2061-903
2061-903
    WAGO(万可电子)
    Board-to-Board Link
2061-903 数据手册
Data sheet  |  Item number: 2061-903 Board-to-Board Link; Pin spacing 6 mm; 3-pole; Length: 30 mm; white www.wago.com/2061-903 Color: Item description Verbindungselement zum vereinfachten Aneinanderreihen von LED-Platinen Einfache Handhabung durch direktes Stecken und Trennen ohne Drückerbetätigung Data Electrical data 05.09.2019    Page 1/4 Data sheet  |  Item number: 2061-903 www.wago.com/2061-903 Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 250 V Rated impulse voltage (III / 3) 4 kV Rated voltage (III / 2) 320 V Rated impulse voltage (III / 2) 4 kV Rated voltage (II / 2) 630 V Rated impulse voltage (II / 2) 4 kV Rated current 9  A Connection data Total number of potentials 3 Number of connection types 1 No. of poles 3 Geometrical Data Pin spacing 6 mm / 0.236 inch Width 17.7 mm / 0.697 inch Height 2.5 mm / 0.098 inch Depth 30 mm / 1.181 inch Mechanical data Mating cycles 10 Number of mating cycles max. 10 mating cycles Material Data Color white Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Copper alloy Contact plating silver-plated Weight 0.85 g Environmental Requirements Limit temperature range -60 … +105 °C 05.09.2019    Page 2/4 Data sheet  |  Item number: 2061-903 www.wago.com/2061-903 Commercial data Country of origin CN GTIN 4055143656801 Customs Tariff No. 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947-7-4 NTR NL7459 CCA DEKRA Certification B.V. EN 60838 NTR NL7721 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71100855 KEMA/KEUR DEKRA Certification B.V. EN 60838 71106232 Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 3D Download 2061-903 05.09.2019    Page 3/4 Data sheet  |  Item number: 2061-903 www.wago.com/2061-903 3D Download 2061-903 URL Download   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.09.2019    Page 4/4
2061-903 价格&库存
很抱歉,暂时无法提供与“2061-903”相匹配的价格&库存,您可以联系我们找货
  • 1+12.860031+1.66858
    • 164+5.57396
    库存:385
    2061-903
      库存:385
      2061-903
        • 204+3.86685204+0.50172
        • 1020+3.466231020+0.44974
        库存:385
