733-204
733-204
    WAGO(万可电子)
    P=2.5mm
    接线端子 间距:2.50mm
733-204 数据手册
Data sheet  |  Item number: 733-204 1-conductor male connector; 100% protected against mismating; 0.5 mm²; Pin spacing 2.5 mm; 4-pole; 0,50 mm²; light gray www.wago.com/733-204 Color: 02.12.2019    Page 1/9 Data sheet  |  Item number: 733-204 www.wago.com/733-204 L = (pole no. + 1) x pin spacing Item description Universal connection for all conductor types Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation For wire-to-wire connections 100% protected against mismating Coding via coding fingers Safety information 1: The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 100 V Rated impulse voltage (III / 3) 2.5 kV Rated voltage (III / 2) 160 V Rated impulse voltage (III / 2) 2.5 kV Rated voltage (II / 2) 320 V Rated impulse voltage (II / 2) 2.5 kV Rated current 6  A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 02.12.2019    Page 2/9 Data sheet  |  Item number: 733-204 www.wago.com/733-204 Approvals per UL 1059 Rated voltage UL (Use Group B) 150 V Rated current UL (Use Group B) 4  A Approvals per CSA Rated voltage CSA (Use Group B) 150 V Rated current CSA (Use Group B) 4  A Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Solid conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 0.34 mm² Fine-stranded conductor with ferrule without plastic collar 0.25 … 0.34 mm² Strip length 5 … 6 mm / 0.2 … 0.24 inch No. of poles 4 Total number of connection points 4 Total number of potentials 4 Number of connection types 1 Number of levels 1 Conductor entry direction to mating direction 0  ° Geometrical Data Pin spacing 2.5 mm / 0.098 inch Width 12.5 mm / 0.492 inch Height 11.8 mm / 0.465 inch Depth 20.3 mm / 0.799 inch Plug connection Contact type (pluggable connector) Male connector/plug Connector connection type for conductors Mismating protection Yes Material Data Color light gray Material group I Insulating material Polyamide 66 (PA 66) Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) 02.12.2019    Page 3/9 Data sheet  |  Item number: 733-204 www.wago.com/733-204 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.043 MJ Weight 2.1 Environmental Requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin PL GTIN 4044918849548 Customs Tariff No. 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 61984 2169534.01 CCA DEKRA Certification B.V. IEC 61984 NL-31141 CSA DEKRA Certification B.V. C22.2 1465035 Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1869876PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z LR Lloyds Register IEC 61984 96/20035 (E5) Ship Approvals Logo Certificate name 02.12.2019    Page 4/9 Data sheet  |  Item number: 733-204 www.wago.com/733-204 UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1977 E45171 UR Underwriters Laboratories Inc. UL 1059 20190122E45172 Compatible products Coding Item no.: 733-330 Coding key; snap-on type; white www.wago.com/733-330 Item no.: 733-331 Coding key; snap-on type; black www.wago.com/733-331 Item no.: 210-251 Operating tool; for MCS MICRO & MINI with CAGE CLAMP® connection; yellow www.wago.com/210-251 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Item no.: 233-331 Operating tool; insulated; yellow www.wago.com/233-331 Item no.: 233-332 Operating tool; made of insulating material www.wago.com/233-332 Item no.: 233-335 Operating tool www.wago.com/233-335 Item no.: 733-130 Operating tool; loose; natural www.wago.com/733-130 Item no.: 733-191 Operating tool; loose; yellow www.wago.com/733-191 tools Strain relief plate Item no.: 734-127 02.12.2019    Page 5/9 Data sheet  |  Item number: 733-204 www.wago.com/733-204 Item no.: 734-127 Strain relief plate; light gray www.wago.com/734-127 Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-131 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 check ferrule Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 733-204 CAE data EPLAN Data Portal 733-204 Download Installation Notes Protected Against Mismating 02.12.2019    Page 6/9 Data sheet  |  Item number: 733-204 www.wago.com/733-204 Male headers and female connectors are 100 % protected against mismating. Only mating halves with the same pole number can be connected. Inserting a conductor Inserting a conductor via (2.5 x 0.4) mm screwdriver. Operation is performed perpendicular to conductor entry. Inserting a conductor via screwdriver (233335) – CAGE CLAMP® actuation parallel to conductor entry. Inserting a conductor via 733-191 Operating Lever. Inserting a conductor via 210-251 Operating Tool. Coding 02.12.2019    Page 7/9 Data sheet  |  Item number: 733-204 www.wago.com/733-204 Coding a male header – fitting coding key(s). Assembly Strain relief plates for factory or in-the-field assembly. Testing 02.12.2019    Page 8/9 Data sheet  |  Item number: 733-204 www.wago.com/733-204 Testing via 1 mm Ø test pin ( 735-500) – touch contact. Product family MCS MICRO Show all products from the family   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 02.12.2019    Page 9/9
733-204 价格&库存
很抱歉,暂时无法提供与“733-204”相匹配的价格&库存,您可以联系我们找货
  • 10+71.9558910+9.32686
  • 50+52.1909550+6.76494
  • 100+50.30754100+6.52082
  • 250+48.80001250+6.32541
  • 500+46.72705500+6.05672
库存:505
733-204
  • 1+20.41200
  • 10+17.01000
  • 30+14.88240
  • 100+12.70080
  • 500+11.71800
  • 1000+11.28600
  • 13+59.7425613+7.74378
  • 25+53.1679825+6.89159
  • 50+36.8854050+4.78105
  • 100+34.20307100+4.43337
  • 250+31.46422250+4.07836
  • 500+29.76039500+3.85752
  • 1000+28.383001000+3.67898
库存:200
733-204
  • 13+61.1510113+7.92634
  • 25+54.4220025+7.05413
  • 50+37.7555750+4.89384
  • 100+35.01025100+4.53800
  • 250+32.20662250+4.17459
  • 500+30.46254500+3.94853
  • 1000+29.053031000+3.76583
库存:200
