280-942/281-488
280-942/281-488
    WAGO(万可电子)
280-942/281-488 数据手册
Data sheet  |  Item number: 280-942/281-488 Component terminal block; double-deck; with 2 diodes 1N4007; Top anode; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-942_281-488 Color: Item description Note: Terminating Aluminum Conductors WAGO spring clamp terminal blocks are suitable for solid aluminum conductors up to 4 mm²/12 AWG if WAGO “Alu-Plus” Contact Paste is used for termination. “Alu-Plus” Contact Paste Advantages: Automatically destroys the oxide film during clamping. Prevents fresh oxidation at the clamping point. Prevents electrolytic corrosion between aluminum and copper conductors (in the same terminal block). Provides long-term protection against corrosion. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Provides long-term protection against corrosion. Using terminal blocks with CAGE CLAMP® Spring Pressure Connection Technology, aluminum conductors must first be cleaned with a blade and then immediately be inserted into the clamping units filled with “Alu-Plus” Contact Paste. It is also possible to apply WAGO “Alu-Plus” additionally on the whole surface of the aluminum conductor before termination. Please note that the nominal currents must be adapted to the reduced conductivity of the aluminum conductors: 2.5 mm² (14 AWG) = 16 A 4 mm² (12 AWG) = 22 A Data Electrical data Nominal voltage 250 V Reverse voltage 1,000 V Ratings per IEC/EN 60664-1 Rated current 0.5 A Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Connectable conductor materials Copper Aluminum Solid conductor 0.08 … 2.5 mm² / 28 … 14 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 14 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Total number of connection points 4 Total number of potentials 2 Number of levels 2 Type of wiring Front-entry wiring Geometrical Data Width 5 mm / 0.197 inch Height from upper-edge of DIN-35 rail 58.5 mm / 2.303 inch Depth 64 mm / 2.52 inch Mechanical data Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Mechanical data Design horizontal Type of mounting DIN-35 rail Marking level Center marking Material Data Color gray Insulating material Polyamide 66 (PA 66) Fire load 0.188 MJ Weight 10.5 g Commercial data Product Group 1 (Rail Mounted Terminal Blocks) Packaging type BOX Country of origin DE GTIN 4045454196783 Customs Tariff No. 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 60947 2157201.01 Ship Approvals Logo Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 Certificate name 14HG1293677PDA Compatible products Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Female plug Item no.: 232-132/005-000 www.wago.com/232-132 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 2-pole; /005-000 gray Item no.: 232-132/005-000/039-000 www.wago.com/232-132 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 2-pole; gray Item no.: 232-133/005-000 www.wago.com/232-133 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 3-pole; /005-000 gray Item no.: 232-133/005-000/039-000 www.wago.com/232-133 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 3-pole; gray Item no.: 232-134/005-000 www.wago.com/232-134 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 4-pole; /005-000 gray Item no.: 232-134/005-000/039-000 www.wago.com/232-134 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 4-pole; gray Item no.: 232-135/005-000 www.wago.com/232-135 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 5-pole; /005-000 gray Item no.: 232-135/005-000/039-000 www.wago.com/232-135 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 5-pole; gray Item no.: 232-136/005-000 www.wago.com/232-136 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 6-pole; /005-000 gray Item no.: 232-136/005-000/039-000 www.wago.com/232-136 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 6-pole; gray Item no.: 232-137/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 7-pole; www.wago.com/232-137 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 7-pole; www.wago.com/232-137 gray /005-000 Item no.: 232-137/005-000/039-000 www.wago.com/232-137 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 7-pole; gray Item no.: 232-138/005-000 www.wago.com/232-138 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 8-pole; /005-000 gray Item no.: 232-138/005-000/039-000 www.wago.com/232-138 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 8-pole; gray Item no.: 232-139/005-000 www.wago.com/232-139 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 9-pole; /005-000 gray Item no.: 232-139/005-000/039-000 www.wago.com/232-139 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 9-pole; gray Item no.: 232-140/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 10pole; gray www.wago.com/232-140 /005-000 Item no.: 232-140/005-000/039-000 www.wago.com/232-140 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 10-pole; gray Item no.: 232-142/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 12pole; gray www.wago.com/232-142 /005-000 Item no.: 232-142/005-000/039-000 www.wago.com/232-142 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 12-pole; gray Item no.: 232-146/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 16pole; gray www.wago.com/232-146 /005-000 Item no.: 232-146/005-000/039-000 www.wago.com/232-146 