Printview: Triple-deck terminal block; Through/through/through terminal block - Item No.: 280-549
Item No.: 280-549
Marking
Business data
Supplier
WAGO
Item no.
280-549
GTIN / EAN
4050821293729
Content
1
Order amount
40
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
6
Total number of potentials
3
Number of levels
3
Color
gray
Ratings according to 1
IEC/EN 60947-7-1
Pollution degree (1)
3
Rated voltage EN (1) [V]
500 [V]
Rated surge voltage (1) [kV]
6 [kV]
Nominal current [A]
20 [A]
Connection technology (1)
CAGE CLAMP®
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Solid sizes 1
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded wires 1
Strip length 1
8 … 9 mm / 0.31 … 0.35 in
Note (conductor cross-section)
12 AWG: THHN, THWN
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.277 [MJ]
Weight [g]
18.39 [g]
Width
5 mm / 0.197 in
Height from upper-edge of DIN-rail [mm]
76.5 [mm]
76.5 mm / 3.012 in
Length
103 mm / 4.055 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“280-549”相匹配的价格&库存,您可以联系我们找货
