Electronic
Model 34
LCD Counter
Description
The Redington Model 34 LCD Totalizer/Preset Counter provides a large display, with 0.28” [7mm] high characters, in industry size housings. The Model
34 counts and displays the number of pulses that appear at its input terminal at a rate of 40 pulses per second (Hz). The input interface handles AC or
DC inputs. The Totalizers are available in 7 different housings. All models are totally sealed and are capable of submersion in 6’ [2 meters] of water. A
wide operating voltage, 10-300VDC and 20-300VAC, makes the model 34 versatile for all indoor and outdoor applications. All models are NEMA 4/4X,
12, & IP66 rated when used with the optional gasket and have a polarized lens which assures high visibility in an outdoor environment.
Maintenance Meters are offered with a maximum of 3 preset “Redi-Alert’s” icons to alert users when service intervals are due or other periodic timed
events are due. Models are available with front panel field or factory programmable alerts. Not only does the display flash to get attention, but it displays
a choice of 7 different .08” [2mm] maintenance icons. Models are available with an Open Drain MOSFET output for the actuation of external alarms or
indicator lamps. Users can program or specify the count/service interval and flash duration for each Redi-Alert. Flash duration is the amount of time in
hours that the specific icon flashes before and after the specified total count. If a front panel manual reset of the Redi-Alert is required, the front panel
models with switches must be specified.
Features
Totally sealed from moisture and dirt
AC or DC voltage input in the same unit
Compact depth
Programmable output thresholds
Preset count value
Up to 3 Redi-Alerts/7 icons
Fits in existing panel openings
Always on display
A choice of 7 housings
A choice of reset modes
Front panel programmable
Preset Counter with output
15+ Year Battery Life
Specifications
Display:
LCD with large 0.28” [7mm] high figures black on
light background
Annunciators:
LCD 0.08” [2mm]
Reset:
Remote, manual and non-reset
Accuracy:
100% [provided signal meets stated parameters]
Displays:
8 digits (99999999)
Maximum pulse rate:
Inputs:
10-300VDC and 20-300VAC - 50/60Hz
VIH 20VAC or 10VDC minimum
VIL 3VAC or 3VDC maximum
Power:
Self powered - battery life 15+ years
Terminations:
Standard 0.250” [6.4mm] spades
Output:
8
Environmental:
Temperature: (Storage and Operating) -40 to +185˚F [-40 to +85˚C]
Humidity:
95% RH per SAE J1378
Vibration:
20g @ 10 to 80 Hz per SAE J1378
Shock:
44 to 55g’s per SAE J1378
Dielectric:
1000VAC 50/60 Hz for 1 minute
Compliance: Compliant to the European WEEE and RoHS Directives
Sealing:
Totally sealed
EMC Compliance:
EN61326:1997 with A1:1998 and A2:2001 for
industrial environments
Enclosure:
Totally sealed from moisture and dirt, NEMA
4/4X, 12, & IP66 compliant from the front when
properly mounted using the optional gasket.
(Not applicable to Snap-In Model)
Approvals:
UL and cUL Recognized (file # ELIY2.E36690),
CE, SAE, NEMA 4/4X/IP66 compliant
Weight:
Format: Open-Drain MOSFET with Source connected to
Common (see note 3)
Maximum Withstanding voltage: 30VDC, reference to Common
Maximum Load current: 0.1Amp
www.redingtoncounters.com
1oz [28g]
Electronic
Model 34
LCD Counter
Functions
Preset Counter:
The preset function is centered on the output signal. When the count reaches the preset value, the output signal is turned “on”. The
Preset function is count “up”. In addition to the preset function, models are also available with 3 RediAlert set points. Upon reaching the preset value the preset can be automatically reset, or it can await an external reset.
Front Panel Switch Functions:
Front panel switches can be used for reset, display selection and programming. The two front switches are used
as follows:
SEL:
During programming this switch is used to select options and to move horizontally in the programming chart.
RST:
This is the reset switch during normal operation.
to move vertically in the programming chart.
Available Icons
SERVICE
OIL
AIR FILTER
CHANGE
OIL FILTER
LAMP
MUFFLER
Dimensions
Rectangular Flush Mount
1.60 [40.6]
.28 [7.0]
1.10 [27.9]
2-Hole Mount
.34 [8.6]
.89 [22.6]
.34 [8.6]
1.75 [44.4]
.50 [12.7]
.28 [7.0]
1.10 [27.9]
.05 [1.3]
.05 [1.3]
1.41 [35.8]
.50 [12.7]
.89 [22.6]
.05 [1.3]
.05 [1.3]
1.41 [35.8]
.75 [19.0]
.75 [19.0]
.25 [6.3]
.25 [6.3]
.88 [22.3]
1.43 [36.3]
.88 [22.3]
1.43 [36.3]
Panel Cutout: 1.45” [36.8mm] x 0.95” [24.1mm]
Maximum Panel Thickness: 0.375” [9.5mm]
2-Hole No-Hole Mount
Round Flush Mount
.34 [8.6]
.34 [8.6]
.28 [7.0]
1.10 [27.9]
.50 [12.7]
.89 [22.6]
.50 [12.7]
.28 [7.0]
.79 [20.0]
.05 [1.3]
1.41 [35.8]
.05 [1.3]
.75 [19.0]
.03 [0.7]
1.29 [32.7]
.05 [1.3]
2.21 [56.1]
.05 [1.3]
.25 [6.3]
1.98 [50.3]
.88 [22.3]
1.43 [36.3]
.75 [19.0]
.25 [6.3]
.88 [22.3]
1.43 [36.3]
9
Electronic
Model 34
LCD Counter
3-Hole Mount
Snap-In Mount
1.10 [27.9]
.34 [8.6]
1.29 [32.7]
.34 [8.6]
.28 [7.0]
.79 [20.0]
.50 [12.7]
.28 [7.0]
.79
[20.0]
1.29 [32.7]
.50 [12.7]
.05 [1.3]
1.60 [40.6]
.05 [1.3]
.75 [19.0]
.03 [0.7]
.05 [1.3]
.05 [1.3]
2.87 [72.9]
.25 [6.3]
1.98 [50.3]
.88 [22.3]
1.43 [36.3]
.75 [19.0]
Panel Cutout: 1.46” [37mm] x 0.95” [24.1mm]
Minimum Panel Thickness: 0.04” [1.0mm]
Maximum Panel Thickness: 0.125” [3.18mm]
.25 [6.3]
.88 [22.3]
1.43 [36.3]
Square Flush Mount
.34 [8.6]
.28 [7.0]
.79 [20.0]
.50 [12.7]
.93 [23.6]
1.81 [46.0]
1.89 [48.0]
1.29 [32.7]
1.89 [48.0]
.03 [0.7]
.05 [1.3]
.05 [1.3]
.75 [19.0]
1.81 [46.0]
.25 [6.3]
.88 [22.3]
1.43 [36.3]
Notes
1. When interfacing the Model 34 with a Solid State Relay or AC Sensor, the leakage current needs to be considered. Contact the factory or see the
application note at www.redingtoncounters.com
2. Exceeding the Absolute Voltage Range and the Absolute Maximum Limits may result in damage to the unit.
3. The open-drain MOSFET acts like an open-collector NPN trasistor. Care should be taken since there is no current limiting protection in the unit.
Applications
Medical Devices
10
Test Equipment
Control Panels
Production Equipment
Office Equipment
Secondary Equipment
很抱歉,暂时无法提供与“3400-0010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+292.673861+37.91150
- 10+274.1800110+35.51590
