9415-001
9415-001
    TRUMETER
    TRUMETER - 9415-001 - TOTALIZING COUNTER
9415-001 数据手册
94 Series LCD Electronic Totalizer A 6 figure, battery powered, push-button or key reset, electronic counter, available in base mount or panel mount configuration. No external power supply is required. Large 0.50’’ [12mm] LCD figures for fast, easy reading. Operates at 6-240 VAC or VDC. Long lasting internal lithium battery. Attractive styling and silent operation make these models equally well-suited for lab or office equipment applications. Key Features • • • • No external power supply needed Long life lithium battery Large easy reading display Operates at 6 to 240 VAC or VDC Applications • • • • Office equipment Production Test Labs Control Panels Specification Figures 6 LCD figures, 0.50’’ [12mm] high Reset Push-button, or lock and key Speed 0-40 counts/second, (min. 12.5ms - on, 12.5ms - off) Input 6-240VAC or VDC Mount Base or panel Terminations (2) #22 AWG 221°F [105° C] wire leads, 8’’ [203mm] long Power Source Internal lithium battery Temp. Range -14°F to +122°F [-26°C to +50°C] Weight 18 oz. [510g] Dimensions Base Mount 3.81 [96.8] 1.65 [41.9] 0.88 [22.2] 4.44 [112.7] 2.97 [75.3] 3.15 [80.0] 1.36 [34.4] Panel Mount 3.15 [80.0] 1.75 [44.4] 2.90 [73.5] 1.65 [41.9] 1.50 [38.1] 3.23 [82.0] 1.87 [47.6] 1.41 [35.8] 4.06 [103.2] 3.31 [84.1] Panel cutout: 3.0” x 1.75” [76.2mm x 44.5mm] Mounting holes: 0.17” [4.3mm] Dia. Mounting holes: 0.14” x 0.24” [3.6mm x 6.1mm] slots Panel Mount/Lock & Key Reset 5.50 [139.7] 2.90 [73.5] 3.15 [80.0] 1.65 [41.9] 1.75 [44.5] 2.12 [54.0] 1.41 [35.8] 5.13 [130.2] Panel cutout: 4.75 ’’ x 1.50” [76.2mm x 44.5mm] Mounting holes: 0.17’’ [4.3mm] Dia. Part Numbers 9415-001 9415-003 9415-005 6 figure, base mount, push-button reset 6 figure, panel mount, push-button reset 6 figure, panel mount, lock and key reset Note: Load resistor (1500 ohms 10 watts) across input terminals required when using AC sensors www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7, Coconut Creek, Florida, FL 33073 USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9EF Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com 94-series-DS.v.3.0 03/2020
9415-001 价格&库存
很抱歉,暂时无法提供与“9415-001”相匹配的价格&库存,您可以联系我们找货
    • 1+2837.181021+366.25630
    • 1+1860.725721+240.20410
    • 5+1628.145955+210.18000
    • 10+1511.8122910+195.16230
    库存:1
