Data sheet | Item number: 862-1503
4-conductor chassis-mount terminal strip; 3-pole; PE-N-L1; without ground
contact; for 3 mm ø screw and nut; 4 mm²; 4,00 mm²; black
www.wago.com/862-1503
Dimensions (in mm) for chassis-mount terminal strips
Color:
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
500 V
Rated impulse voltage (III / 3)
6 kV
Rated current
32 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Push-button
Connectable conductor materials
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Copper
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/8
Copper
Solid conductor
0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination
0.75 … 4 mm² / 18 … 12 AWG
Stranded conductor
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.5 … 2.5 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from
0.75 mm² / 18 AWG
Strip length
10 … 11 mm / 0.39 … 0.43 inch
No. of poles
3
Total number of connection points
12
Total number of potentials
3
Type of wiring
Side-entry wiring
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross section can also be inserted via push-in termination.
Geometrical Data
Pin spacing
12 mm / 0.472 inch
Width
36 mm / 1.417 inch
Height from the surface
22.3 mm / 0.878 inch
Depth
35 mm / 1.378 inch
Mechanical data
Mounting type
Screw mounting
Marking
PE-N-L1
Material Data
Color
black
Fire load
0.383 MJ
Weight
20.5 g
Commercial data
Packaging type
bag
Country of origin
DE
GTIN
4044918509473
Customs Tariff No.
85369010000
Approvals / Certificates
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/8
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL
6912
CCA
EN 60947
2146425.01
CSA
C22.2 No. 158
1505030
ENEC 15
UL International Germany GmbH
EN 60998
143856-01
Approval
Certificate
name
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
Ship Approvals
Logo
UL-Approvals
Logo
Approval
UL
UL 1059
Certificate
name
E45172
sec. 39
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/8
Compatible products
tools
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft
www.wago.com/210-720
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-141
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-142
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-144
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
ferrule
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Item no.: 210-137
Test plug; 2.3 mm Ø; with 500 mm cable; yellow
www.wago.com/210-137
Item no.: 862-482
Comb-style jumper bar; for conductor entry; insulated; terminated conductor entry; black
www.wago.com/862-482
check
Jumper
Marking accessories
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/8
Marking accessories
Item no.: 709-177
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent
www.wago.com/709-177
Item no.: 709-178
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white
www.wago.com/709-178
Downloads
Documentation
Bid Text
862-1503
Feb 19, 2019
xml
3.8 kB
Download
Jun 12, 2017
doc
25.1 kB
Download
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
X81 - Datei
862-1503
doc - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 862-1503
CAE data
EPLAN Data Portal 862-1503
Download
WSCAD Universe 862-1503
Download
Installation Notes
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/8
Cost-effective features:
WAGO’s 862 Series Chassis-Mount Terminal
Strips were developed specifically to
minimize wiring costs, while accommodating
requirements for flexible mounting, multiple
connection points and easy handling:
Equipped with Push-in CAGE
CLAMP®, the 862 Series connects
up to four conductors sized 0.5 …
4 mm² (20 … 12 AWG). Due to
multiple connection points per pole,
different conductor sizes can be
used within the same terminal block
position.
For factory wiring, Push-in CAGE
CLAMP® Connection Technology
allows solid conductors, finestranded conductors with ferrules or
ultrasonically bonded conductors
from 0.5 … 4 mm² (20 … 12 AWG) to
be terminated by simply pushing
them into unit (length of bonded
conductor end: min. 10 mm).
Convenient automatic grounding
contact optional Snap-in mounting
feet for fast assembly
Push-buttons for easy installation
with an operating tool or by hand
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/8
Built-in test points simplify testing
with 2 mm Ø test plug.
Flexible marking options with
standard marking (pre-marked),
marking strip or custom marked for
large orders
Terminating four conductors per pole – solid
and fine-stranded.
Inserting a conductor via push-button.
Commoning using a comb-style jumper bar
(862‑482).
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/8
Testing with a 2 mm Ø test plug.
Dimensions in mm
Marking by direct, one-side printing and/or
marker strips
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/8
很抱歉,暂时无法提供与“862-1503”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+38.526601+4.94181
- 10+27.3895710+3.51327
- 25+23.9719625+3.07489
- 50+21.8390050+2.80129
- 100+20.07464100+2.57498
- 250+18.24204250+2.33991
- 500+17.17650500+2.20323
- 1000+16.336091000+2.09544
- 5000+15.031355000+1.92808
