
> 2.1 <
Rated surge voltage
20 – 16
320 V 630 V AWG
250 V
1.8
Rated voltage
> 4.6
0.4
CAGE CLAMP ® S
< 6 > 2.4 <
Connection technology
< 5.6 >
Conductor Data
IEC/EN 60664-1
5.2 <
6 mm / 0.24 in.
Ratings per
Pin Spacing
3.2
2.7 <
Surface Mount Technology
SMT
Surface Mount Technology (SMT) means soldering electronic
components directly onto PCB surface pads without drilling
holes. The basic SMT process consists of applying solder
paste to the PCB via solder dispensing equipment, screen
or stencil printing. SMT assembly is performed using fully
automated placement machines.
Automated assembly
Printing (solder)
Reflow Soldering Process:
SMT components
THR-Component
SMD
Application Examples:
The SMD components are soldered to the board in infrared,
convection or vapor phase ovens.
0888-0170/0100-6901 - SMD FLYER 1.0 US - 03/2013 - Printed in Germany - Subject to design changes
To the video
www.wago.com/2060
WAGO Kontakttechnik GmbH & Co. KG
Postfach 28 80 · D - 32385 Minden
Hansastraße 27 · D - 32423 Minden
Germany
Phone:
+49 571 887- 0
Fax:
+49 571 887-169
E-mail:
info@wago.com
Online:
www.wago.com
很抱歉,暂时无法提供与“2061-602/998-404”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+9.20810
- 10+7.28420
- 30+6.31620
- 100+5.34820
- 700+4.77950
- 1400+4.47700
