Data sheet | Item number: 250-314
PCB terminal block; push-button; 0.5 mm²; Pin spacing 2.5 mm; 14-pole;
Push-in CAGE CLAMP®; 0,50 mm²; gray
www.wago.com/250-314
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
27.11.2021 Page 1/9
Dimensions in mm
L = (pole no. x pin spacing) + 1.5 mm
Item description
Compact PCB terminal strips with push-buttons
Push-in termination of solid conductors
Termination/removal of fine-stranded conductors via push-buttons
45° conductor entry angle provides easy, space-saving wiring
Custom color combinations
Terminal strips also available with spacers upon request
Data
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
27.11.2021 Page 2/9
Data
Notes
Variants:
Other pole numbers
Other colors
Mixed-color PCB connector strips
Terminal strips with spacers
Direct marking
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
100 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
4 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Ratings per UL
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
5 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
5 A
Ratings per CSA
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
2 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
2 A
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
27.11.2021 Page 3/9
Connection data
Total number of connection points
14
Total number of potentials
14
Number of connection types
1
Number of levels
1
Connection 1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.14 … 0.5 mm² / 24 … 20 AWG
Fine-stranded conductor
0.2 … 0.5 mm² / 24 … 20 AWG
Conductor diameter
0.4 … 0.8 mm / 24 … 20 AWG
Strip length
8.5 … 9.5 mm / 0.33 … 0.37 inch
Conductor connection direction to PCB
45 °
Pole No.
14
Physical data
Pin spacing
2.5 mm / 0.098 inch
Width
36.5 mm / 1.437 inch
Height
16.7 mm / 0.657 inch
Height from the surface
13.1 mm / 0.516 inch
Depth
12 mm / 0.472 inch
Solder pin length
3.6 mm
Solder pin dimensions
0.4 x 0.75 mm
Drilled hole diameter with tolerance
1 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (in-line)
Number of solder pins per potential
1
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
27.11.2021 Page 4/9
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Copper alloy
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.118 MJ
Weight
4.9 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
PU (SPU)
120 (30) Stück
Packaging type
box
Country of origin
CH
GTIN
4050821573203
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CSA
DEKRA Certification B.V.
C22.2 No. 158
1132097
Approval
Certificate
name
UL
UL International Germany GmbH
UL 1059
E45172
UL-Approvals
Logo
Optional accessories
Testing and measuring
Testing accessories
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
27.11.2021 Page 5/9
Testing accessories
Item no.: 735-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/735-500
Marking accessories
Marking strip
Item no.: 210-331/250-207
Marking strips; as a DIN A4 sheet; MARKED; 1-48 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip
length 182 mm; Horizontal marking; Self-adhesive; white
www.wago.com/210-331
/250-207
Item no.: 210-331/250-202
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/250-202
Item no.: 210-331/250-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/250-204
Item no.: 210-331/250-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/250-206
Tool
Operating tool
Item no.: 210-647
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-647
Item no.: 210-719
www.wago.com/210-719
Downloads
Documentation
Additional Information
Technical explanations
2019 Apr 3
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 250-314
PCB Design
Symbol and Footprint 250-314
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
27.11.2021 Page 6/9
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 250-314
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 250-314
PCB terminal block; push-button; 0.5 mm²; Pin spacing 2.5 mm; 14-pole; Push-in
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
27.11.2021 Page 7/9
Installation Notes
Conductor termination
Inserting solid conductors via push-in
termination.
Inserting fine-stranded conductors via pushbuttons, 250 Series – 3.5 mm pin spacing.
Space-saving wiring, 250 Series – 5 mm pin
spacing.
Testing
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
27.11.2021 Page 8/9
Testing with 11 mm Ø test pin, on the
conductor, 250 Series – 2.5 … 3.5 mm pin
spacing.
Testing with 2 mm Ø test plug, touch
contact, 250 Series – 5 mm pin spacing.
Marking
Labeling via self-adhesive strips or direct
marking. Mixed-color terminal strips (with or
without spacer) are available upon request.
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
27.11.2021 Page 9/9
很抱歉,暂时无法提供与“250-314”相匹配的价格&库存,您可以联系我们找货
