750-406
750-406
    WAGO(万可电子)
750-406 数据手册
750-406 / 753-406 4 212 2-Channel Digital Input Module 120 V AC 2- to 4-conductor connection; high-side switching 13 14 A Status DI 1 Status DI 2 C B D 13 14 Data contacts 1 DI 1 L 5 DI 1 DI 2 DI 2 DI 100nF L + — 2 DI 6 120 V 120 V 120 V U N N 3 7 N N N 4 8 750-406 750-406 Power jumper contacts Fig. 750 Series Delivered without miniature WSB markers The digital input module receives control signal from the digital field devices (sensors, etc.). Field and system levels are electrically isolated. Notice: An additional supply module must be added for operation with 120VAC! Description Item No. Pack. Unit Technical Data 2DI 120V AC 2DI 120V AC (without connector) 750-406 753-406 1 1 Number of inputs Current consumption (internal) Voltage via power jumper contacts Accessories 753 Series Connectors Coding elements Item No. Pack. Unit 753-110 753-150 25 100 Miniature WSB Quick marking system plain 248-501 with marking see Section 11 5 Approvals Conformity marking Korea Certification Marine applications r UL 508 r ANSI/ISA 12.12.01 4 TÜV 07 ATEX 554086 X IECEx TUN 09.0001 X WAGO Kontakttechnik GmbH & Co. KG Subject to design changes 1 ABS, BV, DNV, GL, KR, LR, NKK, PRS, RINA Signal voltage (0) Signal voltage (1) Input filter Input current (typ.) Input frequency Isolation Internal bit width Wire connection Cross sections Strip lengths, 750/753 Series Width Weight EMC immunity of interference EMC emission of interference 2 2 mA 230 V AC (-15 % ... +20 %); (± 20 % 1.5 s) 0 V ... 20 V AC 79 V AC ... 1.1 VN 10 ms 4.5 mA f (nominal) ± 10 % 50 Hz ± 10 % 60 Hz ± 10 % 1.5 kV eff. (field/system)*; * 2.5 kV rated surge voltage 2 bits CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 8 ... 9 mm / 0.33 in 9 ... 10 mm / 0.37 in 12 mm 48.5 g acc. to EN 61000-6-2, marine applications acc. to EN 61000-6-4, marine applications Class I, Div. 2, Grp. ABCD, T4 I M2 Ex d I Mb, II 3 G Ex nA IIC T4 Gc, II 3 D Ex tc IIIC T135°C Dc Ex d I Mb, Ex nA IIC T4 Gc, Ex tc IIIC T135°C Dc 26.01.2016 Postfach 2880 - D-32385 Minden Hansastr. 27 - D-32423 Minden Tel.: +49(0)571/887-0 E-Mail: info@wago.com Fax: +49(0)571/887-169 www.wago.com
750-406 价格&库存
很抱歉,暂时无法提供与“750-406”相匹配的价格&库存,您可以联系我们找货
    • 1+1127.01669
    库存:2
    750-406
      • 1+1414.173221+183.53387
      • 10+1173.6062310+152.31267
      • 25+1097.0898625+142.38224
      • 50+1046.4790250+135.81388
      库存:1
      750-406
        • 1+1120.755451+145.45360
        • 4+960.722164+124.68420
        • 16+917.0133916+119.01160
        • 39+877.1356839+113.83620
        库存:70
        750-406
          • 2+704.37343
          • 4+670.79672
          • 16+640.32739
          • 39+612.42136
          库存:70
