1
136
PCB Terminal Strips with Push-buttons 1.5 mm2
Pin Spacing: 5 mm, 7.5 mm
250 Series
Compact PCB terminal strips with push-buttons
Simple, push-in terminations of solid and ferruled conductors
P ush-button operation for connecting of fine-stranded conductors
and removing of conductors
45° conductor entry angle provides easy, space-saving wiring
Technical data:
Pin Spacing
Ratings per
Overvoltage category
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Use group UL1059
Rated voltage
Nominal current UL
Nominal current CSA
5 mm
0.197 in.
IEC/EN 60664-1
III
III
II
3
2
2
320 V 320 V 630 V
4 kV
4 kV
4 kV
17.5A 17.5A 17.5A
UL/CSA
B
C
D
300 V
300 V
2A
2A
10 A
10 A
7.5 mm
0.295 in.
IEC/EN 60664-1
III
III
II
3
2
2
500 V 630 V 1000 V
6 kV
6 kV
6 kV
17.5A 17.5A 17.5A
UL/CSA
B
C
D
300 V
300 V
2A
2A
10 A
10 A
Conductor and solder pin data:
Connection technology
Conductor size: solid
Conductor size: fine-stranded
AWG
Strip length
Conductor entry angle
Solder pin: length/width
Solder pin: drilled hole diameter
Push-in CAGE CLAMP®
0.5 … 1.5 mm2
0.5 mm2/20 AWG (I max. 2 A)
0.75 … 1.5 mm2 (I max. 4 A)
(with insulated ferrule)
0.5 … 1 mm2
(with uninsulated ferrule)
0.5 … 1 mm2
20 … 16 (20 … 14 “sol.”)
9 … 10 mm / 0.35 … 0.39 in.
45° to PCB
4 mm / 0.5 x 0.75 mm
Current in A
10
5
40
50
60
70
80
90 100 105
Ambient operating temperature in °C
2-, 4-, 6-, 12-pole
Conductor rated current
1.2–0.1 mm
Material data:
Material group
Insulating material
Flammability class per UL 94
Lower/Upper limit temperature
Clamping spring material
Contact material
Contact plating
Current-Carrying Capacity Curve
Pin spacing: 5 mm / Conductor size: 1.5 mm2 “sol.”
Based on: EN 60512-5-2 / Reduction factor: 1
250 Series accessories:
I
Polyamide 46 (PA 46)
V0
-60 °C / +105 °C
Chrome nickel spring steel (CrNi)
Electrolytic copper (ECu)
tin-plated
Additional approvals and corresponding ratings can be found at www.wago.com.
Marking accessories
Operating tools
Test pin
For additional technical information, see Section 13.
Page:
570
556
568
很抱歉,暂时无法提供与“250-503”相匹配的价格&库存,您可以联系我们找货
