MicroAMP Meter
For DC Current Measurement
EVALUATION KIT AVAILABLE
W
A
E YE
0-200uA DC input
0.1
Accuracy
40
Programmable backlight
color to alert user
TY
Easy to Use. Easy to Read.
RE
AR
TH
Contact us to request yours
RRAN
Warning
flash
Segment curved
bar graph display
Programmable
scale
Programmable 4 digit
star-burst display. Custom
messages & annunciators
Combined digital and bar
graph display
10
*NEW* 20 point nonlinearization scaling
NEW 10 alarm set points
PLC
USB port for custom user settings
via the free easy-to-use software
16
2 outputs: Digital (open
collector) or Analog (4-20mA)
*NEW* Digital Output Delays
Less than
53mm deep
osition switch for
P
selecting standard
configurations
Available in either
POSITIVE
NEGATIVE
Full 4 digit readout for accuracy
Featuring an acclaimed easy-to-read display and a high resolution input, the MicroAMP Meter is the ideal
meter for applications where accurate DC current measurement is required.
With an accurate 0-200uA DC input, the APM MicroAMP is ideal for DC current measurement applications in marine, leisure, material
handling, and industrial applications such as power supplies, load banks and charging systems.
The programmable scale and custom annunciators mean users can tailor the meter to display their critical parameters exactly how they
want. Dynamic backlighting, in conjunction with setpoints, means operators are visually alerted when a parameter is out of range while
the two outputs can be used to connect the APM to other systems in the process, meaning the MicroAMP is much more than just a
display.
Go to www.trumeter.com/apm for further information
Key Features
Unique Display
Visibility
• 40 segment bar graph display
• User-adjustable backlight brightness and colour
• Large 4-digit display
• Large display
• Separate Starburst display area for annunciators, custom
• Wide viewing angle (horizontal and vertical)
messages and alarm information
• Custom annunciators
• D
ynamic backlight color
Programmable
Dimensions:
57mm [2.24”]
• Scale (offset, gain andlinear) and Range (min and max)
53mm [2.09”]
72mm [2.84”]
• User selectable backlight color and intensity
72mm [2.84”]
• *NEW* 20 point non-linearization scaling for non-linear sensors
e.g. thermocouples and pressure transducers
• *NEW* Ten independent alarm set-points
• * NEW* Configurable digital output delays (control the time
output stays open/closed - .5 seconds – 120 seconds)
INPUT
Range
Easy To Use Software
0-200uA DC
Impedance
4700Ω
Accuracy
Just plug into any USB port on your PC, run the
freely available APM Configurator application
and you’re off. No drivers required.
0.01% of input or 0.5uA
whichever is greater
ENVIRONMENTAL
Temperature - operating
-10 to +60°C
Temperature - storage
-40 to +70°C
IP rating (from the front)
NEMA rating (from the front)
Panel cutout: 68mm x 68mm [2.68” x 2.68”] as per DIN43700/IEC61554
IP65
Type 4 & Type 12 (UL 50)
POWER SUPPLY
Nominal Input
12-24 VDC
DISPLAY
Number of digits
4
Digit height
12mm [0.47”]
Number of message characters
Backlight colors
4
Red, Green, White
LCD display
Positive or Negative
OUTPUTS
Max voltage
34V
Max current
500mA
Analog output
4-20mA
CERTIFICATION
Open-type Measuring
and Testing Equipment
E469787
UL, cUL, CE, UKCA
Part Numbers:
APM-MICRO-APO
APM MicroAMP Meter, Postive LCD with outputs
APM-MICRO-ANO
APM MicroAMP Meter, Negative LCD with outputs
022128-01
USB Cable
022150-01
APM Evaluation Kit
By Request: Modbus © connectivity
APM MicroAMP Meter, Postive LCD with Modbus©
APM MicroAMP Meter, Negative LCD with Modbus©
Full specifications available online
Trumeter (The Americas)
6601 Lyons Rd, Suite H-7
Coconut Creek, Florida
FL 33073,
USA
Tel: +1 954 725 6699
Email: sales.usa@trumeter.com
www.trumeter.com
APM-MICRO-APS
APM-MICRO-ANS
Trumeter (Europe)
Trumeter
Pilot Mill, Alfred Street
Bury, Lancashire
BL9 9JR
Tel: +44 161 674 0960
Email: sales.uk@trumeter.com
Innovative Design Technologies Sdn. Bhd
Lot 5881, Lorong Iks Bukit Minyak 1
Taman Perindustrian Iks, 14000 Bukit Tengah
Penang, Malaysia
Web: www.idtworld.com
Tel: + 604 5015700
Email: sales.my@idtworld.com
APM-MICRO-US-DS.v.2.5
02/2024
很抱歉,暂时无法提供与“APM-MICRO-APO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1732.999821+223.57126
