Data sheet from 26.01.2009
Item no.:
733-370
Product description:
HEADER; RIGHT ANGLE SOLDER PIN 0.8x0.8 MM; 10
POLE; PIN SPACING 2.5 MM / 0.098 IN; 100% PROTECTED
AGAINST MISMATING; MATING DIRECTION PARALLEL TO
PCB
Packing unit 100 pieces
Product group
3 (Multi Conn. System)
Pin spacing from
2,5 mm
Pin spacing from
0,098 in
pole count
10
Measured voltage EN
250 V
Measured shock voltage
2,5 kV
Pollution degree
2
Current intensity EN
4A
Weight
1,52 g
Color
light grey
Height
7,8 mm
Height
0,307 in
Width
27,5 mm
Width
1,083 in
Depth
8,9 mm
Depth
0,35 in
1 von 2
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
733-370
ABS
04-HG469925-PDA
250
4
733-370
BV
11915/A0
250
4
733-370
CCA
NL5640
250
4
733-370
CSA
154112-1465035
150
4
733-370
DNV
E-6997
250
4
733-370
GL
17296-00HH
250
4
733-370
KEMA
2077592.01
250
4
733-370
LR
96/20035
250
6
733-370
RMR
11130002
250
4
733-370
UR
E45171
250
4
733-370
UR
E45172
150
4
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
2 von 2
Cross section [ mm² ]
28-20
28-20
很抱歉,暂时无法提供与“733-370”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+35.202271+4.57002
- 10+22.4490910+2.91438
- 50+18.1689250+2.35872
- 100+17.03336100+2.21130
