207-1332
207-1332
    WAGO(万可电子)
207-1332 数据手册
Data sheet | Item number: 207-1332 Gelbox; for cables; Branch; with gel; 221, 2x73 Series; max. 4 mm² connectors; without splicing connectors; Size 2; gray www.wago.com/207-1332 Color: Item description Note on Packaging Unit (PU) and Subpackaging Unit (SPU): If you order a full PU, you will receive our eco-friendly, sustainable cardboard blisters packed in a shelf-ready box. If you order a quantity smaller than a full PU, you will receive the eco-friendly, sustainable cardboard blisters without a shelf-ready box. Subject to changes. Please also observe the further product documentation! WAGO Private Limited NH No. 8, Block No. 94 Vadsala, Block No. 1187 Varnama, Village Varnama / Vadsala Ta. & Distt. Vadodara, Vadodara, Gujarat-391243 Phone: +91-265-6812100 | Email: info.india@wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.12.2021    Page 1/5 Data sheet | Item number: 207-1332 www.wago.com/207-1332 Please note the system description for the splicing connectors that can be used. The Benefits for You: Easy, fast and safe to use Can be used immediately and accessed again later Silicon-free Label-free Suitable for indefinite storage The complete system consisting of Gelboxes and WAGO connectors has been VDE-tested and IPX8-certified. Data Connection data Connection 1 Actuation type Locking system Physical data Width 33.6 mm / 1.323 inch Height 17.8 mm / 0.701 inch Depth 45.9 mm / 1.807 inch Mechanical data Mounting type Flying leads Protection class IPX8 Material data Note on material data Information on material data can be found here Color gray Housing material Polypropylene Weight 18.4 g Environmental requirements Surrounding air temperature (operation) -55 … 85 °C Surrounding air temperature (storage) 0 … 40 °C Commercial data Subject to changes. Please also observe the further product documentation! WAGO Private Limited NH No. 8, Block No. 94 Vadsala, Block No. 1187 Varnama, Village Varnama / Vadsala Ta. & Distt. Vadodara, Vadodara, Gujarat-391243 Phone: +91-265-6812100 | Email: info.india@wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.12.2021    Page 2/5 Data sheet | Item number: 207-1332 www.wago.com/207-1332 Commercial data PU (SPU) 48 (4) Stück Packaging type BOX Country of origin IT GTIN 4055143998017 Customs tariff number 85389099990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name VDE VDE Prüf- und Zertifizierungsinstitut EN 60998 400051938 Downloads Documentation Bid Text 207-1332 X81 - Datei 207-1331 doc - Datei xml 3.7 kB Download docx 20.9 kB Download pdf 1.2 MB Download pdf 2.2 MB Download URL Download System Description System Description 207 Series Gel boxes Additional Information Technical Section Technical explanations CAD/CAE-Data CAD data 2D/3D Models 207-1332 Subject to changes. Please also observe the further product documentation! WAGO Private Limited NH No. 8, Block No. 94 Vadsala, Block No. 1187 Varnama, Village Varnama / Vadsala Ta. & Distt. Vadodara, Vadodara, Gujarat-391243 Phone: +91-265-6812100 | Email: info.india@wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.12.2021    Page 3/5 Data sheet | Item number: 207-1332 www.wago.com/207-1332 2D/3D Models 207-1332 URL Download URL Download URL Download CAE data ZUKEN Portal 207-1332 Environmental Product Compliance Compliance Search Environmental Product Compliance 207-1332 Gelbox; for cables; Branch; with gel; 221, 2x73 Series; max. 4 mm² connectors; without splicing connectors; Size 2; gray Installation Notes Installation Place the wired connector in the Gelbox. Place the wired connector in the Gelbox. Gelbox öffnen. Close the Gelbox. Close latch securely. Subject to changes. Please also observe the further product documentation! WAGO Private Limited NH No. 8, Block No. 94 Vadsala, Block No. 1187 Varnama, Village Varnama / Vadsala Ta. & Distt. Vadodara, Vadodara, Gujarat-391243 Phone: +91-265-6812100 | Email: info.india@wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.12.2021    Page 4/5 Data sheet | Item number: 207-1332 www.wago.com/207-1332 Re-accessible: Open the Gelbox. Remove the gel. Rewire with new components. Lift the flap and pull the cover perforation forward. Press in the perforation on the sides. As a counter display: Bend the rear flap at the fold, straighten it and fix it in the cardboard cut-out If the flap is not required, tear off from the perforation. Tear off the cover from the perforation. Subject to changes. Please also observe the further product documentation! WAGO Private Limited NH No. 8, Block No. 94 Vadsala, Block No. 1187 Varnama, Village Varnama / Vadsala Ta. & Distt. Vadodara, Vadodara, Gujarat-391243 Phone: +91-265-6812100 | Email: info.india@wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.12.2021    Page 5/5
207-1332 价格&库存
很抱歉,暂时无法提供与“207-1332”相匹配的价格&库存,您可以联系我们找货
    库存:49
    207-1332
      • 1+121.802611+15.77770