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 16-pole; gray Item no.: 232-147/005-000/039-000 www.wago.com/232-147 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 17-pole; gray Item no.: 232-150/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 20Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 5 mm; 20pole; gray www.wago.com/232-150 /005-000 Item no.: 232-150/005-000/039-000 www.wago.com/232-150 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 5 mm; 20-pole; gray Item no.: 232-232/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 2-pole; gray www.wago.com/232-232 /005-000 Item no.: 232-232/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Locking lever; Pin spacing 5 mm; 2-pole; gray www.wago.com/232-232 /005-000/039-000 Item no.: 232-233/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 3-pole; gray www.wago.com/232-233 /005-000 Item no.: 232-233/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Locking lever; Pin spacing 5 mm; 3-pole; gray www.wago.com/232-233 /005-000/039-000 Item no.: 232-234/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 4-pole; gray www.wago.com/232-234 /005-000 Item no.: 232-234/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Locking lever; Pin spacing 5 mm; 4-pole; gray www.wago.com/232-234 /005-000/039-000 Item no.: 232-235/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 5-pole; gray www.wago.com/232-235 /005-000 Item no.: 232-235/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Locking lever; Pin spacing 5 mm; 5-pole; gray www.wago.com/232-235 /005-000/039-000 Item no.: 232-236/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 6-pole; gray www.wago.com/232-236 /005-000 Item no.: 232-236/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Locking lever; Pin spacing 5 mm; 6-pole; gray www.wago.com/232-236 /005-000/039-000 Item no.: 232-237/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 7-pole; gray www.wago.com/232-237 /005-000 Item no.: 232-238/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 8-pole; Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/232-238 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 8-pole; gray www.wago.com/232-238 /005-000 Item no.: 232-239/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 9-pole; gray www.wago.com/232-239 /005-000 Item no.: 232-240/005-000 www.wago.com/232-240 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 10-pole; /005-000 gray Item no.: 232-240/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Locking lever; Pin spacing 5 mm; 10-pole; gray www.wago.com/232-240 /005-000/039-000 Item no.: 232-242/005-000 www.wago.com/232-242 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 12-pole; /005-000 gray Item no.: 232-242/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Locking lever; Pin spacing 5 mm; 12-pole; gray www.wago.com/232-242 /005-000/039-000 Item no.: 232-246/005-000 www.wago.com/232-246 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 16-pole; /005-000 gray Item no.: 232-246/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Locking lever; Pin spacing 5 mm; 16-pole; gray www.wago.com/232-246 /005-000/039-000 Item no.: 232-250/005-000 www.wago.com/232-250 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Pin spacing 5 mm; 20-pole; /005-000 gray Item no.: 232-250/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; Locking lever; Pin spacing 5 mm; 20-pole; gray www.wago.com/232-250 /005-000/039-000 Item no.: 232-732/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 7.5 mm; 2pole; gray www.wago.com/232-732 /005-000 Item no.: 232-733/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 7.5 mm; 3pole; gray www.wago.com/232-733 /005-000 Item no.: 232-734/005-000 THT female header; 0.6 x 1.0 mm solder pin; gray www.wago.com/232-734 /005-000 Item no.: 232-734/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing www.wago.com/232-734 7.5 mm; 4-pole; gray /005-000/039-000 Item no.: 232-735/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 7.5 mm; 5pole; gray www.wago.com/232-735 /005-000 Item no.: 232-735/005-000/039-000 www.wago.com/232-735 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 7.5 mm; 5-pole; gray Item no.: 232-736/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 7.5 mm; 6pole; gray www.wago.com/232-736 /005-000 Item no.: 232-736/005-000/039-000 www.wago.com/232-736 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Locking lever; Pin spacing /005-000/039-000 7.5 mm; 6-pole; gray Item no.: 232-738/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 7.5 mm; 8pole; gray www.wago.com/232-738 /005-000 Item no.: 232-740/005-000 THT female header; 0.6 x 1.0 mm solder pin; gray www.wago.com/232-740 /005-000 Item no.: 232-742/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; Pin spacing 7.5 mm; 12pole; gray www.wago.com/232-742 /005-000 Item no.: 232-832/005-000 THT female header; 0.6 x 1.0 mm solder pin; angled; Pin spacing 7.5 mm; 2-pole; gray www.wago.com/232-832 /005-000 Item no.: 232-833/005-000 THT female header; 0.6 x 1.0 mm solder pin; angled; Pin spacing 7.5 mm; 3-pole; gray www.wago.com/232-833 /005-000 Item no.: 232-834/005-000 THT female header; 0.6 x 1.0 mm solder pin; angled; Pin spacing 7.5 mm; 4-pole; gray www.wago.com/232-834 /005-000 Item no.: 232-836/005-000 THT female header; 