722-0003
722-0003
    TRUMETER
722-0003 数据手册
Item # 722-0002 VAC, Clip Flush Rectangular VAC, Clip Flush Rectangular The Redington Model 722 provides an AC Hour Meter with an operating range of 90-264VAC 50/60 Hz. You no longer require two separate meters, one for 115VAC and one for 230VAC. Models are available in the standard industry housings. Its quartz time base insures accurate long-term time keeping. The Totally Sealed case protects against the environment and provides years of reliable service. All applicable models are NEMA 4X,12 rated when mounted with optional gasket. Specifications Model No. 722 Mounting Clip Flush-Rectangular Reset Non-reset Termination 1/4 inch (6.3mm) spade terminals Display 6 - digits, 0.125 inch (3.2mm) 99999.9 Hours - white on black Tenths - red on white Display Height 0.125 Inch Display Height 3.2 mm No. of Digits 6 Records 99999.9 hours Accuracy ± 0.02 over entire range Input Voltage 90-240 VAC 50-60 Hz ± 10% Power Less than 0.6 watts Operating Temperature -40 to +185 °F Operating Temperature -40 to +85 °C Case Material Black Polymer Weight 2 oz Weight 57 gm 1 Panel Cutout 1.45 x 0.95 Inch Panel Cutout 36.8 x 24.1 mm Approvals UL/CSA Recognized, CE Compliant Environmental Protection Totally sealed Vibration 10-75 Hz Stock Availability Yes Max. Panel Thickness 0.03 to 0.63 Inch Max. Panel Thickness 0.76 to 16.00 mm Accessory 5003-009 (NEMA 4X, 12 Gasket) 2 Model 722 Electromechanical Totally Sealed Hour Meter Description The Redington Model 722 provides an AC Hour Meter with an operating range of 90-264VAC 50/60 Hz. You no longer require two separate meters, one for 115VAC and one for 230VAC. Models are available in the standard industry housings, 2-Hole Rectangular, Flush-Rectangular, Flush-Round and 3-Hole Round. Its quartz time base insures accurate long-term time keeping. The Totally Sealed case protects against the environment and provides years of reliable service. All models are NEMA 4X,12 rated when mounted with optional gasket. Features • • • • • Options Operating voltage 90-264VAC 50/60Hz Totally Sealed UL/cUL Recognized, CE & RoHS Compliant 6 Figure, 99999.9 Quartz accuracy • • • • Wire leads Gasket kit (for NEMA 4X, 12 rating) Custom lens Terminals up, down, straight Specifications Figures: Reset: Voltage: Frequency: Power: Mounting: Termination: Weight: Accuracy: 6 - digits, 0.14” [3.6mm] 99999.9 Hours and idicator - white on black Decimal - black on white Non-reset 90-264VAC 50/60Hz 1 watt max. Clip or mounting holes ¼” [6.3mm] spade terminals ~2 oz [57 g] ± 0.02% over entire range Models Description 722-0001 722-0002 722-0003 722-0004 2-Hole Rectangular, Flush-Rectangular, Flush-Round, 3-Hole Round, 5003-009 5003-010 5003-011 5003-008 NEMA 4X, 12 Gasket for Model 722-0002 NEMA 4X, 12 Gasket for Model 722-0001 NEMA 4X, 12 Gasket for Model 722-0004 NEMA 4X, 12 Gasket for Model 722-0003 * All items are normally in factory stock 90 90-264VAC 50/60Hz, 90-264VAC 50/60Hz, 90-264VAC 50/60Hz, 90-264VAC 50/60Hz, Case Material: Lens Material: Agency Approvals: Environmental: Front Panel: Temperature: Humidity: Vibration: Shock: ¼” [6.3mm] spade terminals, ¼” [6.3mm] spade terminals, ¼” [6.3mm] spade terminals, ¼” [6.3mm] spade terminals, Black polymer Polymer UL/cUL Recognized, CE & RoHS Compliant, SAE & NEMA 4X, 12 Compliant Totally Sealed NEMA 4X, 12 rated with optional gasket -40°F to +185°F [-40°C to + 85°C] 95% (SAE J1378) 10-80 Hz. 20g max. (SAE J1378) 55g @ 9 - 13msec (SAE J1378) hours & 1/10’s hours & 1/10’s hours & 1/10’s hours & 1/10’s Model 722 Electromechanical Totally Sealed Hour Meter Dimensions 2-Hole Flush-Rectangular .7 [18] .7 [18] 25° REF 25° REF 1.89 [48.0] MAX 2.19 [55.6] MAX .10 [2.5] 2.05 [52.1] 2.19 [55.6] MAX 1.89 [48.0] MAX .10 [2.5] 1.60 [40.6] .88 [22.4] .88 [22.4] 1.47 [37.4] 2X Ø.15 [Ø3.8] 1.08 [27.4] 1.03 [26.2] .93 [23.5] 1/10 .93 [23.5] 1/10 .15 [3.8] 1.43 [36.3] 1.43 [36.3] 1.75 [44.5] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] Panel Thickness: 0.03 to 0.63 [0.76 to 16.00] Flush-Round 3-Hole Round .7 [18] .70 [17.8] 25° REF 1.87 [47.5] MAX .21 [5.3] 25° REF 2.17 [55.1] MAX 1.87 [47.5] MAX FOAM GASKET .10 [2.5] Ø2.24 [Ø56.9] Ø.16 [Ø4.0] .09 [2.3] .21 [5.3] Ø.13 [Ø3.2] Ø1.98 [Ø50.3] 2.17 [55.1] MAX Ø2.80 [Ø71.1] Ø1.95 [Ø49.4] Ø1.98 [Ø50.3] Ø1.82 [Ø46.2] .93 [23.5] .93 [23.5] 1/10 1/10 Ø2.53 [Ø64.3] 1.43 [36.3] Ø2.42 [Ø61.5] 1.43 [36.3] Panel Opening: 2.0” [50.6] Panel Thickness: 0.40 [10.2] Max. Panel Opening: 2.0” [50.6] Applications Medical Equipment Control Panels Test Equipment Generators Office Equipment 91
722-0003 价格&库存
很抱歉,暂时无法提供与“722-0003”相匹配的价格&库存,您可以联系我们找货
  • 1+410.09691
库存:22
722-0003
    • 2+618.282412+80.22163
    • 5+412.831075+53.56449
    • 10+379.5310910+49.24385
    库存:18
