Data sheet | Item number: 752-9800
Edge Computer; 4 x ETHERNET, 4 x USB, HDMI, DP; 16GB RAM; 256GB FLASH
https://www.wago.com/752-9800
• 4 x ETHERNET interface for connecting to field devices and IT networks
• 4 x USB interface for optional connection of a USB stick, mouse or keyboard
• HDMI and display port interfaces for connecting a display
Notes
Note (availability)
Available from mid-December 2021
Technical data
ETHERNET protocols
DHCP
DNS
HTTP
HTTPS
SSH
SCP
SFTP
Visualization
Web server
Operating system
Debian Linux 10.9
Processor
Intel® i7-7600U 2.8 GHz (max. 3.90 GHz)
Main memory (RAM)
16 GB; DDR4 2133 MHz
Internal memory (flash)
256 GB; SATA 2.5“ SSD
Indicators
3 x LED
Supply voltage
24 VDC (10 … 36 V)
Input current (typ.) at nominal load (24 V)
2292 mA
Input current (max.) (24 V)
3967 mA
Page 1/3
Version 07.03.2022
Continued on next page
Technical data
Operating power
55 W (typ.); 95.2 W (max.)
Connection data
Connection technology: communication/fieldbus
4 x RJ-45 1000BASE-T; 4 x USB 3.0 (Typ A)
Physical data
Width
45 mm
Height
200 mm
Depth
140 mm
Mechanical data
Weight
1810 g
Housing material
Aluminum, powder-coated
Environmental requirements
Ambient temperature (operation)
-20 … +60 °C
Surrounding air temperature (storage)
-40 … +85 °C
Protection type
IP40
Relative humidity (without condensation)
95 %
Mounting type
DIN-35 rail
Fire load
0 MJ
Commercial data
PU (SPU)
1 Pieces
Country of origin VKOrg Germany
TW
GTIN
4055144116861
Customs tariff number VKOrg Germany
84715000000
Approvals / Certificates
UL-Approvals
Approval
Standard
Certificate name
UL
Underwriters Laboratories
Inc.
UL 62368-1
E482462
Page 2/3
Version 07.03.2022
Downloads
Environmental Product Compliance
Compliance Search
Compliance 752-9800
Documentation
Manual
WAGO Edge Computer
Bid Text
V 1.0.0
12.10.2021
pdf
1032.71 KB
752-9800
xml
5.08 KB
752-9800
docx
29.29 KB
CAD/CAE-Data
CAD data
CAE data
2D/3D Models
752-9800
ZUKEN Portal
752-9800
Subject to changes. Please also observe the further product documentation!
Current addresses can be found at: w w w.wago.com
Page 3/3
Version 07.03.2022
很抱歉,暂时无法提供与“752-9800”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+123106.684901+15893.44239
