7000AS
7000AS
    TRUMETER
    Module
    TRUMETER - 7000AS - LCD COUNTER, 6 DIGIT, 6MM, 2.6 TO 3.4VDC
7000AS 数据手册
7000 Series 6 digit LCD electronic totalizing counters and hour meter With Bezel Without Bezel The 7000 series is a range of miniature, 6-digit LCD, PCB-mount totalizing counters and hour meters. They are designed for minimal power requirement and are suitable for either direct PCB mounting, or panel mounting with the bezel supplied. The 7000/7000AS can be configured to count electro-mechanical contact closure events using an external resistor and capacitor to eliminate contact bounce. Similarly the supply voltage can be increased using an external resistor and 3V zener diode. Key Features • Uses the latest CMOS circuitry to • Counts pulses up to 10kHz frequency achieve quiescent current consumption • External reset input of less than 5µA • CE, UL and cUL approved • 6mm black character high contrast LCD display • Bi-directional counting (7000AS model) • Hour Meter (7000XX model) Specification Supply Voltage 2.6 – 3.4VDC Current Consumption 5uA quiescent, 10µA at 10kHz Display 6 digit black LCD, 6mm characters with leading zero blanking Count Range 999999 display rollover to 0 Count Input 10kHz maximum, negative edge triggered, 0.7V threshold, 50µS minimum pulse length, TTL/CMOS Compatible Reset Input Negative edge triggered, 0.7V threshold, 15mS minimum pulse length, TTL/ CMOS Compatible Direction Input Add=logic 1, Subtract=logic 0 (0V) Operating Temp -10°C to +60°C Storage Temp -10°C to +60°C Material Clear polycarbonate Environmental Protection IP40/DIN40050 Weight 7.5g Dimensions 31mm (1.22") 21mm (0.83") 5mm 6.5mm (0.2") (0.26") 28mm (1.1") 3.5mm (0.14") 24mm (0.95") 5mm (0.2") 10mm (0.4") 18mm (0.71") 1 2 3 4 2.54mm (0.1") 5 20.32mm (0.8") Part Numbers 7000 6 Digit LCD Totalizing Counter 7000AS 6 Digit LCD Totalizing Counter, Bi-directional, Add/Subtract version of above 7000XXX 6 Digit LCD Hour Meter www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7 Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9EF Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com 7000(AS)-DS.v.3.0 02/2020
7000AS 价格&库存
很抱歉,暂时无法提供与“7000AS”相匹配的价格&库存,您可以联系我们找货
