281-681
    WAGO(万可电子)
    端子块连接器 3 位置 馈通式 灰色 12-28 AWG
281-681 数据手册
3-CONDUCTOR THROUGH TERMINAL BLOCK CENTRE MARKING for DIN 35 rail 281-681 PDF Datasheet © 1992 - 2011 CADENAS GmbH 3-CONDUCTOR THROUGH TERMINAL BLOCK CENTRE MARKING for DIN 35 rail 281-681 PDF Datasheet © 1992 - 2011 CADENAS GmbH ITEM-NO. (ITEM-NO.) 281-681 Cross section1 (Cross section / mm²) 0.08 - 4 Cross section2 (Cross section / AWG) 28 - 12 Strip length (Strip length / mm) 9 - 10 Measured voltage (Measured voltage / V) 800 Measured shock voltage (Measured shock voltage / kV) 8 Pollution degree (Pollution degree) 3 Current intensity (Current intensity / A) 32 Height (Height / mm) 29 Width (Width / mm) 6 Depth (Depth / mm) 73.5 No. of connection Points (No. of connection Points) 3 No. of potentials (No. of potentials) 1 COLOR (COLOR) grau WEIGHT (WEIGHT / g) 11.003 Comment (Comment)
281-681 价格&库存
很抱歉,暂时无法提供与“281-681”相匹配的价格&库存,您可以联系我们找货
    • 50+8.34770
    库存:952
    281-681
      • 1+7.00260
      • 50+6.30234
      库存:613
      281-681
      • 4+26.729974+3.19680
      • 20+26.1731020+3.13020
      • 50+25.8018550+3.08580
      • 125+25.52341125+3.05250
      • 300+24.78091300+2.96370
      库存:25
      281-681
      • 1+18.802461+2.24870
      • 5+14.078225+1.68370
      • 250+13.13338250+1.57070
      库存:52
      281-681
        • 50+6.59638
        库存:952
        281-681
          • 1+689.46816
          库存:50
          281-681
            • 1+61.84763
            • 5+28.92730
            • 9+28.74983
            • 19+27.15262
            库存:52
            281-681
              • 5+29.71485
              库存:490
