787-722
Switched-Mode Power Supply, 1-Phase
EPSITRON® ECO Power
L
DC+
DC+
DC DC -
N
Primary switch mode power supply unit
Prepared for class I equipment
Natural convection cooling when horizontally mounted
Enclosed for use in switchgear cabinets
Parallel operation, series connection possible
Electrically isolated output voltage (SELV) acc. to EN 60950-1/UL 60950
Technical Data
Input:
Nominal input voltage Vi nom
Input voltage range
Frequency
Input current Ii
Discharge current
Inrush current
Mains failure hold-up time
Output:
Nominal output voltage Vo nom
Output voltage range
Output current Io
Factory preset
Adjustment accuracy
Residual ripple
Overload behavior
Operational indication
Efficiency / power losses:
Efficiency
Power loss PV
Max. power loss PV
Fuse protection:
Internal fuse
External fuse
WAGO Kontakttechnik GmbH & Co. KG
Subject to design changes
Description
Item No.
Pack.
Unit
24 VDC / 5 A
787-722
1
Technical Data
110 ... 240 VAC
85 ... 264 VAC; 90 ... 373 VDC
47 ... 63 Hz
1.0 A typ. at 230 VAC;
2.0 A at 115 VAC
< 3.5mA
< 30 A at AC 230 V; < 25 A at AC 115 V
> 20 ms at 230 VAC
24 VDC (SELV)
22 ... 28 VDC adjustable
5 A at 24 V DC
24 VDC
1%
< 100 mV (peak-to-peak)
Constant power (in overload range:
1.15 ... 1.4 x Ia); shutdown and automatic
restart in the event of a short circuit
LED green (24 V DC o.k.),
LED red (overload)
82 % typ. (110 VAC); 86 % typ. (230 VAC)
19.5 W (at 230 VAC and 5 ADC)
23.5 W (at 110 VAC and 5.5 ADC)
F 3.15 A / 250 V
Circuit breakers 10 A, 16 A,
characteristic: B or C
An external DC fuse is required for the DC
input voltage
06.01.2017
Environmental requirements:
Ambient operating temperature
Storage temperature
Rel. humidity
Derating
Degree of pollution
Climatic category
Safety and protection:
Test voltage pri.-sec./ pri.-gr. / sec.-gr.
Protection class
Degree of protection
Overvoltage protection
Short circuit protection
No-load proof
Feedback voltage
Parallel operation
Series connection
MTBF
Connection and type of mounting:
Wire connection
Cross sections
Strip lengths
Type of mounting
Dimensions and weight:
Dimensions (mm) W x H x L
Weight
Standards and approvals:
Standards/Specifications
Postfach 2880 - D-32385 Minden
Hansastr. 27 - D-32423 Minden
-10 °C ... +60 °C
-25 °C ... +85 °C
95 % (no condensation)
-5.33 % / K (> 45 °C at 230 VAC)
2 (acc. to EN 50178)
3K3 (acc. to EN 60721)
3 kV AC / 1.5 kV AC / 0.5 kV AC
IP20 acc. to EN 60529
via varistor at primary circuit
yes
yes
28 VDC
yes
yes
480000 h (acc. IEC 61709)
CAGE CLAMP® (WAGO 745 Series)
0.08 mm² ... 4 mm² / AWG 28 ... 12
(THHN, THWN)
8 ... 9 mm / 0.33 in
DIN-rail mount (EN 60715)
75 x 92 x 136
Height from upper-edge of DIN 35 rail
850 g
EN 60950, EN 61204-3,
Y 60950, r 508,
ANSI/ISA 12.12.01 (Class I Div.2),
ATEX, IEC Ex
Tel.: +49(0)571/887-0
E-Mail: info@wago.com
Fax: +49(0)571/887-169
www.wago.com
很抱歉,暂时无法提供与“787-722”相匹配的价格&库存,您可以联系我们找货
