281-611
281-611
    WAGO(万可电子)
281-611 数据手册
FUSED DISCONNECT TERMINAL BLOCK WITHPIVOTABLE FUSE HOLDER for miniature metric fuses 5 x 20 mm WITHOUT BLOWN FUSE PDF Datasheet © 1992 - 2011 CADENAS GmbH FUSED DISCONNECT TERMINAL BLOCK WITHPIVOTABLE FUSE HOLDER for miniature metric fuses 5 x 20 mm WITHOUT BLOWN FUSE INDICATION 281-611 PDF Datasheet © 1992 - 2011 CADENAS GmbH ITEM-NO. (ITEM-NO.) 281-611 Cross section1 (Cross section / mm²) 0.08 - 4 Cross section2 (Cross section / AWG) 28 - 12 Strip length (Strip length / mm) 9 - 10 Measured voltage (Measured voltage / V) 800 Measured shock voltage (Measured shock voltage / kV) 8 Pollution degree (Pollution degree) 3 Current intensity (Current intensity / A) 10 Height (Height / mm) 60 Width (Width / mm) 8 Depth (Depth / mm) 60 No. of connection Points (No. of connection Points) 2 No. of potentials (No. of potentials) 2 COLOR (COLOR) grau WEIGHT (WEIGHT / g) 17.26 Comment (Comment) für G-Sicherungseinsatz 5 x 20 mm
281-611 价格&库存
很抱歉,暂时无法提供与“281-611”相匹配的价格&库存,您可以联系我们找货
