APM-M2-APO
APM-M2-APO
    TRUMETER
    TRUMETER - APM-M2-APO - ADVANCED PANEL METER, VOLT/AMP/FREQ
APM-M2-APO 数据手册
M2 AC Mains Powered Meter 3-in1 for measuring volts, amps or frequency EVALUATION KIT AVAILABLE Contact us to request yours programmable dynamic backlight color Warning flash 40 Combined digital and bar graph display *NEW* 20 point nonlinearization scaling segment curved bar graph display mains powered 100-240 VAC RRAN Measurement: •  Volts: 0-600 AC or DC •  Amps: 0-5A Direct 0-10,000A via CT •  Frequency: 2Hz-400Hz Outputs x2: •  digital open collector •  analog 4-20mA programmable to measure voltage, current or frequency 10 Overview TY TH W A E YE AR Advanced Panel Meter (APM) RE Input Power •  100-240VAC NEW 10 alarm set points Configuration: •  PC Application via USB programmable scale Display Options: •  Available in either PLC POSITIVE 2 outputs: Digital (open collector) or Analog (4-20mA) *NEW* Digital Output Delays less than 53mm deep NEGATIVE programmable starburst display for alarms, annunciators and functionality Open-type Measuring and Testing Equipment E469787 Key Features • • • • • • • • • • Mains powered 100-240VAC - no additional power supply needed. User configurable to measure voltage, current or frequency via APM application. User-programmable bar graph and alarms to immediately alert operators when a parameter is out of range. 4 character messaging area displays custom messages, alarms and annunciators. Interface to other equipment using digital and analog outputs. Two LCD options: positive (as shown) for use in bright conditions or negative for use in darker environments. Customizable scale, including offset and gain, range (min and max) and linear. *NEW* T20 point non-linearization scaling for non-linear sensors e.g. thermocouples and pressure transducers. *NEW* 10 independent alarm set-points can be configured to change the backlight and/or message when input is in or out of range. *NEW* Configurable digital output delays (control the time output stays open/closed - .5 seconds – 120 seconds). Go to www.trumeter.com/apm for further information Specifications POWER SUPPLY Input 100 - 240VAC Max Power 1.6W Supply Frequency 47-63Hz ENVIRONMENTAL Temperature - operating -10 to +60°C Temperature - storage -40 to +70°C IP rating (from the front) IP65, NEMA type 4 and NEMA type 12 (UL 50) DISPLAY User-Configurable Backlight Colors Red, Green, White ANALOG OUTPUT Output 4-20 mA Accuracy 0.50 % Resolution 0.02 mA OPEN COLLECTOR OUTPUTS Max voltage (open collector outputs) 34 VDC Max current (open collector outputs) 500 mA CERTIFICATION CE, RoHS, UL, UKCA 57mm [2.24”] MECHANICAL Dimensions 53mm [2.09”] 72mm [2.84”] 72mm x 72mm x 53mm [2.83” x 2.83” x 2.09”] Cutout Connection Type Wire Gauge 72mm [2.84”] 68mm x 68mm [2.68” x 2.63”] Screw Terminals 0.8mm² - 3.3mm² (18AWG to 12AWG) Weight 180 grams Part Numbers BY REQUEST: Modbus Connectivity APM-M2-APO APM AC/MAINS Powered - 100-240 VAC with Positive LCD APM-M2-APS APM AC/MAINS Powered - 100-240 VAC, Positive LCD with Modbus APM-M2-ANO APM AC/MAINS Powered - 100-240 VAC with Negative LCD APM-M2-ANS APM AC/MAINS Powered - 100-240 VAC, Negative LCD with Modbus 022128-01 USB Cable 022150-01 APM Evaluation Kit Full specifications available online www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7 Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com www.trumeter.com/apm Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9JR Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com APM-M2-DS-v.2.5 01/2023
APM-M2-APO 价格&库存
很抱歉,暂时无法提供与“APM-M2-APO”相匹配的价格&库存,您可以联系我们找货
