Shunt Meter
For DC Current Measurement
EVALUATION KIT AVAILABLE
W
A
0 - 1VDC Input
High resolution for DC Current Shunts
Low Side Applications
0.1
Accuracy
40
E YE
TY
Easy to Use. Easy to Read.
RE
AR
TH
Contact us to request yours
RRAN
Programmable backlight
color to alert user
Warning
flash
Segment curved
bar graph display
Programmable
scale
Programmable 4 digit
star-burst display. Custom
messages & annunciators
Combined digital and
bar graph display
2
Alarm set points
USB port for custom user settings
via the free easy-to-use software
PLC
2 outputs: Digital (open
collector) or Analog (4-20mA)
*NEW* Digital Output Delays
16
osition switch for
P
selecting standard
configurations
Available in either
Less than
53mm deep
POSITIVE
NEGATIVE
Full 4 digit readout for accuracy
Featuring an acclaimed easy-to-read display and a high resolution input, the Shunt Meter takes the APM into a wide
range of new applications, where accurate DC current measurement is required.
The APM Shunt Meter is ideal for DC current measurement applications in marine, leisure, material handling, and industrial
applications such as power supplies, load banks and charging systems.
The programmable scale and custom annunciators mean users can tailor the meter to display their critical parameters exactly
how they want. Dynamic backlighting, in conjunction with setpoints, means operators are visually alerted when a parameter
is out of range. The two outputs can be used to connect the APM to other systems in the process, meaning the APM Shunt
Meter is much more than just a display.
Go to www.trumeter.com/apm for further information
Key Features
Large multi-format display that incorporates:
Visibility:
• 40 segment bar graph display
• Large 4-digit display
• S
eparate Starburst display area for annunciators,
custom messages and alarm information
• D
ynamic backlight color
Programmable:
Dimensions:
Display Range (Both Min & Max Values)
Custom annunciators
User-selectable backlight color and intensity
Two independent alarm set-points
T
wo independent outputs
4-20mA analog monitor output
57mm [2.24”]
53mm [2.09”]
72mm [2.84”]
72mm [2.84”]
User-adjustable backlight brightness and color
Large display
Wide viewing angle (horizontal and vertical)
Custom annunciators
Panel cutout: 68mm x 68mm [2.68” x 2.68”] as per DIN43700/IEC61554
INPUT
VOLTAGE
Range
0 - 1 VDC
Impedance
Easy To Use Software
1 Meg
Accuracy (0-200mV)
0.1% of signal or 0.5mV, whichever is greater
Accuracy (201-1000mV)
0.2% of full scale
ENVIRONMENTAL
Temperature - operating
-10 to +60°C
Temperature - storage
-40 to +70°C
IP rating (from the front)
NEMA rating (from the front)
Just plug into any USB port on your PC, run the
freely available APM Configurator application
and you’re off. No drivers required.
IP65
Type 4 & Type 12 (UL 50)
POWER SUPPLY
Nominal Input
12-24 VDC
DISPLAY
Number of digits
4
Digit height
12mm [0.47”]
Number of message characters
Backlight colors
4
Red, Green, White
LCD display
Positive or Negative
OUTPUTS
Max voltage
34V
Max current
500mA
Analog output
4-20mA
CERTIFICATION
Open-type Measuring
and Testing Equipment
E469787
UL, cUL, CE, UKCA
Part Numbers:
By Request: Modbus connectivity
APM-SHUNT-APO
APM SHUNT METER, POSITIVE LCD, WITH OUTPUTS
APM-CT-APS
APM CT METER, POSITIVE LCD WITH MODBUS
APM-SHUNT-ANO
APM SHUNT METER, NEGATIVE LCD, WITH OUTPUTS
APM-CT-ANS
APM CT METER, NEGATIVE LCD WITH MODBUS
022128-01
USB Cable
022150-01
APM Evaluation Kit
www.trumeter.com
Full specifications available online
Trumeter (The Americas)
6601 Lyons Rd, Suite H-7
Coconut Creek, Florida
FL 33073,
USA
Tel: +1 954 725 6699
Email: sales.usa@trumeter.com
Trumeter (Europe)
Pilot Mill
Alfred Street
Bury,
BL9 9JR
Tel: +44 161 674 0960
Email: sales.uk@trumeter.com
Innovative Design Technologies Sdn. Bhd
Lot 5881, Lorong Iks Bukit Minyak 1
Taman Perindustrian Iks, 14000 Bukit Tengah
Penang, Malaysia
Web: www.idtworld.com
Tel: + 604 5015700
Email: sales.my@idtworld.com
APM-SHUNT-US-DS.v.2.6
SHUNT-APM-DS.v.3.4
02/2024 01/2020
很抱歉,暂时无法提供与“APM-SHUNT-ANO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1337.99062
- 5+1314.54907
