Printview: 2-conductor through terminal block - Item No.: 284-901
Item No.: 284-901
Marking
Business data
Supplier
WAGO
Item no.
284-901
GTIN / EAN
4044918305730
Content
1
Order amount
25
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
2
Total number of potentials
1
Color
gray
Ratings according to 1
IEC/EN 60947-7-1
Pollution degree (1)
3
Rated voltage EN (1) [V]
800 [V]
Rated surge voltage (1) [kV]
8 [kV]
Nominal current [A]
57 [A]
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
0.2 … 10 mm² / 24 … 8 AWG
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Fine-stranded wires 1
Strip length 1
12 … 13 mm / 0.47 … 0.51 in
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.348 [MJ]
Weight [g]
23.1 [g]
Width
10 mm / 0.394 in
Height from upper-edge of DIN-rail [mm]
35 [mm]
35 mm / 1.378 in
Length
78 mm / 3.071 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“284-901”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+96.872911+12.54843
- 10+68.7735910+8.90859
- 25+60.8086525+7.87685
- 50+55.9852550+7.25205
- 100+52.07676100+6.74577
- 250+48.09523250+6.23002
- 500+45.81447500+5.93458
- 1000+44.034211000+5.70397
