710-0001
710-0001
    TRUMETER
    TRUMETER - 710-0001 - ELECTROMECHANICAL HOUR METER
710-0001 数据手册
Item # 710-0003 Model 710 Electromechanical Hour Meter Model 710 Electromechanical Hour Meter The Model 710 AC hour meters and minute meters are widely used in panel applications where number size and visibility are critical. Its tough, Lexan bezel and distinctive styling enhance appearance and durability. Available in 5 figures reset or 6 figures non-reset versions. Specifications Model No. 710 Mounting Panel (3-Hole) Reset Non-reset Termination 8 inch (203mm) wire leads Display 6 figures, 99999.9 (non-reset), 0.19 inch (5mm) high Display Height 0.19 Inch Display Height 5 mm No. of Digits 6 Records 99999.9 hours Input Voltage 230 VAC 60 Hz ± 10% Power 3 watts (nominal) Operating Temperature -20 to +160 °F Operating Temperature -29 to +71 °C Weight 6 oz Weight 170 gm Panel Cutout 2.21 Inch Panel Cutout 56.1 mm Mounting Holes For No. 4 screws on 2.44 inch (62.0mm) B.C. and No. 6 screws on 2.53 inch (64.3mm) B.C. Approvals UL Recognized, CSA Certified, CE Compliant Stock Availability Yes 1 Electromechanical Model 710 Hour Meter Description The model 710 AC hour meters and minute meters are widely used in panel applications where number size and visibility are critical. Its tough, Lexan bezel and distinctive styling enhance appearance and durability. Available in 5 figure reset or 6 figure non-reset versions. Features Options • • • • • • • • • Large figures Tough, Lexan case Reset or non-reset Specifications Figures: Models Description 710-0001 710-0002 710-0003 710-0006 710-0008 710-0009 710-0013 115VAC/60Hz, non-reset, 99,999.9 hrs, 115VAC/60Hz, non-reset, 99,999.9 hrs, 230VAC/60Hz, non-reset, 99,999.9 hrs, 24VAC/60Hz, non-reset, 99,999.9 hrs, 115VAC/60Hz, non-reset, 99,999 hrs, 115VAC/50Hz, non-reset, 99,999.9 hrs, 115VAC/60Hz, front reset, 9,999.9 hrs, * Terminations: Temp. Range: Approvals: Weight: 5 figures, 9999.9 (reset) or 6 figure, 99999.9 (non-reset), 0.19’’ [5mm] high Reset (on front or side) or non-reset 24, 115 or 230VAC, (+/-10%), 50 or 60 Hz. 3 watts (nominal) Panel (3-hole) Reset: Voltages: Power: Mounting: Private label faceplates Bracket mount Mounting bracet (721-0003) Splash proof kit (721-0017) Heavy duty splash proof kit (721-0018) Gasket (721-0004) 8’’ [203mm] wire leads terminal block 8’’ [203mm] wire leads 8’’ [203mm] wire leads 8’’ [203mm] wire leads 8’’ [203mm] wire leads 8’’ [203mm] wire leads 8’’ [203.2mm] wire leads or terminal block -20°F to +160°F [-29°C to +71°C] UL Recognized, CSA Certified, CE Compliant 6 oz. [170g] Models Description 710-0014 710-0018 710-0024 710-0026 710-0032 710-0051 230VAC/60Hz, non-reset, 99,999.9 hrs, terminal block 115VAC/60Hz, non-reset, 99,999.9 min, 8’’ [203mm] wire leads 24VAC/60Hz, non-reset, 99,999.9 hrs, terminal block 115VAC/50Hz, non-reset, 99,999.9 hrs, terminal block 115VAC/60Hz, front reset, 9,999.9 hrs, terminal block 115VAC/60Hz, non-reset, 99,999 hrs, terminal block Items in bold are normally in factory stock. Dimensions 8” [203mm] Wire Leads 2.40 [61.0] 12 3 4 5 6 0.19 [4.8] Applications Office equipment 66 2.18 [55.2] DIA 2.84 [72.1] 1.98 [50.3] Mounting holes: For #4 screws on 2.44” [62.0] B.C. and #6 screws on 2.53” [64.3] B.C. Panel cutout: 2.21’’ [56.1] Dia. Control panels Industrial equipment Test equipment Compressors
710-0001 价格&库存
很抱歉,暂时无法提供与“710-0001”相匹配的价格&库存,您可以联系我们找货
  • 1+762.63653
库存:46
710-0001
  • 1+1073.765091+139.32014
