236-412
236-412
    WAGO(万可电子)
    插件,P=5.08mm
    接线端子 间距:5.08mm 每排针脚数:12 排数:单排
236-412 数据手册
Printview: PCB terminal strip; 2 solder pins/pole; 12-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236412 . PCB terminal strip; 2 solder pins/pole; 12-pole; pin spacing 5/5.08 mm / 0.2 in Item No.: 236-412 . PCB terminal strip; 2 solder pins/pole; 12-pole; pin spacing 5/5.08 mm / 0.2 in . Marking . Business data Supplier WAGO Item no. 236-412 GTIN / EAN 4044918770668 Content 1 Order amount 20 Customer item number . Notes Terminal strips with CAGE CLAMP® connection, screwdriver actuation parallel or perpendicular to conductor entryAlso available with Ex e approvalFor custom terminal strip assembliesOperating tools for factory wiring45° connection angle permits a wide range of uses and wiring optionsSet to metric or inch pin spacing by compressing terminal strips together or pulling them apart Technical data Miscellaneous No. of poles 12 Pin Spacing 5/5.08 mm / 0.2 in Total number of connection points 12 Total number of potentials 12 Color gray Ratings according to 1 IEC/EN 60664-1 WAGO Kontakttechnik GmbH & Co. KG 1 Printview: PCB terminal strip; 2 solder pins/pole; 12-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236412 Technical data Overvoltage category EN 1 III Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 24 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 24 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 250 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 24 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 1.5 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 1.5 mm² / … Strip length 1 5 … 6 mm / 0.2 … 0.24 in Conductor entry angle to the PCB 1 [°] 45 [°] Type of wiring Front-/Side-entry wiring Solder pin arrangement in-line solder pin Solder pin length [mm] 4 [mm] Solder pin width A [mm] 0.7 [mm] Solder pin width B [mm] 0.7 [mm] Tolerance of drilled hole [mm] 1.1(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Clamping spring material Chrome-nickel spring steel (CrNi) WAGO Kontakttechnik GmbH & Co. KG 2 Printview: PCB terminal strip; 2 solder pins/pole; 12-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236412 Technical data Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 0.148 [MJ] Weight [g] 10.42 [g] Width 62.3 mm / 2.453 in Height 17 mm / 0.669 in Height from the surface 13 mm / 0.512 in Length 14 mm / 0.551 in WAGO Kontakttechnik GmbH & Co. KG 3 Printview: PCB terminal strip; 2 solder pins/pole; 12-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236412 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 4 Printview: PCB terminal strip; 2 solder pins/pole; 12-pole; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236412 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
236-412 价格&库存
很抱歉,暂时无法提供与“236-412”相匹配的价格&库存,您可以联系我们找货
  • 1+100.480451+13.02418
  • 10+71.3265210+9.24528
  • 25+63.1004925+8.17903
  • 50+58.1219850+7.53372
  • 100+54.09125100+7.01126
  • 250+49.98710250+6.47928
  • 500+47.63718500+6.17469
  • 1000+45.803351000+5.93699
库存:467
236-412
  • 5+78.41411
  • 125+75.27330
  • 375+72.80522
库存:30
