The Advanced Panel Meter
APM Range
EVALUATION KIT AVAILABLE
Warning
flash
W
Programmable backlight
color to alert user
A
E YE
40
TY
MODELS: Volt Meter, Ammeter, Frequency Meter
RE
AR
TH
Contact us to request yours
RRAN
Combined digital and bar graph
display
*NEW* 20 point non-linearization
scaling
Segment curved
bar graph display
Programmable 4 digit
star-burst display. Custom
messages & annunciators
Programmable
scale
16
10
NEW 10 alarm set points
osition switch for
P
selecting standard
configurations
PLC
USB port for custom user settings
via the free easy-to-use software
2 outputs: Digital (open
collector) or Analog (4-20mA)
*NEW* Digital Output Delays
Less than
53mm deep
Available in either
POSITIVE
Full 4 digit readout for accuracy
NEGATIVE
The most visible, easy to use, programmable panel meter on the market. The APM provides accurate
measurement with an immediate visual indication of critical parameters. It has been designed for engineers
who require a more effective way of monitoring and displaying data.
The unique display combines traditional moving coil meters with the latest digital panel meters and it features a multitude of
options that can be set using the APM software. The backlight can be programmed to change color to alert the operator when the
current or voltage supply is too high or too low, reducing the risk of equipment failing and improving efficiency.
Go to www.trumeter.com/apm for further information
Key Features
Unique Display
Visibility
• 40 segment bar graph display
• Large 4 digit display
• S
eparate Starburst display area for annunciators, messages and alarm
information
• Dynamic backlight colour
Programmable
Dimensions:
User adjustable backlight brightness and colour
Large display
Wide viewing angle (both horizontal and vertical)
C
ustom annunciators
Positive and negative LCD options for indoor or outdoor environments
• Scale (offset, gain and linear) and Range (min and max)
• User selectable backlight color and intensity
• *NEW* 20 point non-linearization scaling for non-linear sensors e.g.
thermocouples and pressure transducers
• *NEW* Ten independent alarm set-points
• *NEW* Configurable digital output delays (control the time output stays open/
closed - .5 seconds – 120 seconds)
VOLT
AMP
Input range (DC)
0 - 600V
0 - 5A
Input range (AC)
0 - 600V
0 - 5A
2 - 400Hz
Max Using CT
53mm [2.09”]
72mm [2.84”]
72mm [2.84”]
MEASUREMENT
57mm [2.24”]
FREQUENCY
Panel cutout: 68mm x 68mm [2.68” x 2.68”] as per DIN43700/IEC61554
10,000A
Accuracy
1%
Display modes
1%
0.5%
Peak or RMS
ENVIRONMENTAL
Temperature - operating
-10 to +60°C
Temperature - storage
-40 to +70°C
IP rating (from the front)
NEMA 4 & 12 (UL50) with IP65
POWER SUPPLY
Nominal Input (AC or DC)
Easy To Use Software
Just plug into any USB port on your PC, run the freely
available APM Configurator application and you’re off. No
drivers required.
12-24 VAC/VDC
DISPLAY
Number of digits
4
Digit height
12mm [0.47”]
Digit height of annunciator
6mm [0.23”]
Number of message characters
Backlight colours
LCD display
4
Red, Green, White
Positive or Negative
OUTPUT MODELS
Max voltage
34V
Max current
500mA
Analogue output
4-20mA
CERTIFICATION
UL and cUL, CE, UKCA
Part Numbers: (POS LCD = Positive LCD; NEG LCD = Negative LCD)
Amp
Description
Frequency
Description
APM-VOLT-APO APM VOLT METER, POS LCD W/OUTPUTS
Volt
Description
APM-AMP-APO
APM AMMETER, POS LCD W/OUTPUTS
APM-FREQ-APO
APM FREQ METER, POS LCD W/OUTPUTS
APM-VOLT-ANO APM VOLT METER, NEG LCD W/OUTPUTS
APM-AMP-ANO
APM AMMETER, NEG LCD W/OUTPUTS
APM-FREQ-ANO
APM FREQ METER, NEG LCD W/OUTPUTS
APM VOLT METER, POS LCD W/MODBUS
APM-AMP-APS
APM AMMETER, POS LCD W/MODBUS
APM-FREQ-APS
APM FREQ METER, POS LCD W/MODBUS
APM-VOLT-ANS APM VOLT METER, NEG LCD W/MODBUS
APM-AMP-ANS
APM AMMETER, NEG LCD W/MODBUS
APM-FREQ-ANS
APM FREQ METER, NEG LCD W/MODBUS
022128-01
USB Cable
022150-01
APM Evaluation Kit
By Request: Modbus Connectivity
APM-VOLT-APS
www.trumeter.com
Trumeter (The Americas)
6601 Lyons Rd, Suite H-7
Coconut Creek, Florida
FL 33073,
USA
Tel: +1 954 725 6699
Email: sales.usa@trumeter.com
Trumeter (Europe)
Pilot Mill
Alfred Street
Bury,
BL9 9JR
Tel: +44 161 674 0960
Email: sales.uk@trumeter.com
Innovative Design Technologies Sdn. Bhd
Lot 5881, Lorong Iks Bukit Minyak 1
Taman Perindustrian Iks, 14000 Bukit Tengah
Penang, Malaysia
Web: www.idtworld.com
Tel: + 604 5015700
Email: sales.my@idtworld.com
APM-VAF-USA-DS.v.5.7
02/2024
很抱歉,暂时无法提供与“APM-VOLT-ANO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+844.131021+109.73430
- 3+787.890393+102.42320
