Data sheet from 28.06.2008
Item no.:
281-652
Product description:
4-CONDUCTOR THROUGH TERMINAL BLOCK; CENTRE
MARKING; for DIN 35 rail; FRONT-ENTRY; CAGE
CLAMP®CONNECTION; HORIZONTAL TYPE
Packing unit 50 pieces
RoHS compliant
Product group
1 (Rail Mounted Terminal Blocks)
Cross section from [mm²]
0,08 mm²
Cross section to [mm²]
4 mm²
Cross section from [AWG]
28 AWG
Cross section to [AWG]
12 AWG
Connection method
CAGE CLAMP®CONNECTION
Measured voltage EN
800 V
Measured shock voltage
8 kV
Pollution degree
3
Current intensity EN
26 A
Weight
12,948 g
Color
grey
Wiring type
Front-entry
No. of connection Points
4
No. of potentials
1
Height
29 mm
Height
1,14 in
Width
6 mm
Width
0,236 in
Depth
86 mm
Depth
3,39 in
Strip length from
9 mm
Strip length to
10 mm
Strip length
0,37 in
1 von 2
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
281-652
ABS
05-HG476175/1-PDA
800
26
4,0
281-652
BBJ
B/12/700/03
800
26
4,0
281-652
BV
07436/Co
800
26
4,0
281-652
CCA
NL5591/1
800
281-652
CSA
154112-1505034
600
25
28-12
281-652
CSM
017956
800
26
4,0
281-652
DEMKO
113344
800
281-652
Dep.MaE
CS4866N
600
25
4
281-652
DNV
E7570
800
32
4,0
281-652
GL
17295-00HH
800
32
4
281-652
KEMA
2076376.01
800
281-652
KR
HMB05880-EL001
500/800
10/35
4
281-652
LR
91/20112(E3)
800
26
4,0
281-652
LR
91/20112(E5)
800
26
4,0
281-652
NEMKO
L92062
800
281-652
PRS
TE/1219/880590/98
800
281-652
PRS
TE/1718/880590/08
800
281-652
RMR
11130002
800
26
4,0
281-652
RosTesT
B09523
800
26
4,0
281-652
UL
E45172
600
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
2 von 2
4
4
4
4
26
4,0
4
很抱歉,暂时无法提供与“281-652”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3+33.505283+4.00710
- 15+32.7627815+3.91830
- 40+32.2987240+3.86280
- 125+31.83465125+3.80730
- 300+30.90653300+3.69630
