4
250
Male Headers with Solder and Press-In Pins, MCS-MIDI
Pin Spacing: 3.5 mm, 3.81 mm
MCS MINI
Technical data:
Pin Spacing
Ratings per
Overvoltage category
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Use group UL 1059
Rated voltage
Nominal current UL
Nominal current CSA
3.5/3.81 mm
0.138 in.
IEC/EN 60664-1
III
III
II
3
2
2
160 V 160 V 320 V
2.5 kV 2.5 kV 2.5 kV
10 A
10 A
10 A
UL/CSA
B
C
D
300 V
300 V
10 A
10 A
10 A
10 A
ale headers may be mounted horizontally or vertically via straight or
M
angled solder pins
x 1 mm pin cross section (MCS MINI) allows a nominal current of
1
10 A
ouble-deck male headers save space on the PCB, providing a large
D
number of “wire-to-board” connections
100% protected against mismating
Coding pins available
Press-in technology:
Double-deck version:
3.5/3.81 mm
0.138 in.
IEC/EN 60664-1
III
III
II
3
2
2
160 V 160 V 320 V
8A
8A
8A
UL/CSA
B
C
D
300 V
300 V
10 A
10 A
10 A
10 A
3.5/3.81 mm
0.138 in.
IEC/EN 60664-1
III
III
II
3
2
2
160 V 160 V 320 V
10 A
10 A
10 A
UL/CSA
B
C
D
300 V
300 V
10 A
10 A
10 A
10 A
Solder and press-in pin data:
Solder pin: length/width
Solder pin: drilled hole diameter
4.5 mm / 1 x 1 mm (straight)
3.8 mm / 1 x 1 mm (angled)
3.6 mm / 1 x 1 mm (double-deck male headers)
1.4+0.1 mm
Press-in pin: length/width
Press-in pin: drilled hole diameter
Press-in pin: metal-plated hole
2.9 mm / 0.6 x 1.2 mm
1,15±0,025
1.0 Ø–0.06 mm (HAL Sn)
1.0 Ø–0.00 mm (Chem. Sn)
Derating Curve
734-102 female connector with 734-162 male header
Pin spacing: 3.5 mm / Conductor size: 1.5 mm2 “f-st”
Based on: EN 60512-5-2 / Reduction factor: 0.8
Current in A
10
5
40
50
60
70
80
90 100 105
Ambient operating temperature in °C
2-, 4-, 6-, 12-, 24-pole
Conductor rated current
For other pin lengths, please contact factory.
MCS MINI accessory:
Material data:
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL 94
V0
Lower/Upper limit temperature
-60 °C / +100 °C / Press-in pin: -40 °C / +85 °C
Contact material
Electrolytic copper (ECu) / Copper alloy for press-in technology
Contact plating
tin-plated
MCS connectors are also available upon request with gold-plated or partially gold-plated contact surfaces.
Depending on the version requested, “item no. suffix . . . /010-000” is added to the “basic item no.”
Coding keys
The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984.
When used as intended, these connectors shall not be connected/disconnected when live or under load. The circuit
design should ensure header pins, which can be touched, are not live when unmated.
Additional approvals and corresponding ratings can be found at www.wago.com.
For additional technical information, see Section 13.
Page:
273
很抱歉,暂时无法提供与“734-165”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.24040
- 10+6.69600
- 30+5.85360
- 200+4.90320
- 400+4.47120
- 1000+4.27680
