Model 3400
Electronic LCD Counter
EVALUATION KIT AVAILABLE
Contact us to request yours
The Model 34 LCD Totalizer/Preset Counter provides a large display with 0.28” [7mm] high
characters, in a range of industry-standard sized housings.
The Model 34 counts and displays the number of pulses that appear at its input terminal at a rate of 40 pulses per second
(Hz), the input interface handles AC or DC inputs. The Totalizers are available in 5 different housings.
A wide operating voltage, 10-300VDC and 20-300VAC, makes the model 34 versatile for all indoor and outdoor
applications. All models are NEMA 4/4X, 12 & IP66 rated when used with the optional gasket and have a polarized lens
which assures high visibility in an outdoor environment.
Key Features
Options
Totally sealed from moisture and dirt
AC and DC voltage input in the same unit
Compact depth
Fits in existing panel openings
Always on display
Optional Remote Reset
A choice of 5 housings
Applications
Medical Devices
Test Equipment
Control Panels
Production Equipment
Office Equipment
Secondary Equipment
0.776
19.70
2.21
56.1
0.776
19.70
1.98
50.3
RECTANGULAR FLUSH
MOUNT AND SNAP-IN MODEL
0.94
23.9
0.
0.88
22.40
CL
ROUND FLUSH MOUNT
27.90
CL
1.09
27.6
1.750
44.45
1.09
27.6
1.750
44.45
hen interfacing the Model 34 with a Solid State Relay or AC sensor, the
W
leakage current needs to be considered. Exceeding the Absolute Voltage
1.44
36.6
Range and the Absolute Maximum Limits may result
in damge to the unit.
1.60
40.60
AC/DC Counter 2-hole case 1/4” spade terminal non-reset
AC/DC Counter 2-hole case 1/4” spade terminal remote-reset
Gasket
1.09
27.6
5003-010
0.25
5003-010
6.35
3400-1000
AC/DC Counter 3-hole case 1/4” spade terminals non-reset
3400-1010
AC/DC Counter 3-hole case 1/4” spade terminals remote-reset **special order** MOQ=50pcs
3400-2000
AC/DC Counter flush rectangular case 1/4” spade terminals non-reset **special order** MOQ=50pcs
0.78
19.70
3400-0000
3400-0010
1.60
40.60
5003-017
5003-017
0.25
6.35
0.88
22.40
3400-2010
AC/DC Counter flush rectangular case 1/4” spade terminals remote-reset
5003-009
AC/DC Counter round SAE case 1/4” spade terminals non-reset **special order** MOQ=50pcs
5003-009
5003-009
3400-3010
AC/DC Counter round SAE case 1/4” spade terminals remote-reset
AC/DC Counter snap-in case 1/4” spade terminals non-reset
3403-3000
3-30VDC Counter round SAE case 1/4” spade terminals non-reset
5003-010
5003-017
5003-009
NEMA 4X Gasket two hole mount
NEMA 4X Gasket three hole mount
NEMA 4X Gasket flush rectangular and SAE round mount
3400-0010-EVAL
3400 Evaluation Kit
www.trumeter.com
Trumeter (The Americas)
6601 Lyons Rd, Suite H-7
Coconut Creek, Florida
FL 33073,
USA
Tel: +1 954 725 6699
Email: sales.usa@trumeter.com
Trumeter (Europe)
Pilot Mill
Alfred Street
Bury,
BL9 9JR
Tel: +44 161 674 0960
Email: sales.uk@trumeter.com
1.09
27.6
0.88
22.40
3400-3000
3400-5000
0.94
23.9
1.10
27.90
0.78
19.70
1.10
27.90
Description
0.94
23.9
1.44
36.6
Part Numbers
Part Number
0.63
16.07
0.63
16.07
0.03
0.70
0.25
6.35
Notes:
1.98
50.30
1.26
32.13
1.26
32.13
0.88
22.40
0.78
19.70
Weight
0.03
0.70
1.09
27.6
0.94
23.9
0.78
19.70
0.25
6.35
Totally sealed
Totally sealed from moisture and dirt. NEMA 4/4X,
12 & IP66 compliant from the front when properly
mounted using the optional gasket.
(Not applicable in the Snap-In Model)
1 oz. [28g]
0.776
19.70
2.21
56.1
1.98
50.3
1.09
27.6
EMC Compliance EN61326
Enclosure
0.78
19.70
1.60
40.60
0.78
19.70
Sealing
0.
15
7
4
0.78
19.70
Environmental Operating Temp.: -10˚C to +60˚C [14˚F to +140˚F]
Storage Temp.: -20˚C to +70˚C [-4˚F to +158˚F]
Humidity: 95% RH per SAE J1378
Shock: 44 to 55g’s per SAE J1378
Dielectric: 1000VAC 50/60 Hz for 1 minute
Compliance: to European WEEE and RoHS Directives
0.776
19.70
2.21
56.1
15
7
4
UL & cUL recognized (file # ELIY2.E36690), CE,
UKCA, SAE, NEMA 4/4X/IP66 compliant (not
including snap-in models)
0.03
0.70
THREE HOLE MOUNT
0.
Approvals
TWO HOLE MOUNT
0.03
0.70
0.78
19.70
Standard 0.250” [6.4mm] spades
2.19
55.65
0.78
19.70
Terminations
2.19
55.65
1.60
40.60
1.44
36.6
1.10
27.90
Self-powered - battery life 10+ years (battery life
reduced to 5 years for temps above 100˚F/37.8˚C)
1.44
36.6
0.78 1.10
19.70 27.90
Power
1.09
27.6
1.750
44.45
0.78
19.70
10-300VDC and 20-300VAC - 50/60Hz
很抱歉,暂时无法提供与“3400-0000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+644.803361+83.39061
