3410-0010
3410-0010
    TRUMETER
    TRUMETER - 3410-0010 - HOUR METER, AC/DC, 300VAC, 24.1X37MM
3410-0010 数据手册
Model 3410 Electronic LCD Hour Meter Description Maintenance Meters are offered with an optional maximum of 3 “Redi-Alerts” to alert users when service is due. Models are available with optional front panel field or fac- tory programmable alerts. Not only does the display flash to get attention, but it displays a choice of 7 different .08”[2mm] maintenance icons. Users can program or specify the service interval and flash duration for each Redi-Alert. Flash duration is the amount of time in hours that the specific icon flashes before and after the service interval. If a front panel manual reset of the Redi-Alert is required the front panel models with switches must be specified. Options Features • • • • • • • Totally sealed from moisture and dirt AC or DC voltage input in the same unit Tachometer/Hour Meter versions Compact depth Fits in existing panel openings Always on display 15+ Year Battery Life • • • • • • • • A choice of 6 housings A choice of reset modes Front panel programmable Preset Timer with output Can be programmed with starting time Programmable output thresholds Preset Hour Meter/time up or down Up to 3 Redi-Alerts/7 icons Specifications Display: LCD with large 0.28” [7mm] high figures black on light background Run indicator: Blinking decimal point Reset: Remote, manual and non-reset (remote reset not available on surface mount housing) Maximum Withstanding voltage: 30VDC, reference to Common Maximum Load current: 0.1Amp Hour Meter Resolution: 0.01 or 0.1 Hour, displayed; 1 second, internal Environmental: Temperature: (Storage and Operating) -40 to +185˚F [-40 to +85˚C] Humidity: 95% RH per SAE J1378 Vibration: 20g @ 10 to 80 Hz per SAE J1378 Shock: 44 to 55g’s per SAE J1378 Dielectric: 1000VAC 50/60 Hz for 1 minute Compliance: Compliant to the European WEEE and RoHS Directives Accuracy: ± 0.1% @ room temperature ± 0.2% over the specified temperature range Sealing: Totally sealed EMC Compliance: Records & Displays: 9999999.9 - hours & 1/10’s or 999999.99 - hours & 1/100’s EN61326:1997 with A1:1998 and A2:2001 for industrial environments 10-300VDC and 20-300VAC-50/60Hz
3410-0010 价格&库存
很抱歉,暂时无法提供与“3410-0010”相匹配的价格&库存,您可以联系我们找货
