750-352
    WAGO(万可电子)
750-352 数据手册
750-352 10/100 Mbit/s; digital and analog signals Marking area 1 0: WBM 255: DHCP Supply 24 V 0V W ON ETHERNET 24V X3 0V Fieldbus connection RJ-45 Fieldbus connection RJ-45 LINK 1 ACT LINK 2 ACT MS NS I/O Status indication -Fieldbus -Fieldbus node Data contacts 750-352 8 Address ON 144 ETHERNET Fieldbus Coupler 1 2 3 4 5 6 7 8 4 X1 Configuration and programming interface (with cover open) X2 The 750-352 ETHERNET Fieldbus Coupler connects ETHERNET to the modular WAGO-I/O-SYSTEM. The DIP switch configures the last byte of the IP address and may be used for IP address assignment (DHCP, BootP, static). The fieldbus coupler automatically configures, creating a local process image which may include analog, digital or specialty modules. Analog and specialty module data is sent via words and/or bytes; digital data is sent bit by bit. The coupler is designed for fieldbus communication in both Ethernet/IP and MODBUS networks. It also supports a wide variety of standard ETHERNET protocols (e.g., HTTP, BootP, DHCP, DNS, SNMP, FTP). An integrated Web server provides configuration and status information to the coupler. Two ETHERNET interfaces and an integrated switch allow the fieldbus to be wired in a line topology. This eliminates additional network devices such as switches or hubs. Both interfaces support Auto-Negotiation and Auto-MDI(X). The coupler has an integrated supply terminal for the system voltage. The field power jumper contacts are supplied via a separate supply module. Description Item No. Pack. Unit System Data ETHERNET Coupler 750-352 1 No. of couplers connected to Master Transmission medium Baud rate Transmission performance Buscoupler connection Protocols Accessories Item No. Miniature WSB Quick marking system plain with marking 248-501 see Section 11 Pack. Unit limited by ETHERNET specification Twisted Pair S-UTP 100 Ω, Cat 5; Max. line length: 100 m 10/100 Mbit/s Class D acc. to EN 50173 2 x RJ-45 EtherNet/IP, MODBUS/TCP (UDP), HTTP, BootP, DHCP, DNS, FTP, SNMP 5 Approvals Conformity marking Korea Certification Marine applications r UL 508 r ANSI/ISA 12.12.01 4 TÜV 07 ATEX 554086 X IECEx TUN 09.0001 X WAGO Kontakttechnik GmbH & Co. KG Subject to design changes 1 ABS, BV, DNV, GL, KR, LR, NKK, PRS, RINA Class I, Div. 2, Grp. ABCD, T4 I M2 Ex d I Mb, II 3 G Ex nA IIC T4 Gc, II 3 D Ex tc IIIC T135°C Dc Ex d I Mb, Ex nA IIC T4 Gc, Ex tc IIIC T135°C Dc 26.01.2016 Postfach 2880 - D-32385 Minden Hansastr. 27 - D-32423 Minden Tel.: +49(0)571/887-0 E-Mail: info@wago.com Fax: +49(0)571/887-169 www.wago.com 4 145 24 V 24 V 0V 10 nF DC I/O modules DC ELECTRONICS FIELDBUS INTERFACE ELECTRONICS FIELDBUS INTERFACE 0V 10 nF 750-352 Technical Data Number of I/O modules with bus extension Max. input process image Max. output process image Configuration Power supply Input current typ. at rated load (24 V) Efficiency of the power supply (typ.) at nominal load (24 V) Internal current consumption (5 V) Total current for I/O modules (5 V) Isolation General Specifications 64 250 1020 words 1020 words via PC 24 V DC (-25 % ... +30 %) 280 mA 90 % 450 mA 700 mA 500 V system/supply Operating temperature Wire connection Cross sections Strip lengths Dimensions (mm) W x H x L Weight Storage temperature Relative air humidity (no condensation) Vibration resistance Shock resistance Degree of protection EMC immunity of interference EMC emission of interference 0 °C ... +55 °C CAGE CLAMP® 0.08 mm² ... 1.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in 50 x 65 x 97 Height from upper-edge of DIN 35 rail 112 g -25 °C ... +85 °C 95 % acc. to IEC 60068-2-6 acc. to IEC 60068-2-27 IP20 acc. to EN 61000-6-2, marine applications acc. to EN 61000-6-3, marine applications 4.1
750-352 价格&库存
很抱歉,暂时无法提供与“750-352”相匹配的价格&库存,您可以联系我们找货
