857-423
JUMPFLEX® Signal Conditioners
Signal Splitter with 2 configurable Current Outputs
Configuration via:
DIP switch
Short description:
The 857-423 Signal Splitter converts standard signals and amplifies, filters and
electrically isolates analog standard signals.
Characteristics:
• Two configurable current outputs
• Calibrated scale switching
• Switchable max. operating frequency
• Safe 3-way isolation with 2.5kV test voltage to EN 61140
Technical Data
Configuration:
Configuration
Input:
Input signal
Input resistance
Output:
Output signal
Load impedance
General specifications:
Nominal supply voltage VS
Supply voltage range
Current consumption at 24 VDC
Max. operating frequency
Response time (T10-90)
Transmission error
Temperature coefficient
WAGO Kontakttechnik GmbH & Co. KG
Subject to design changes
5 OUT 1+
IN
OUT 1
GND 1 2
6 GND 2
OUT 2+ 3
OUT 2
_>
_>
____________
IN+ 1
GND 4 4
7 Us+
POWER
8 GND 3
6 mm/0.23 in
Description
Item No.
JUMPFLEX® Signal Conditioner, for DIN 35 857-423
Pack.
Unit
1
Technical Data
DIP switch
0 ... 20 mA, 4 ... 20 mA, 0... 5 V,
0 ... 10 V, 2 ... 10 V, 1 ... 5 V
(calibrated switchable)
≤ 50 Ω (In = mA)
≥ 100 kΩ (In = V)
2 x 0(4) ... 20 mA
2 x 300Ω
24 VDC
VS -30 % … +30 %
≤ 35 mA
100 Hz / 1 kHz
(switchable via DIP switch)
< 3.5 ms / < 300 μs
≤ 0.1 % of the full scale value
≤ 0.01 % /K
08.07.2015
Environmental requirements:
Ambient operating temperature
Storage temperature
Safety and protection:
Test voltage (input/output/supply)
Connection and type of mounting:
Wire connection
Cross sections
Strip lengths
Dimensions and weight:
Dimensions (mm) W x H x L
Weight
Standards and approvals:
Conformity marking
r UL 508
r ANSI/ISA 12.12.01
Shipbuilding
EMC immunity of interference
EMC emission of interference
Accessories
Postfach 2880 - D-32385 Minden
Hansastr. 27 - D-32423 Minden
-25 °C ... +70 °C
-40 °C ... +85 °C
2.5 kV AC, 50 Hz, 1 min
Push-in CAGE CLAMP®
solid:
0.08 mm² ... 2.5 mm² / AWG 28 ... 14
fine-stranded:
0.34 mm² ... 2.5 mm² / AWG 22 ... 14
9 ... 10 mm / 0.35 … 0.39 in
6 x 96 x 94
Height from upper-edge of DIN 35 rail
40.6 g
1
Class I, Div. 2, Grp. ABCD, T4
GL, PRS, NKK, DNV, BV
EN 61000-6-2
EN 61000-6-4
see pages 226 … 236
Tel.: +49(0)571/887-0
E-Mail: info@wago.com
Fax: +49(0)571/887-169
www.wago.com
DIP Switch Adjustability
857-423
▯ = ON
Dip Switch S1 (6-fold)
Max. Operating
Frequency
Input Signal
1
2
3
4
0 … 20 mA
4 … 20 mA
2 … 10 V
5
1 kHz
0 … 10 V
0…5V
Output Signal 1
1…5V
Default Settings
Input
0 … 20 mA
Output 1
0 … 20 mA
Output 2
0 … 20 mA
Max. Operating Frequency
1 kHz
100 Hz
Output Signal 2
6
0 … 20 mA
4 … 20 mA
0 … 20 mA
4 … 20 mA
很抱歉,暂时无法提供与“857-423”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4533.391901+587.61391
- 10+3808.1461410+493.60825
