APM-M2-ANO
APM-M2-ANO
    TRUMETER
    TRUMETER - APM-M2-ANO - ADVANCED PANEL METER, VOLT/AMP/FREQ
APM-M2-ANO 数据手册
AC Mains Powered Meter For measuring volts, amps or frequency Advanced Panel Meter (APM) Warning flash Programmable dynamic backlight color 40 Combined digital and bar graph display segment curved bar graph display mains powered 100-240 VAC Measurement: •  Volts: 0-600 AC or DC •  Amps: 0-5A Direct 0-10,000A via CT •  Frequency: 2Hz-400Hz Outputs: •  2x digital open collector •  1x analogue 4-20mA programmable to measure voltage, current or frequency Input Power •  100-240VAC user configurable alarms Configuration: •  PC Application via USB programmable scale Display Options: •  Positive LCD •  Negative LCD PLC 2 digital outputs 1 analog output Overview less than 53mm deep programmable starburst display for alarms, annunciators and functionality Open-type Measuring and Testing Equipment E469787 Key Features • • • • • • Mains powered 100-240VAC - no additional power supply needed. User configurable to measure voltage, current or frequency via APM application. User-programmable bar graph and alarms to immediately alert operators when a parameter is out of range. 4 character messaging area displays custom messages, alarms and annunciators. Interface to other equipment using digital and analogue outputs. Two LCD options: Positive (as shown) for use in bright conditions or Negative for use in darker environments. Go to www.truAPM.com for further information Specifications POWER SUPPLY Input 100 - 240VAC Max Power 1.6W Supply Frequency 47-63Hz ENVIRONMENTAL Temperature - operating -10 to +60°C Temperature - storage -40 to +70°C IP rating (from the front) IP65, NEMA type 4 and NEMA type 12 DISPLAY User Configurable Backlight Colours Red, Green, White ANALOGUE OUTPUT Output 4-20 mA Accuracy 0.50 % Resolution 0.02 mA OPEN COLLECTOR OUTPUTS Max voltage (open collector outputs) 34 VDC Max current (open collector outputs) 500 mA CERTIFICATION CE, RoHS, UL MECHANICAL 57mm [2.24”] Dimensions 53mm [2.09”] 72mm [2.84”] 72mm x 72mm x 53mm [2.83” x 2.83” x 2.09”] Cutout Connection Type 72mm [2.84”] 68mm x 68mm [2.68” x 2.63”] Screw Terminals Wire Gauge 0.8mm² - 3.3mm² (18AWG to 12AWG) Weight 180 grams Part Numbers APM-M2-APO APM MAINS M2 100-240VAC Positive LCD APM-M2-ANO APM MAINS M2 100-240VAC Negative LCD 022128-01 USB Cable www.trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9EF Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Trumeter (The Americas) 702 S. Military Trail Deerfield Beach, Florida FL 33442, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com APM-TM-MM-DS.v.1.0 05/2017
APM-M2-ANO
物料型号包括: - APM-M2-APO: APM MAINS M2 100-240VAC Positive LCD - APM-M2-ANO: APM MAINS M2 100-240VAC Negative LCD
器件简介: - 这是一个AC Mains Powered Meter,用于测量电压、电流或频率的高级面板仪表(APM)。
引脚分配: - 2x 数字开路集电极输出 - 1x 模拟4-20mA输出
参数特性: - 测量范围:电压0-600 AC或DC,电流0-5A直接测量,0-10,000A通过CT,频率2Hz-400Hz - 输入电源:100-240VAC - 显示选项:正显LCD(适用于明亮环境)和负显LCD(适用于较暗环境)
功能详解: - 可编程动态背光颜色 - 结合数字和条形图显示 - 用户可配置的报警 - 可编程星形爆发显示用于报警、指示器和功能 - 通过USB使用PC应用程序进行配置 - 环境温度范围:-10°C至+60°C
应用信息: - 主要用于测量电压、电流或频率,适用于需要实时监控和报警的场合。
封装信息: - 尺寸:72mm x 72mm x 53mm - 接线类型:螺丝端子 - 线规:0.8mm² - 3.3mm² (18AWG至12AWG) - 重量:180克
认证:CE, RoHS, UL。
APM-M2-ANO 价格&库存
很抱歉,暂时无法提供与“APM-M2-ANO”相匹配的价格&库存,您可以联系我们找货
APM-M2-ANO
  • 1+898.902991+116.66120
  • 3+842.743323+109.37270
库存:4
