3602-172TC
3602-172TC
    TRUMETER
    TRUMETER - 3602-172TC - TOTALIZING COUNTER, 6 DIGIT, 4MM
3602-172TC 数据手册
Now available LEFT-HAND and RIGHT-HAND drive shaft 3602 / 3603 / 3604 Series Mechanical Totalizing Counter 3603 left-hand shaft 3602 dual shaft 3604 right-hand shaft This unit counts revolutions on many different types of production machinery. Robustly constructed for continuous operation at high speeds with the main shaft running in double oil impregnated bearings to ensure accurate, long term, trouble free service. It is supplied with a double or single drive with wing bushing and customer configurable left or right side reset. Key Features Specifications • 6-digit 6.4mm (0.25in) readout • Up to 3000 counts per minute with 1:1 gear ratio • 1:1, 1:10, 2:1, 3:1, 4:1 gearings as standard • Front viewing • Reset to zero • Reset by lever • Customer configurable reset position - either left or right • Dual, left-hand or right-hand shaft options Reset Instructions Do not reset while counter is running Do not use an external device to reset counter Do not use excessive force to reset counter Make sure that all of the 0’s on the display are lined up   Display Base Material White on black, decimals black on white 6.4mm (0.25in) figures Black PC-ABS plastic Cover Material Grey ABS plastic Drive Shaft Diameter 7mm (0.275 inch) diameter Gearing Bearings 1:1, 1:10, 2:1, 3:1, 4:1 as standard. Others on application Bronze, oil impregnated for life Operating Torque 180g.cm (2.5oz.in) at 1:1 gearing Maximum Shaft Speed 3000 RPM Maximum Count Speed 3000 CPM Accuracy +/- 1% Operating Temp -10°C to +50°C [14°F to 122°F] Storage Temp -20°C to +50°C [-4°F to 122°F] Environmental Protection IP40 Nett Weight 200g Measuring Wheel Ordering Information Material Width 12” circumference 18” circumference 1/3m circumference 1/2m circumference Rubber Covered Plastic 3/4" (19mm) 007571 007573 007905 007574 Knurled Aluminum 3/4" (19mm) 001558 001622 Dimensions 36 VIEW.00° ANG ING LE 3.87 98.40 0.17 4.25 2.6 66 0.67 17.0 0.20 5.00 0.750 0.740 19.05 18.80 2.00 50.79 0.27 7.0 1.17 29.75 1.17 29.75 4.37 111 6.59 167.50 Part Number Ordering Chart COUNTER TYPE 3602DUAL SHAFT NUMBER OF DECIMAL PLACES FIG WHEEL READING GEAR RATIO 0 FULL FIGURES (PLAIN) 0 1 0 - 11” FIG WHEEL (FEET & INCHES) 1 1:1 2 0 - 9” FIG WHEEL (FEET & TENTHS) 2 2:1 3 0 - 9” FIG WHEEL (YARDS & TENTHS) 3 3:1 RESET POSITION IS CUSTOMER CONFIGURABLE - LEFT OR RIGHT 4 FULL FIGURES (FEET) 4 4:1 DRIVE SHAFT WITH WING BUSHINGS FITTED AS STANDARD 5 FULL FIGURES (YARDS) 5 1:25 EXAMPLE OF CODING: 3602 - 117TG 3602 = DUAL SHAFT 1 = ONE DECIMAL PLACE 1 = 0-11” FIG WHEEL (FEET & INCHES) 7 = 2:3 TG = TOP GOING 6 FULL FIGURES (METRES) 6 10:1 7 0 - 7/8” FIG WHEEL (YARDS & EIGTHS) 7 2:3 8 128:105 9 64:105 0 NO DECIMAL PLACES 3603LEFT-HAND SHAFT 3604RIGHT-HAND SHAFT 1 ONE DECIMAL PLACE ALL COUNTERS ARE 6 DIGIT, FRONT VIEWING 3602-117TG = 99999 - 11 / 2:3 / TOP GOING 9 0 - 9cm FIG WHEEL WITH 100 LINES(M/cm) www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7 Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com 1:10 DRIVE DIRECTION TC TOP COMING Material Direction (Top Coming) Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9JR Tel: +44 161 674 0960 Email: sales.uk@trumeter.com 5 TG 2 9 8 9 0 TOP GOING 5 2 9 8 9 0 Material Direction (Top Going) Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com 3602-DS-4.1 05/2023
3602-172TC 价格&库存
很抱歉,暂时无法提供与“3602-172TC”相匹配的价格&库存,您可以联系我们找货
