209-602
209-602
    WAGO(万可电子)
    连接器 标签,卡入式 用于 5mm 宽接线板
209-602 数据手册
Printview: WSB quick marking system; Vertical marking; 1 ... 10 (10x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip - Item No.: 209-602 . WSB quick marking system; Vertical marking; 1 ... 10 (10x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip Item No.: 209-602 . WSB quick marking system; Vertical marking; 1 ... 10 (10x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip . Marking . Business data Supplier WAGO Item no. 209-602 GTIN / EAN 4017332273381 Content 1 Order amount 5 Customer item number . Notes Technical data Miscellaneous Color white Fire load [MJ] 0.234 [MJ] Weight [g] 7.8 [g] Marking 1-10 (10x) Printing direction Vertical marking Marker width [mm] 5 [mm] Marker width (max.) [mm] 17.5 [mm] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: WSB quick marking system; Vertical marking; 1 ... 10 (10x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip - Item No.: 209-602 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 2 Printview: WSB quick marking system; Vertical marking; 1 ... 10 (10x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip - Item No.: 209-602 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 3
209-602 价格&库存
很抱歉,暂时无法提供与“209-602”相匹配的价格&库存,您可以联系我们找货
    • 1+58.365301+7.30380
    • 5+57.566995+7.20390
    • 25+56.8573925+7.11510
    • 50+56.5025850+7.07070
    • 150+55.52687150+6.94860
    • 10+112.5722210+14.08723
    • 25+83.1630025+10.40697
    • 50+80.0450450+10.01679
    • 100+77.13685100+9.65286
    库存:100
