8000-099/000-1765
8000-099/000-1765
    WAGO(万可电子)
    适配器连接器 USB-A(USB TYPE-A),插座 至 USB-A(USB TYPE-A),插座 面板安装
8000-099/000-1765 数据手册
TECHNICAL DATA SHEET USB 3.0 Panel Connector PN 8000-099/000-1765 DIMENSIONS (mm) Part Number: 8000-099/000-1765 Description General Degree of polution USB 3.0 panel connector with M22 thread for front installation ISB 3.0 female / female Type A/A Type: USB 3.0 A/A F/F 3 Technical Data Rated volatge UN 5 VAC / VDC Rated current 0.9 A Insulation resistance > 100 MΩ Rated voltage max. Protection class cULus NEMA Type 2, 3R, 4, 4X, 12, 13: IEC IP65 with cap closed, IP20 when connected Pole number 9 PA, PVC Transfer rate 5 Gbit/s CuSn, gold-plated Contact type 1:1 Contact resistance Housing material Cover Contact material Mounting Installation depth Operating temperature range Storage temperature range Mechanical service life Weight MOUNTING < 30 mΩ TPU Front installation 100 mm - 20 °C ... +70 °C USB standard Shielding Approvals 30 V 3.0 Shielded cULus -25 °C ... +80 °C > 100 insertion cycles 0.32 oz/piece PIN ASSIGNMENT TECHNICAL DATA SHEET Cat 6A Panel Connector PN 8000-099/000-1764 DIMENSIONS (mm) Part Number: 8000-099/000-1764 Description General RJ45 panel connector for front installation 22.5 mm Female/female 1:1 Form male 1 RJ45 Insulation resistance > 100 MΩ Degree of polution Contact resistance Flammability according to UL 94 Protection class Housing material Cover Contact material Mounting Installation depth Operating temperature range Storage temperature range Temperature range connector Mechanical service life Weight MOUNTING 3 Rated volatge UN 24 VAC Rated current 1.5 A Rated voltage max. < 30 mΩ V0 Technical Data Pole number cULus NEMA Type 2, 3R, 4, 4X, 12, 13: IEC IP65 with cap closed, IP20 when connected Transfer rate 50 V 8 10 Gbit/s Category Cat 6 A PA, PBT, Contact type 1:1 CuSn, gold-plated Approvals cULus TPU Front installation Shielding 70 mm -20 °C ... +70 °C -20 °C ... +80 °C -20 °C ... +70 °C > 750 insertion cycles 0.84 oz / piece CIRCUIT DIAGRAM Connected through
8000-099/000-1765 价格&库存
很抱歉,暂时无法提供与“8000-099/000-1765”相匹配的价格&库存,您可以联系我们找货
8000-099/000-1765
