852-1305
852-1305
    WAGO(万可电子)
    WAGO - 852-1305 - ETHERNET SW, RJ45 X 8/SFP X 4, DIN RAIL
852-1305 数据手册
Data sheet  |  Item number: 852-1305 Industrial-Managed-Switch; 8-Port 1000BASE-T; 4-Slot 1000BASE-SX/LX; metallic black www.wago.com/852-1305 Color: 06.11.2019    Page 1/8 Data sheet  |  Item number: 852-1305 www.wago.com/852-1305 Item description The 852‐1305 Industrial Managed Switch is an 8-port 10/100/1000Base‐TX and 4-port SFP-100Base‐SX/LX configurable ETHERNET switch (SFP modules are optional). The switch has a rugged housing, redundant power supply and function monitoring with a relay. These functions, along with extensive ETHERNET switch options, make it ideal for a wide range of applications. Features: Web-based/SNMP Management Redundant DC power supply Wide supply voltage range: 12 ... 60 VDC DIP switches to set alarm functions Full compliance with IEEE802.3, 802.3u, 802.3z, 802.3x, 802.3ad, 802.3ab, 802.1d, 802.1q, 802.1p, 802.1w, 802.1x standards Xpress Ring (redundant ring, recovery < 50 ms) Non‐blocking, store‐and‐forward switching, rapid spanning tree protocol (RSTP) Autonegotiation at all 10/100/1000Base-T ports Auto‐MDI/MDIX (crossover) at all 10/100/1000Base‐T ports VLAN (802.1q) VID IGMP snooping for multicast filtering Port configuration, status, statistics 06.11.2019    Page 2/8 Data sheet  |  Item number: 852-1305 www.wago.com/852-1305 Port configuration, status, statistics Port trunking SNMP v1/v2 and RMON Data Technical Data Switchingmodus Store‐and‐forward, non-blocking Number of 1000Base-T ports 8 Number of 1000Base SX/LX ports 4 Communication standards IEEE 802.3 10BASE-T IEEE 802.3u 100BASE-TX IEEE 802.3ab 1000BASE-T IEEE 802.3z 1000BASE-SX/LX IEEE 802.3x Flow Control IEEE 802.1w Rapid Spanning Tree Protocol (RSTP) IEEE 802.1q VLAN Tagging IEEE 802.1ab Link Layer Discovery Protocol (LLDP) IEEE 802.1p Prioritization IEEE 802.1x Port Authentication ITU-T G8032v1/v2 Ethernet Ring Protection Switching (ERPS) Redundancy function Redundant DC power supply, STP, RSTP, MSTP, Jetring < 300 ms, XPRESS ring < 20 ms, Dual homing < 20 ms, Dual ring, ERPSv2 < 50 ms, LCAP Configuration options DIP switch for signal contact Command Line Interface SNMPv1/v2c/v3 Diagnostics Signal contact, Modbus/TCP, port status, port statistics, port load, traffic monitor, SFP information, syslog, mail alarm, SNMP traps MAC table (large) 16000 addresses Jumbo frame size 10000 Byte Supply voltage DC 12 … 60 V; Leitungslänge < 3 m Energy consumption max. 18 W ESD (contact/air discharge) 8 KV / 15 KV Baud rate Copper cable: 10/1000 Mbit/s; Fiber optic:1000 Mbit/s Transmission medium (communication/fieldbus) Copper cable: Cat. 5 or higher, max. line length: 100 m; Fiber optic: SX Multi-Mode, LX Single-Mode LWL-Fasertyp Single-Mode and Multi-Mode VLANs Port-based and tag-based (4k VIDs) Panel 14 x DIP switch: Alarm function power supplies and ports 1 … 12; 1 x Reset button: restart of the system Indicators Device: LED (PWR, RPS, POST) green: power supply (primary), redundant power supply (secondary), POST function; LED (ALM) red: Alarm; LED (SFP) green, Status fiber optic ports; per port: LED (100, LNK/ACT) green: Status 100 Mbps, LNK/ACT Port 1 … 8 Connection data 06.11.2019    Page 3/8 Data sheet  |  Item number: 852-1305 www.wago.com/852-1305 Connection data Connection technology: communication/fieldbus Copper cable: 8 x RJ-45; Fiber optic: 4 x SFP, LC fiber-optic connectors Anschlusstechnik: Versorgung 1 x im Gerät verbaute Stiftleiste: 231-436/001-000; mitgelieferte Federleiste (Steckverbinder MCS): 2231-106/026-000 Geometrical Data Width 50 mm / 1.969 inch Height from upper-edge of DIN-35 rail 120 mm / 4.724 inch Depth 162 mm / 6.378 inch Mechanical data Weight 910 Color metallic black Housing material Aluminum Conformity marking CE Environmental Requirements Surrounding air (operating) temperature -40 … 70 °C Surrounding air (storage) temperature -40 … 80 °C Protection class IP30 Relative air humidity (no condensation) 95 % Type of mounting DIN-35 rail Vibration resistance acc. to IEC 60068-2-6 Shock resistance acc. to IEC 60068-2-27 EMC immunity to interference acc. to EN 61000-6-2 EMC emission of interference acc. to EN 61000-6-4 Commercial data Packaging type BOX Country of origin TW GTIN 4055143327169 Customs Tariff No. 85176200000 Compatible products power supply Item no.: 787-1602 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 1 A output current; NEC Class www.wago.com/787-1602 06.11.2019    Page 4/8 Data sheet  |  Item number: 852-1305 www.wago.com/852-1305 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 1 A output current; NEC Class www.wago.com/787-1602 2; DC OK signal Item no.: 787-1606 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 2 A output current; NEC Class www.wago.com/787-1606 2; DC OK signal Item no.: 787-1622 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 5 A output