721-164/001-000
721-164/001-000
    WAGO(万可电子)
    插件,P=5mm
    THT 针型插座; 1.2 x 1.2 mm焊针; 直型; 100% 防插错保护; 焊针间距 5 mm; 4极; 浅灰色
721-164/001-000 数据手册
Data sheet  |  Item number: 721-164/001-000 THT male header; 1.2 x 1.2 mm solder pin; straight; 100% protected against mismating; Pin spacing 5 mm; 4-pole; light gray www.wago.com/721-164_001-000 Color: Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/7 Data sheet  |  Item number: 721-164/001-000 www.wago.com/721-164_001-000 L = (pole no. – 1) x pin spacing + 8.2 mm Item description Horizontal or vertical PCB mounting via straight or angled solder pins 1.2 x 1.2 mm solder pins allow nominal current up to 16 A, enhancing stability of horter headers 100 % protected against mismating With coding fingers Safety information 1: The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 250 V Rated impulse voltage (III / 3) 4 kV Rated voltage (III / 2) 320 V Rated impulse voltage (III / 2) 4 kV Rated voltage (II / 2) 630 V Rated impulse voltage (II / 2) 4 kV Rated current 16 A Legend (ratings) Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com (III / 2) ≙ Overvoltage category III / Pollution degree 2 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/7 Data sheet  |  Item number: 721-164/001-000 www.wago.com/721-164_001-000 Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per UL 1977 Rated voltage per UL 1977 (factory wiring only) 600 V Rated current per UL 1977 (factory wiring only) 15 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data No. of poles 4 Total number of potentials 4 Number of connection types 1 Number of levels 1 Geometrical Data Pin spacing 5 mm / 0.197 inch Width 23.2 mm / 0.913 inch Height 17 mm / 0.669 inch Height from the surface 12 mm / 0.472 inch Depth 11.4 mm / 0.449 inch Solder pin length 5 mm Solder pin dimensions 1.2 x 1.2 mm Drilled hole diameter (tolerance) 1.7(- … +0.1) mm Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/7 Data sheet  |  Item number: 721-164/001-000 www.wago.com/721-164_001-000 Plug connection Contact type (pluggable connector) Male connector/plug Connector connection type for PCBs Mismating protection Yes Mating direction to the PCB 90 ° PCB contact PCB contact THT Solder pin arrangement over the entire male connector, in line Number of solder pins per potential 1 Material Data Color light gray Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.029 MJ Weight 1.7 g Environmental Requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin PL GTIN 4044918932684 Customs Tariff No. 85366990990 Approvals / Certificates Country specific Approvals Logo Approval CB Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Additional Approval Text Certificate name IEC 61984 NL-39756 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/7 Data sheet  |  Item number: 721-164/001-000 www.wago.com/721-164_001-000 CB DEKRA Certification B.V. IEC 61984 NL-39756 CSA DEKRA Certification B.V. C22.2 1466354 KEMA/KEUR DEKRA Certification B.V. EN 61984 2190761.01 Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1869876PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z Ship Approvals Logo Certificate name UL-Approvals Logo Approval Additional Approval Text Certificate name UR UL International Germany GmbH UL 1977 E45171 Compatible products Coding Item no.: 231-129 Coding key; snap-on type; light gray www.wago.com/231-129 Marking accessories Item no.: 210-833 Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white www.wago.com/210-833 Item no.: 210-834 Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white www.wago.com/210-834 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/7 Data sheet  |  Item number: 721-164/001-000 www.wago.com/721-164_001-000 Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 721-164/001-000 CAE data EPLAN Data Portal 721-164/001-000 Download PCB Design Symbol and Footprint 721-164/001-000 URL Download CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/7 Data sheet  |  Item number: 721-164/001-000 www.wago.com/721-164_001-000 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Installation Notes Coding Coding a male header – fitting coding key(s). Product family MCS MIDI Show all products from the family Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/7
721-164/001-000 价格&库存
很抱歉,暂时无法提供与“721-164/001-000”相匹配的价格&库存,您可以联系我们找货
