231-333/001-000
231-333/001-000
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 1x3P 间距:5.08mm 排数:1 每排Pin数:3
231-333/001-000 数据手册
Printview: Male connector; with straight solder pins; 3-pole; pin spacing 5.08 mm / 0.2 in; Vertical PCB mounting; with closed end - Item No.: 231-333/001-000 . Male connector; with straight solder pins; 3-pole; pin spacing 5.08 mm / 0.2 in; Vertical PCB mounting; with closed end Item No.: 231-333/001-000 . Male connector; with straight solder pins; 3-pole; pin spacing 5.08 mm / 0.2 in; Vertical PCB mounting; with closed end . Marking . Business data Supplier WAGO Item no. 231-333/001-000 GTIN / EAN 4044918865241 Content 1 Order amount 200 Customer item number . Notes 1.2 x 1.2mm solder pins allow nominal current up to 16A, enhancing stability of shorter headers Enclosed on each side, the pin housing design prevents mismatingCoding option available Technical data Miscellaneous No. of poles 3 Pin Spacing 5.08 mm / 0.2 in % Color orange Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Male connector; with straight solder pins; 3-pole; pin spacing 5.08 mm / 0.2 in; Vertical PCB mounting; with closed end - Item No.: 231-333/001-000 Technical data Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 12 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 12 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 320 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 12 [A] Solder pin length [mm] 5 [mm] Solder pin width A [mm] 1 [mm] Solder pin width B [mm] 1 [mm] Tolerance of drilled hole [mm] 1.4(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 100 C Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 0.02 [MJ] Weight [g] 1.034 [g] Width 18.44 mm / 0.726 in Height 17 mm / 0.669 in Height from the surface 12 mm / 0.472 in Length 8.4 mm / 0.331 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Male connector; with straight solder pins; 3-pole; pin spacing 5.08 mm / 0.2 in; Vertical PCB mounting; with closed end - Item No.: 231-333/001-000 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Male connector; with straight solder pins; 3-pole; pin spacing 5.08 mm / 0.2 in; Vertical PCB mounting; with closed end - Item No.: 231-333/001-000 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
231-333/001-000 价格&库存
很抱歉,暂时无法提供与“231-333/001-000”相匹配的价格&库存,您可以联系我们找货