current; TopBoost; www.wago.com/787-1622 DC OK contact Item no.: 787-1623 Switched-mode power supply; Classic; 1-phase; 48 VDC output voltage; 2 A output current; DC OK signal www.wago.com/787-1623 Item no.: 787-1632 Switched-mode power supply; Classic; 1-phase; 24 VDC output voltage; 10 A output current; TopBoost; DC OK contact www.wago.com/787-1632 Item no.: 787-1633 Switched-mode power supply; Classic; 1-phase; 48 VDC output voltage; 5 A output current; TopBoost; www.wago.com/787-1633 DC OK contact Item no.: 787-1635 Switched-mode power supply; Classic; 1-phase; 48 VDC output voltage; 10 A output current; TopBoost; DC OK contact www.wago.com/787-1635 General accessories Item no.: 852-1200 SFP Module 1000BASE; SX Multi-Mode 850 nm LC; 0.55 km; Extended temperature range; DDM; silver- www.wago.com/852-1200 colored Item no.: 852-1210 SFP Module 1000BASE; LX Single-Mode 1310 nm LC; 10 km; Extended temperature range; DDM; silver- www.wago.com/852-1210 colored Item no.: 852-1280 SFP Module 1000BASE; ZX Single-Mode 1550 nm LC; 80 km; Extended temperature range; DDM; silver- www.wago.com/852-1280 colored transfer module Item no.: 289-172 Interface module; RJ-45; RJ-45; Cat. 5; in mounting carrier www.wago.com/289-172 Item no.: 289-175 Interface module; RJ-45; PCB terminal blocks, double-row; Cat. 5; in mounting carrier; with shield connection; with shield clamping saddle; 1,50 mm² www.wago.com/289-175 Item no.: 289-195 Interface module; RJ-45; IDC technology; Cat. 6; in mounting carrier; with shield connection www.wago.com/289-195 Item no.: 289-196 Interface module; RJ-45; with power jumper contacts; PCB terminal blocks; Cat. 5 www.wago.com/289-196 wiring and connectors Item no.: 750-975 ETHERNET RJ-45 connector, IP20; ETHERNET 10/100 Mbit/s; for field assembly; light gray www.wago.com/750-975 Item no.: 750-976 PROFINET RJ-45 connector, IP20; ETHERNET 10/100 Mbit/s; for field assembly www.wago.com/750-976 Item no.: 750-977/000-011 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22 www.wago.com/750-977 /000-011 06.11.2019    Page 5/8 Data sheet  |  Item number: 852-1305 www.wago.com/852-1305 Item no.: 750-977/000-012 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22 www.wago.com/750-977 /000-012 Item no.: 750-977/000-013 Connector PROFINET; RJ-45; Cat. 6A; straight; AWG 22 www.wago.com/750-977 /000-013 Item no.: 750-977/000-021 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24 www.wago.com/750-977 /000-021 Item no.: 750-977/000-022 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24 www.wago.com/750-977 /000-022 Item no.: 750-978/000-011 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22; Strain relief www.wago.com/750-978 /000-011 Item no.: 750-978/000-012 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22; Strain relief www.wago.com/750-978 /000-012 Item no.: 750-978/000-013 Connector PROFINET; RJ-45; Cat. 6A; straight; AWG 22; Strain relief www.wago.com/750-978 /000-013 Item no.: 750-978/000-021 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24; Strain relief www.wago.com/750-978 /000-021 Item no.: 750-978/000-022 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24; Strain relief www.wago.com/750-978 /000-022 Item no.: 750-979/000-011 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 22; Strain relief www.wago.com/750-979 /000-011 Item no.: 750-979/000-012 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 22; Strain relief www.wago.com/750-979 /000-012 Item no.: 750-979/000-013 Connector PROFINET; RJ-45; Cat. 6A; angled; AWG 22; Strain relief www.wago.com/750-979 /000-013 Item no.: 750-979/000-021 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 24; Strain relief www.wago.com/750-979 /000-021 Item no.: 750-979/000-022 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 24; Strain relief www.wago.com/750-979 /000-022 Downloads 06.11.2019    Page 6/8 Data sheet  |  Item number: 852-1305 www.wago.com/852-1305 Downloads Documentation Manual 8-Port 1000BASE-T + 4-Slot 1000BASE-SX/LX Industrial Switch V 1.2.0 pdf 5.7 MB Download V 1.0.0 pdf 265.8 kB Download pdf 2.0 MB Download zip 9.9 MB Download Additional Information Disposal; Electrical and electronic equipment, Packaging System Description Industrial Switches ‒ General Product Information Runtime Software Firmware Firmware: 852-1305 Industrial-Managed-Switch; 8-Port 1000BASE-T; 4-Slot 1000BASE-SX/LX; metallic black 06 07-Jun-2019 CAD/CAE-Data CAE data EPLAN Data Portal 852-1305 Download WSCAD Universe 852-1305 Download Device Files Device Description File MIB File for 852-1305 Managed Switch 27-Mar-2017 MIB 21.9 kB Download MIB File for 852 Managed Switch 22-Jul-2016 MIB 15.7 kB Download 06.11.2019    Page 7/8 Data sheet  |  Item number: 852-1305 www.wago.com/852-1305 Installation Notes   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 06.11.2019    Page 8/8
852-1305 价格&库存
很抱歉,暂时无法提供与“852-1305”相匹配的价格&库存,您可以联系我们找货
  • 1+10910.553651+1415.99072