0.6 x 1.0 mm solder pin; angled; Pin spacing 7.5 mm; 6-pole; gray www.wago.com/232-836 /005-000 Item no.: 232-836/005-000/039-000 THT female header; 0.6 x 1.0 mm solder pin; angled; Locking lever; Pin spacing 7.5 mm; 6-pole; gray www.wago.com/232-836 /005-000/039-000 Item no.: 232-840/005-000 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/232-840 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 8/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Item no.: 232-840/005-000 THT female header; 0.6 x 1.0 mm solder pin; angled; Pin spacing 7.5 mm; 10-pole; gray www.wago.com/232-840 /005-000 Item no.: 232-842/005-000 THT female header; 0.6 x 1.0 mm solder pin; angled; Pin spacing 7.5 mm; 12-pole; gray www.wago.com/232-842 /005-000 Item no.: 722-132/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 2-pole; light gray www.wago.com/722-132 /005-000 Item no.: 722-132/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 2-pole; light gray www.wago.com/722-132 /005-000/039-000 Item no.: 722-133/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 3-pole; light gray www.wago.com/722-133 /005-000 Item no.: 722-133/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 3-pole; light gray www.wago.com/722-133 /005-000/039-000 Item no.: 722-134/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 4-pole; light gray www.wago.com/722-134 /005-000 Item no.: 722-134/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 4-pole; light gray www.wago.com/722-134 /005-000/039-000 Item no.: 722-135/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 5-pole; light gray www.wago.com/722-135 /005-000 Item no.: 722-135/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 5-pole; light gray www.wago.com/722-135 /005-000/039-000 Item no.: 722-136/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 6-pole; light gray www.wago.com/722-136 /005-000 Item no.: 722-136/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 6-pole; light gray www.wago.com/722-136 /005-000/039-000 Item no.: 722-137/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 7-pole; light gray www.wago.com/722-137 /005-000 Item no.: 722-137/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 9/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 7-pole; light gray www.wago.com/722-137 /005-000/039-000 Item no.: 722-138/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 8-pole; light gray www.wago.com/722-138 /005-000 Item no.: 722-138/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 8-pole; light gray www.wago.com/722-138 /005-000/039-000 Item no.: 722-139/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 9-pole; light gray www.wago.com/722-139 /005-000 Item no.: 722-139/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 9-pole; light gray www.wago.com/722-139 /005-000/039-000 Item no.: 722-140/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 10-pole; light gray www.wago.com/722-140 /005-000 Item no.: 722-140/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 10-pole; light gray www.wago.com/722-140 /005-000/039-000 Item no.: 722-141/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 11-pole; light gray www.wago.com/722-141 /005-000 Item no.: 722-142/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 12-pole; light gray www.wago.com/722-142 /005-000 Item no.: 722-142/005-007/039-000 Female connector for rail-mount terminal blocks; gray www.wago.com/722-142 /005-007/039-000 Item no.: 722-143/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 13-pole; light gray www.wago.com/722-143 /005-000 Item no.: 722-144/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 14-pole; light gray www.wago.com/722-144 /005-000 Item no.: 722-144/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 14-pole; light gray www.wago.com/722-144 /005-000/039-000 Item no.: 722-145/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/722-145 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 10/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 15-pole; light gray www.wago.com/722-145 /005-000 Item no.: 722-146/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 16-pole; light gray www.wago.com/722-146 /005-000 Item no.: 722-146/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 16-pole; light gray www.wago.com/722-146 /005-000/039-000 Item no.: 722-150/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Pin spacing 5 mm; 20-pole; light gray www.wago.com/722-150 /005-000 Item no.: 722-150/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 20-pole; light gray www.wago.com/722-150 /005-000/039-000 Item no.: 722-232/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 2-pole; light gray www.wago.com/722-232 /005-000 Item no.: 722-232/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 2-pole; light gray www.wago.com/722-232 /005-000/039-000 Item no.: 722-233/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 3-pole; light gray www.wago.com/722-233 /005-000 Item no.: 722-233/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 3-pole; light gray www.wago.com/722-233 /005-000/039-000 Item no.: 722-234/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 4-pole; light gray www.wago.com/722-234 /005-000 Item no.: 722-234/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 4-pole; light gray www.wago.com/722-234 /005-000/039-000 