Data sheet | Item number: 249-125
Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross
section 0.75 mm²
www.wago.com/249-125
Item description
Safety information 1:
Note: Push down the wire jumper until fully inserted!
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
800 V
Rated impulse voltage (III / 3)
8 kV
Rated current
9 A
Mechanical data
Wire length of wire jumpers
60 mm
Material Data
Fire load
0.018 MJ
Weight
2 g
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/5
Weight
2 g
Commercial data
Product Group
2 (Terminal Block Accessories)
Packaging type
BOX
Country of origin
DE
GTIN
4044918786249
Customs Tariff No.
85444290900
Downloads
Documentation
Bid Text
249-125
Apr 27, 2017
doc
23.6 kB
Download
Feb 19, 2019
xml
2.6 kB
Download
Apr 3, 2019
pdf
2.1 MB
Download
doc - Datei
249-125
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAE data
WSCAD Universe 249-125
Download
Installation Notes
Jumpered
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/5
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/5
Wire jumpers
When installing machines or control
systems, it is often necessary to make an
additional connection between two terminal
blocks that are not next to each other on the
rail. In such cases, WAGO’s touch-proof,
push-in type wire jumpers are the ideal
solution.
These jumpers are compatible with the
following rail-mount terminal blocks:
279 Series (1.5 mm²/16 AWG),
280/775/780 Series (2.5 mm²/14
AWG)
281/769/776/777/781 and 880
Series (4 mm²/12 AWG)
They are available in three conductor
lengths (60, 110 and 250 mm), allowing up to
60 terminal blocks to be commoned
depending on their width (see table on the
right).
Compared with the 279 Series, the 280/775
/780 and 281/776/777/781 Series can also
accommodate two wire jumpers, allowing
the use of commoning chains. Furthermore,
the 280/769/775/780/880 and 281/776/777
/781 Series allow both wire jumper and
adjacent jumper to be simultaneously
plugged into a same terminal block.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/5
“n” = number of 279, 280/769/780/880 and
281/781 Series Rail-Mount Terminal Blocks
that can be skipped with a wire jumper.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/5
很抱歉,暂时无法提供与“249-125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 12+65.9013612+8.53150
- 60+59.3548760+7.68400
