722-0030
722-0030
    TRUMETER
722-0030 数据手册
722 Series Electromechanical Hour Meter The Model 722 provides an AC Hour Meter with an operating range of 90-264VAC 50/60 Hz. You no longer require two separate meters, one for 115VAC and one for 230VAC. Models are available in the standard industry housings, 2-Hole Rectangular, Flush-Rectangular, Flush-Round, Square and 3-Hole Round. Its quartz time base insures accurate long-term time keeping. The totally sealed case protects against the environment and provides years of reliable service. All models are IP66 and NEMA 4X,12 rated when mounted with optional gasket. Key Features • • • • • Operating voltage 90-264VAC 50/60Hz Totally Sealed UL/cUL Recognized, CE & RoHS Compliant 6 Figure, 99999.9 Quartz accuracy Applications • • • • • Medical Equipment Control Panels Office Equipment Test Equipment Generators • Options include: ◦ Wire leads ◦ Gasket kit (for IP66 and NEMA 4X, 12 rating) ◦ Custom lens ◦ Terminals up, down, straight Specification Figures 6 - digits, 0.14” [3.6mm] 99999.9 Hours and indicator - white on black Decimal - black on white Non-reset 90-264VAC 50/60Hz 1 watt max. Clip or mounting holes 1/4” [6.3mm] spade terminals ~2 oz [57 g] ± 0.02% over entire range Black polymer Polymer UL/cUL Recognized; CE, UKCA & RoHS Compliant; IP66, SAE & NEMA 4X, 12 Compliant Totally Sealed IP66 and NEMA 4X, 12 rated with optional gasket -40°F to +185°F [-40°C to + 85°C] 95% (SAE J1378) 10-80 Hz. 20g max. (SAE J1378) 55g @ 9 - 13msec (SAE J1378) Reset Voltage Frequency Power Mount Terminations Weight Accuracy Case Material Lens Material Approvals Environmental Front Panel Temp. Range Humidity Vibration Shock Industry standard quartz timing: The 722 series hour meter uses a quartz crystal oscillator that generates an impulse every 36 seconds or 0.01 of an hour. Dimensions 2-Hole Flush-Rectangular .7 [18] .7 [18] 25° REF 25° REF 1.89 [48.0] MAX 2.19 [55.6] MAX 1.89 [48.0] MAX 2.19 [55.6] MAX .10 [2.5] .10 [2.5] .88 [22.4] .88 [22.4] 2.05 [52.1] 1.47 [37.4] 1.03 [26.2] 1.60 [40.6] 2X Ø.126 [Ø3.2] 1.08 [27.4] .93 [23.5] .15 [3.8] 1.75 [44.5] .93 [23.5] 1/10 1/10 1.43 [36.3] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] Recommended cut out hole size: 0.15 [3.8mm] 1.43 [36.3] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] Panel Thickness: 0.03 to 0.63 [0.76 to 16.00] Flush-Round 3-Hole Round .7 [18] .70 [17.8] 25° REF 1.87 [47.5] MAX .21 [5.3] 25° REF 2.17 [55.1] MAX 1.87 [47.5] MAX FOAM GASKET .10 [2.5] Ø2.24 [Ø56.9] Ø.16 [Ø4.0] .09 [2.3] .21 [5.3] Ø.13 [Ø3.2] Ø1.98 [Ø50.3] 2.17 [55.1] MAX Ø2.80 [Ø71.1] Ø1.95 [Ø49.4] Ø1.98 [Ø50.3] Ø1.82 [Ø46.2] .93 [23.5] .93 [23.5] 1/10 1/10 Ø2.53 [Ø64.3] 1.43 [36.3] Ø2.42 [Ø61.5] 1.43 [36.3] Panel Opening: 2.0” [50.6] Panel Thickness: 0.40 [10.2] Max. Panel Opening: 2.0” [50.6] Square Part Numbers 722-0001 2-Hole Rectangular, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s 722-0002 Flush-Rectangular, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s 722-0003 Flush-Round, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s 722-0004 3-Hole Round, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s 722-0030 Square 1.9”, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s 5003-010 IP66 / NEMA 4X, 12 Gasket for Model 722-0001 5003-009 IP66 / NEMA 4X, 12 Gasket for Model 722-0002 5003-008 IP66 / NEMA 4X, 12 Gasket for Model 722-0003 5003-011 IP66 / NEMA 4X, 12 Gasket for Model 722-0004 www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7 Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9JR Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com 722-series-DS.v.3.3 08/2022
722-0030 价格&库存
很抱歉,暂时无法提供与“722-0030”相匹配的价格&库存,您可以联系我们找货
  • 1+557.695331+72.36051