Item no.: 722-235/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 5-pole; light gray www.wago.com/722-235 /005-000 Item no.: 722-235/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 5-pole; light gray www.wago.com/722-235 /005-000/039-000 Item no.: 722-236/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 11/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 6-pole; light gray www.wago.com/722-236 /005-000 Item no.: 722-236/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 6-pole; light gray www.wago.com/722-236 /005-000/039-000 Item no.: 722-237/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 7-pole; light gray www.wago.com/722-237 /005-000 Item no.: 722-237/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 7-pole; light gray www.wago.com/722-237 /005-000/039-000 Item no.: 722-238/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 8-pole; light gray www.wago.com/722-238 /005-000 Item no.: 722-239/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 9-pole; light gray www.wago.com/722-239 /005-000 Item no.: 722-239/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 9-pole; light gray www.wago.com/722-239 /005-000/039-000 Item no.: 722-240/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 10-pole; light gray www.wago.com/722-240 /005-000 Item no.: 722-240/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 10-pole; light gray www.wago.com/722-240 /005-000/039-000 Item no.: 722-241/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 11-pole; light gray www.wago.com/722-241 /005-000 Item no.: 722-242/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 12-pole; light gray www.wago.com/722-242 /005-000 Item no.: 722-242/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 12-pole; light gray www.wago.com/722-242 /005-000/039-000 Item no.: 722-243/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 13-pole; light gray www.wago.com/722-243 /005-000 Item no.: 722-244/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/722-244 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 12/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 14-pole; light gray www.wago.com/722-244 /005-000 Item no.: 722-244/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 14-pole; light gray www.wago.com/722-244 /005-000/039-000 Item no.: 722-246/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 16-pole; light gray www.wago.com/722-246 /005-000 Item no.: 722-246/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 16-pole; light gray www.wago.com/722-246 /005-000/039-000 Item no.: 722-250/005-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; angled; 100% protected against mismating; Pin spacing 5 mm; 20-pole; light gray www.wago.com/722-250 /005-000 Item no.: 210-103 Wire commoning chain; insulated; 50 connections; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; 50 connections www.wago.com/210-123 Item no.: 249-123 Push-in type wire jumper; insulated; wire length 180 mm; Conductor cross section 0.75 mm² www.wago.com/249-123 Item no.: 249-125 Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross section 0.75 mm² www.wago.com/249-125 Item no.: 249-126 Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 0.75 mm² www.wago.com/249-126 Item no.: 249-127 Push-in type wire jumper; insulated; wire length 250 mm; Conductor cross section 0.75 mm² www.wago.com/249-127 Item no.: 280-482 Comb-style jumper bar; insulated; 2-way; IN = IN terminal block; gray www.wago.com/280-482 Item no.: 280-483 Comb-style jumper bar; insulated; 3-way; IN = IN terminal block; gray www.wago.com/280-483 Item no.: 280-484 Comb-style jumper bar; insulated; 4-way; IN = IN terminal block; gray www.wago.com/280-484 Item no.: 280-485 Comb-style jumper bar; insulated; 5-way; IN = IN terminal block; gray www.wago.com/280-485 Item no.: 280-490 Comb-style jumper bar; insulated; 10-way; IN = IN terminal block; gray www.wago.com/280-490 Jumper Item no.: 280-492 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/280-492 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 13/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Item no.: 280-492 Alternate comb-style jumper bar; insulated; 2-way; IN = IN terminal block; gray www.wago.com/280-492 Item no.: 709-110 Wire commoning chain; insulated; 4 connections; 3 x 110 mm; black www.wago.com/709-110 Item no.: 709-111 Wire commoning chain; insulated; 3 connections; 2 x 120 mm; black www.wago.com/709-111 Item no.: 709-112 Wire commoning chain; insulated; 3 connections; 2 x 170 mm; black www.wago.com/709-112 Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short www.wago.com/210-657 Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft www.wago.com/210-720 Item no.: 249-141 L-type test plug module; modular; with spring-loaded contact pin; Center module; 1,50 mm²; gray www.wago.com/249-141 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-162 Steel carrier rail; 35 x 7.5 mm; slotted; 1 mm thick www.wago.com/210-162 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored www.wago.com/210-196 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 tools check Carrier rail Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; copperSubject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/210-198 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 