732-0004
732-0004
    TRUMETER
    TRUMETER - 732-0004 - ELECTROMECHANICAL HOUR METER
732-0004 数据手册
Item # 732-0013 VDC, Round Cup Mount VDC, Round Cup Mount The Redington Model 732 provides a DC Hour Meter with an operating range of 10-80VDC. Models are protected for two times battery voltage and/or reverse polarity. Models are available in the standard industry housings. Its quartz time base insures accurate long-term time keeping. The Totally Sealed case protects against the environment and provides years of reliable service. All applicable models are NEMA 4X, 12 rated when mounted with optional gasket. Specifications Model No. 732 Mounting Round Cup Reset Non-reset Termination 1/4 inch (6.3mm) spade terminals Display 6 - digits, 0.125 inch (3.2mm) 99999.9 Hours - white on black Tenths - red on white Display Height 0.125 Inch Display Height 3.2 mm No. of Digits 6 Records 99999.9 hours Accuracy ± 0.02 over entire range Input Voltage 10-80 VDC Power 0.3 watts at 12VDC Operating Temperature -40 to +185 °F Operating Temperature -40 to +85 °C Case Material Black Polymer Weight 2 oz Weight 57 gm Approvals UL/CSA Recognized, CE Compliant Environmental Protection Totally sealed Vibration 10-75 Hz Stock Availability Yes 1 Model 732 Electromechanical Totally Sealed Hour Meter Description The Redington Model 732 provides a DC Hour Meter with an operating range of 10-80VDC. Models are protected for 2 times battery voltage and/or reverse polarity. Models are available in the standard industry housings, 3-Hole Round, Flush-Rectangular, Flush-Round and 2-Hole Rectangular. A Stirrup and Cup mount are available for applications where high shock and vibration exist. Its quartz time base insures accurate long-term time keeping. The Totally Sealed case protects against the environment and provides years of reliable service. Most models are NEMA 4X, 12 rated when mounted with optional gasket. Features • • • • • • 92 Options Operating voltage 10-80VDC Totally Sealed UL/cUL Recognized, CE & RoHS Compliant 6 Figure, 99999.9 Quartz accuracy 6 mounting variations • • • • Wire leads Gasket kit (for NEMA 4X, 12 rating) Custom Lens Terminals up, down, straight Model 732 Electromechanical Totally Sealed Hour Meter Specifications Figures: 6 - digits, 0.14” [3.6mm] 99999.9 Hours and running indicator - white on black Decimal - black on white Non-reset 10-80VDC 1 watt max. Clip, mounting holes, Cup, or Stirrup ¼” [6.3mm] spade terminals ~2.0 oz [57 g] ± 0.02% over entire range Stirrup and Cup mount have metallic bezels Black polymer Cup & Stirrup - glass All other models - polymer Reset: Voltage: Power: Mounting: Termination: Weight: Accuracy: Bezel: Case Material: Lens Material: Transient Protection: Agency Approvals: Overvoltage & Reverse Polarity: Environmental: Front Panel: Temperature: Humidity: Shock: Vibration: ± 6 times normal for 300msec UL/cUL Recognized, CE, SAE, & RoHS Compliant. All models are NEMA 4X, 12 Compliant except the Cup and Stirrup mount Protected for 2 times battery voltage and/or reverse polarity Totally Sealed NEMA 4X, 12 rated with optional gasket -40°F to +185°F [-40°C to + 85°C] 95% (SAE J1378) 55g @ 9 - 13msec (SAE J1378) 10-80Hz. 20g max. (SAE J1378) Models Description 732-0001 732-0002 732-0003 732-0004 732-0013 732-0014 732-0023 732-0024 3-Hole Round, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s Flush-Rectangular, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s Flush-Round, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 2-Hole Rectangular, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s Panel mt, Round, Cup, stainless steel bezel, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s Panel mt, Round, Cup, black metallic bezel, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s Panel mt, Round, Stirrup, stainless steel bezel, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s Panel mt, Round, Stirrup, black metallic bezel, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 5003-008 5003-009 5003-010 5003-011 NEMA 4X, 12 Gasket for Models 732-0003 NEMA 4X, 12 Gasket for Model 732-0002 NEMA 4X, 12 Gasket for Model 732-0004 NEMA 4X, 12 Gasket for Model 732-0001 * All items are normally in factory stock. Dimensions 2-Hole Flush-Rectangular .7 [18] .7 [18] 25° REF 25° REF 1.89 [48.0] MAX 2.05 [52.1] 2.19 [55.6] MAX 1.89 [48.0] MAX .10 [2.5] 1.60 [40.6] 1.47 [37.4] 2.19 [55.6] MAX .10 [2.5] .88 [22.4] .88 [22.4] 2X Ø.15 [Ø3.8] 1.08 [27.4] 1.03 [26.2] 1/10 .93 [23.5] .93 [23.5] 1/10 .15 [3.8] 1.75 [44.5] 1.43 [36.3] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] 1.43 [36.3] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] Maximum Panel Thickness: 0.03 to 0.63 [0.76 to 16.00] 93 Electromechanical Model 732 Totally Sealed Hour Meter Flush-Round 3-Hole Round .7 [18] .7 [18] 25° REF 25° REF 1.87 [47.5] MAX .11 [2.8] 2.17 [55.1] MAX FOAM GASKET Ø.16 [Ø4.0] Ø.13 [Ø3.2] .10 [2.5] Ø1.98 [Ø50.3] Ø2.24 [Ø56.9] 2.17 [55.1] MAX 1.87 [47.5] MAX .09 [2.3] .21 [5.3] Ø2.80 [Ø71.1] Ø1.95 [Ø49.4] Ø1.98 [Ø50.3] Ø1.82 [Ø46.2] .93 [23.5] .93 [23.5] 1/10 1/10 Ø2.53 [Ø64.3] 1.43 [36.3] Ø2.42 [Ø61.5] 1.43 [36.3] Panel Opening: 2.0” [50.6] Maximum Panel Thickness: 0.40 [10.2] Panel Opening: 2.0” [50.6] Cup Stirrup .3 [8] .7 [18] Ø2.25 [Ø57.2] Ø2.25 [Ø57.2] .3 [8] Ø1.95 [Ø49.5] Ø1.98 [Ø50.3] 2.89 [73.4] 1.88 [47.8] MAX 1.88 [47.8] MAX .30 [7.6] Ø2.5 [Ø64] .7 [18] .12 [3.0] Ø2.5 [Ø64] .12 [3.0] 2X #8-32UNF .30 [7.6] METALLIC RING 1.53 [38.9] 3/8-16UNC 1/10 ~ 1/10 ~ Ø2.2 [Ø56] GLASS LENS 15° REF METALLIC RING 15° REF Ø2.2 [Ø56] GLASS LENS NOTE: SUPPLIED WITH MOUNTING HARDWARE NOTE: SUPPLIED WITH MOUNTING HARDWARE Panel Opening: 2.0” [50.6] Panel Opening: 2.0” [50.6] Applications Material Handling 94 Farm Equipment Outdoor Power Equipment Construction Equipment Utility Vehicles
732-0004 价格&库存
很抱歉,暂时无法提供与“732-0004”相匹配的价格&库存,您可以联系我们找货
    • 1+417.92811
    库存:343
    732-0004
    • 1+413.831481+53.78800
    • 5+388.010485+50.43190
    • 25+372.3613925+48.39790
    库存:8
