722 Series
Electromechanical Hour Meter
The Model 722 provides an AC Hour Meter with an operating range of 90-264VAC 50/60 Hz. You no
longer require two separate meters, one for 115VAC and one for 230VAC. Models are available in the
standard industry housings, 2-Hole Rectangular, Flush-Rectangular, Flush-Round, Square and 3-Hole
Round. Its quartz time base insures accurate long-term time keeping. The totally sealed case protects
against the environment and provides years of reliable service. All models are IP66 and NEMA 4X,12
rated when mounted with optional gasket.
Key Features
Operating voltage 90-264VAC 50/60Hz
Totally Sealed
UL/cUL Recognized, CE & RoHS Compliant
6 Figure, 99999.9
Quartz accuracy
Applications
Medical Equipment
Control Panels
Office Equipment
Test Equipment
Generators
Options include:
◦ Wire leads
◦ Gasket kit (for IP66 and NEMA 4X, 12 rating)
◦ Custom lens
◦ Terminals up, down, straight
Specification
Figures
6 - digits, 0.14” [3.6mm] 99999.9
Hours and indicator - white on black
Decimal - black on white
Non-reset
90-264VAC
50/60Hz
1 watt max.
Clip or mounting holes
1/4” [6.3mm] spade terminals
~2 oz [57 g]
± 0.02% over entire range
Black polymer
Polymer
UL/cUL Recognized; CE, UKCA & RoHS Compliant; IP66, SAE & NEMA 4X, 12 Compliant
Totally Sealed
IP66 and NEMA 4X, 12 rated with optional gasket
-40°F to +185°F [-40°C to + 85°C]
95% (SAE J1378)
10-80 Hz. 20g max. (SAE J1378)
55g @ 9 - 13msec (SAE J1378)
Reset
Voltage
Frequency
Power
Mount
Terminations
Weight
Accuracy
Case Material
Lens Material
Approvals
Environmental
Front Panel
Temp. Range
Humidity
Vibration
Shock
Industry standard quartz timing: The 722 series hour meter uses a quartz crystal oscillator that generates an
impulse every 36 seconds or 0.01 of an hour.
Dimensions
2-Hole
Flush-Rectangular
.7 [18]
.7 [18]
25°
REF
25°
REF
1.89 [48.0]
MAX
2.19 [55.6]
MAX
1.89 [48.0]
MAX
2.19 [55.6]
MAX
.10 [2.5]
.10 [2.5]
.88 [22.4]
.88 [22.4]
2.05 [52.1]
1.47 [37.4]
1.03 [26.2]
1.60 [40.6]
2X Ø.126 [Ø3.2]
1.08 [27.4]
.93 [23.5]
.15 [3.8]
1.75 [44.5]
.93 [23.5]
1/10
1/10
1.43 [36.3]
Panel Opening: 1.45” X 0.95” [36.8 X 24.1]
Recommended cut out hole size: 0.15 [3.8mm]
1.43 [36.3]
Panel Thickness: 0.03 to 0.63 [0.76 to 16.00]
Flush-Round
3-Hole Round
.7 [18]
.70 [17.8]
25°
REF
1.87 [47.5]
MAX
.21 [5.3]
25°
REF
2.17 [55.1]
MAX
1.87 [47.5]
MAX
FOAM
GASKET
.10 [2.5]
Ø2.24 [Ø56.9]
Ø.16 [Ø4.0]
.09 [2.3]
.21 [5.3]
Ø.13 [Ø3.2]
Ø1.98 [Ø50.3]
2.17 [55.1]
MAX
Ø2.80 [Ø71.1]
Ø1.95 [Ø49.4]
Ø1.98 [Ø50.3]
Ø1.82 [Ø46.2]
.93 [23.5]
.93 [23.5]
1/10
1/10
Ø2.53 [Ø64.3]
1.43 [36.3]
Ø2.42 [Ø61.5]
1.43 [36.3]
Panel Opening: 2.0” [50.6]
Panel Thickness: 0.40 [10.2] Max.
Square
Part Numbers
722-0001
2-Hole Rectangular, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s
722-0002
Flush-Rectangular, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s
722-0003
Flush-Round, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s
722-0004
3-Hole Round, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s
722-0030
Square 1.9”, 90-264VAC 50/60Hz, ¼” [6.3mm] spade terminals, hours & 1/10’s
5003-010
IP66 / NEMA 4X, 12 Gasket for Model 722-0001
5003-009
IP66 / NEMA 4X, 12 Gasket for Model 722-0002
5003-008
IP66 / NEMA 4X, 12 Gasket for Model 722-0003
5003-011
IP66 / NEMA 4X, 12 Gasket for Model 722-0004
www.trumeter.com
Trumeter (The Americas)
6601 Lyons Rd, Suite H-7
Coconut Creek, Florida
FL 33073,
USA
Tel: +1 954 725 6699
Email: sales.usa@trumeter.com
Trumeter (Europe)
Pilot Mill
Alfred Street
Bury,
BL9 9JR
Tel: +44 161 674 0960
Email: sales.uk@trumeter.com
Innovative Design Technologies Sdn. Bhd
Lot 5881, Lorong Iks Bukit Minyak 1
Taman Perindustrian Iks, 14000 Bukit Tengah
Penang, Malaysia
Web: www.idtworld.com
Tel: + 604 5015700
Email: sales.my@idtworld.com
722-series-DS.v.3.3
08/2022
很抱歉,暂时无法提供与“722-0002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+256.846321+32.98470
- 10+240.5679510+30.89420