14/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715 www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715 www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715 www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715 www.wago.com/210-508 Item no.: 209-192 Separator for Ex e/Ex i applications; 3 mm thick; 125.5 mm wide; orange www.wago.com/209-192 Item no.: 280-340 End and intermediate plate; 2.5 mm thick; gray www.wago.com/280-340 Item no.: 280-341 End and intermediate plate; 2.5 mm thick; orange www.wago.com/280-341 End plate General accessories Item no.: 231-162/003-000 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 2-pole; gray www.wago.com/231-162 /003-000 Item no.: 231-163/003-000 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 3-pole; gray www.wago.com/231-163 /003-000 Item no.: 231-164/003-000 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 4-pole; gray www.wago.com/231-164 /003-000 Item no.: 231-165/003-000 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 5-pole; gray www.wago.com/231-165 /003-000 Item no.: 231-166/003-000 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 6-pole; gray www.wago.com/231-166 /003-000 Item no.: 231-167/003-000 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 7-pole; gray www.wago.com/231-167 /003-000 Item no.: 231-168/003-000 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 8-pole; gray www.wago.com/231-168 /003-000 Item no.: 231-169/003-000 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 15/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Item no.: 231-169/003-000 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 9-pole; gray www.wago.com/231-169 /003-000 Item no.: 231-170/003-000 www.wago.com/231-170 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 10-pole; /003-000 gray Item no.: 231-171/003-000 www.wago.com/231-171 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 11-pole; /003-000 gray Item no.: 231-172/003-000 www.wago.com/231-172 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 12-pole; /003-000 gray Item no.: 231-176/003-000 www.wago.com/231-176 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 16-pole; /003-000 gray Item no.: 231-180/003-000 www.wago.com/231-180 Male connector for rail-mount terminal blocks; 1.2 x 1.2 mm pins; straight; Pin spacing 5 mm; 20-pole; /003-000 gray Item no.: 231-668 Lockout caps; for covering unused clamping units; gray www.wago.com/231-668 Item no.: 231-669 Lockout caps; for covering unused clamping units; orange www.wago.com/231-669 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-104 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 ferrule Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 16/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Item no.: 280-470 Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white www.wago.com/280-470 Item no.: 280-471 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/280-471 Item no.: 280-472 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip www.wago.com/280-472 Insulation stop Marking accessories Item no.: 2009-115 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 249-105 Group marker carrier www.wago.com/249-105 Item no.: 793-501 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 17/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- www.wago.com/793-5501 on type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-002 on type; yellow Item no.: 793-5501/000-005 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/793-5501 /000-005 Item no.: 793-5501/000-006 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/793-5501 /000-006 Item no.: 793-5501/000-007 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/793-5501 /000-007 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 18/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 Item no.: 793-5501/000-012 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/793-5501 /000-012 Item no.: 793-5501/000-017 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/793-5501 /000-017 Item no.: 793-5501/000-023 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/793-5501 /000-023 Item no.: 793-5501/000-024 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/793-5501 /000-024 Protective Warning Marker Item no.: 280-415 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/280-415 Item no.: 209-106 Mounting carrier; for isolated mounting on DIN 35 rails; gray www.wago.com/209-106 Item no.: 709-154 Cover; Type 2; suitable for cover carrier, type 2; 1 m long; transparent www.wago.com/709-154 assembling Downloads Documentation Bid Text 280-942/281-488 Feb 19, 2019 xml 3.3 kB Download Apr 27, 2017 doc 25.1 kB Download Apr 3, 2019 pdf 2.1 MB Download URL Download X81 - Datei 280-942/281-488 doc - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 280-942/281-488 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 19/20 Data sheet  |  Item number: 280-942/281-488 www.wago.com/280-942_281-488 CAE data EPLAN Data Portal 280-942/281-488 Download WSCAD Universe 280-942/281-488 Download Installation Notes Lamp test circuits can be created using the following terminal blocks: 280‑942/281‑487 or 280‑942/281‑488 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 20/20
280-942/281-488 价格&库存
很抱歉,暂时无法提供与“280-942/281-488”相匹配的价格&库存,您可以联系我们找货
